Re: coolant capacity 69 440, 22" radiator
[Re: Moparnut426]
#2603594
01/08/19 09:29 PM
01/08/19 09:29 PM
RapidRobert
50% antifreeze/50% water will protect you to 35 below (& give plenty of corrosion inhibitors). You could figure out the % you want, then mix several gallons in that percentage to get it mostly full, then mixup a "pint" at a time (of that %) till it is topped off (if this is what you are asking).
