B body side marker metal studs need "thickening".What 2 use? #2606094
01/13/19 08:23 PM
01/13/19 08:23 PM
GA
roadrunninMark Offline OP
GA
The studs on my pot metal side marker housings (69 RR) are somewhat worn down to where they are not holding the nut on. I was thinking I could use some JB Weld on the studs and recut the threads using a die. Is this the best idea or what has others used? Is there different types of JB weld also? The one I bought just looks like a bottle of superglue.
Re: B body side marker metal studs need "thickening".What 2 use? [Re: roadrunninMark] #2606147
01/13/19 09:50 PM
01/13/19 09:50 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
You need the two part black and gray stuff.
It can run and sag until it sets up so you might want to watch for that.
Re: B body side marker metal studs need "thickening".What 2 use? [Re: roadrunninMark] #2606166
01/13/19 10:14 PM
01/13/19 10:14 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Try different nuts?
Carl Kessel
Re: B body side marker metal studs need "thickening".What 2 use? [Re: CKessel] #2606382
01/14/19 12:31 PM
01/14/19 12:31 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
try hammering the top of the nuts,sometimes that closes them up enough for a good bite on the stud.
