Need some '71 B-body measurements #2603025
01/07/19 05:32 PM
01/07/19 05:32 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I need the measurements where the front and rear bumper brackets bolt to the front frames and rear valances.
'71 B-body
I need the front bolt spacing and any offset (front to back) from horizontal
In the rear the holes are usually elongated so center to center would be fine.
I do not require side to side measurement.
A photo of each of those areas would also be awesome !!
Thanks in advance.
Re: Need some '71 B-body measurements [Re: Stanton] #2603601
01/08/19 09:44 PM
01/08/19 09:44 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Are you asking for measurements of the holes in the brackets themselves, or of the mounting holes in the subframes? Are you making some dollies? I can help with the fronts, but I haven't removed my rear brackets yet.
Btw, if you're making dollies, I can show you what I did to incorporate a lifting bracket with the dollies (so you can install the engine from below).
Re: Need some '71 B-body measurements [Re: Stanton] #2604013
01/09/19 06:01 PM
01/09/19 06:01 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
This is exactly what I need. I build rotisseries and I have an order for one that needs '71 B brackets. The buyer thought the front is the same as an E-body and but wasn't positive. Your measurements confirm that it is. Now I need the rear.
Thanks,
Stan
Re: Need some '71 B-body measurements [Re: Stanton] #2604195
01/10/19 12:12 AM
01/10/19 12:12 AM
Stoney Creek, Ontario, Canada
76Beeper Online content
76Beeper  Online Content
Here's the rear.
Attached PDF document
Re: Need some '71 B-body measurements [Re: Stanton] #2604200
01/10/19 12:16 AM
01/10/19 12:16 AM
The pdf is a download, but here it is......I hope its legible.
Re: Need some '71 B-body measurements [Re: Stanton] #2604202
01/10/19 12:18 AM
01/10/19 12:18 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
AWESOME !!!! Thanks guys !!
Re: Need some '71 B-body measurements [Re: Stanton] #2604204
01/10/19 12:19 AM
01/10/19 12:19 AM
Maybe right off the AutoCAD is better......
