Jobber's Stock 340 replacement Converter: Dacco/Continental? #2603592
01/08/19 09:15 PM
01/08/19 09:15 PM
The Swamp
Sixpak Offline OP
Sixpak  Offline OP
The Swamp
Seems to me I remember a thread (yes I searched, and came up empty) regarding some reputable converter company (not an HP aftermarket like Dynamic, B&M, etc.) making an aftermarket replacement converter the equivalent of a stock 340 727 converter, for the jobbers and tranny shops. Trying to figure out what company it was and if they are still available. Supposedly a little better stall speed right from the factory...JK, you out there?...
Re: Jobber's Stock 340 replacement Converter: Dacco/Continental? [Re: Sixpak] #2603981
01/09/19 04:58 PM
01/09/19 04:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Part number for the factory 11" high-stall converter is 2801764, many rebuilders use the last three digits and refer to it as the 764 converter.
Re: Jobber's Stock 340 replacement Converter: Dacco/Continental? [Re: Sixpak] #2604007
01/09/19 05:38 PM
01/09/19 05:38 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
"Precision" rebuilds/makes converters. Not sure if they have something with more stall then factory or not.
Re: Jobber's Stock 340 replacement Converter: Dacco/Continental? [Re: Sixpak] #2604381
01/10/19 12:47 PM
01/10/19 12:47 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
In your title- Daaco makes OEM as well as some mild stall 2500rpm ish units which priced right and I guess 2400-2500 stall would be OEM for a HP mopar. All Star makes affordable converters with a good reputation.
Keep old mopars alive.
Re: Jobber's Stock 340 replacement Converter: Dacco/Continental? [Re: 2boltmain] #2604674
01/10/19 10:48 PM
01/10/19 10:48 PM
N.E. Ohio
K
KillerBee Online content
KillerBee  Online Content
K
N.E. Ohio
Per the suggestion from a reputable Mopar tranny builder I installed a Dacco #764 converter in the wife's mild 440 Six Pack Challenger.
I ordered it from Autozone for around $100.
I was concerned about the smaller 5/16 lug bolts but it has worked very well for the last 2 years. luck
Re: Jobber's Stock 340 replacement Converter: Dacco/Continental? [Re: Sixpak] #2606636
01/14/19 09:46 PM
01/14/19 09:46 PM
The Swamp
Sixpak Offline OP
Sixpak  Offline OP
The Swamp
Thanks to all...
Re: Jobber's Stock 340 replacement Converter: Dacco/Continental? [Re: Sixpak] #2618289
02/07/19 03:01 PM
02/07/19 03:01 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Just to double check, this is the right converter for a 1973 small block 727?
https://www.autozone.com/powertrain/tran...odel=&year=
Re: Jobber's Stock 340 replacement Converter: Dacco/Continental? [Re: Montclaire] #2618318
02/07/19 03:57 PM
02/07/19 03:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, but if it's a 340 it needs weights.
Re: Jobber's Stock 340 replacement Converter: Dacco/Continental? [Re: Sixpak] #2618370
02/07/19 05:48 PM
02/07/19 05:48 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I forgot about the weights. Thanks
Re: Jobber's Stock 340 replacement Converter: Dacco/Continental? [Re: Montclaire] #2618380
02/07/19 06:03 PM
02/07/19 06:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Jobber's Stock 340 replacement Converter: Dacco/Continental? [Re: Sixpak] #2618521
02/08/19 12:36 AM
02/08/19 12:36 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
If I can avoid spending another $100 on a flexplate, that would be ideal. I actually have a 1989 LA 360 and a stock 1973 727. I was looking at a CR25H but the advertised stall speed seems to vary greatly.
Re: Jobber's Stock 340 replacement Converter: Dacco/Continental? [Re: Montclaire] #2618655
02/08/19 02:19 PM
02/08/19 02:19 PM
dogdays Offline
dogdays  Offline
The
LA 360, the 5.9 Mag and the cat crank 340 all have different amounts of factory imbalance required. It's not one size fits all.
Also, the transmission IS a one size fits all as long as it's either a smallblock bolt pattern or bigblock bolt pattern. The converter does have to match the splines on the transmission input shaft and the flexplate and the converter need to have the same bolt pattern but aside from that, the engine determines the amount if any factory imbalance needed on either flexplate or converter.
Example: A 318 is bolted to a '73 340 transmission. The converter and flexplate are neutral balance.
An LA 360 is bolted to a '73 340 transmission. Converter and /or flexplate needs the 360's amount of factory imbalance on either converter or flexplate.
A 5.9Mag is bolted to a 1973 340 transmission. The flexplate or converter needs to have the 5.9Mag factory imbalance 9on either flexplate or converter.
But you probably knew this.
R.
Re: Jobber's Stock 340 replacement Converter: Dacco/Continental? [Re: Sixpak] #2619484
02/10/19 06:31 PM
02/10/19 06:31 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Which is why I was looking at the CR25H converter which is listed as being used behind '77-up LA 360s. Rock Auto was advertising them with an approx 2500 stall (when in stock) but they are also listed elsewhere as a 2100 rpm unit. I don't know which is correct or if it depends on the brand. I also do not know if a 1977 LA 360 requires the same amount of imbalance as a 1989 LA 360.
Re: Jobber's Stock 340 replacement Converter: Dacco/Continental? [Re: Sixpak] #2619592
02/10/19 11:50 PM
02/10/19 11:50 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
1973 torqueflite is 24 spline, correct?
Re: Jobber's Stock 340 replacement Converter: Dacco/Continental? [Re: Montclaire] #2619833
02/11/19 03:22 PM
02/11/19 03:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes.
Re: Jobber's Stock 340 replacement Converter: Dacco/Continental? [Re: John_Kunkel] #2634255
03/18/19 11:58 PM
03/18/19 11:58 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
If anyone finds a source for a CR25H converter without crazy shipping please post. No luck at any of the national chains, no stock at NAPA,RA or O'Reilly.
Re: Jobber's Stock 340 replacement Converter: Dacco/Continental? [Re: Sixpak] #2634257
03/19/19 12:09 AM
03/19/19 12:09 AM
The Swamp
Sixpak Offline OP
Sixpak  Offline OP
The Swamp
Originally Posted by Sixpak
Thanks to all...
I struck out trying to order a 764 converter thru Autozone. Seems Dacco stopped making these a year or so ago and there weren't any at the jobber warehouse.YMMV..
