Here are a couple pictures of my 73 Challenger's exhaust hanger setup. This is the correct bracket for the passengers side in the later years.(original vs Accurate exhausts replacement)
You can see that it mounts to the shock x-member in the upper left section of the picture.
I think your 72 should use the "bolt-on" bracket mounted to the floor pan on the drivers side like the earlier years.(one half of the bracket is on the interior of the car...behind the back seat) My Challenger was a single exhaust car so I added the DS bracket.
In 74, they used the shock x-member hangers on both sides.
As far as the hangers at the back of the car...some used the hangers mounted to the trunk floor to support the mufflers. The later years used brackets mounted to the frame rail. Not sure what you should have on your 72. My 73 had one bracket mounted to the trunk floor on the passengers side. The frame rail hangers might be a Cuda thing.
