New trans to old axle drive shaft?
#2599467
12/31/18 09:29 PM
12/31/18 09:29 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
OK, I know someone has already done this. I need to connect a NAG 1 trans to an 8 3/4 rearend. I know the driveshaft will need a slip joint in the middle, but how do you allow for angular movement at the trans?
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: New trans to old axle drive shaft?
[Re: rattler]
#2599596
01/01/19 01:45 AM
01/01/19 01:45 AM
Posts: 2,260 IL
furious70
IL
Somewhere in here there's pictures of a sprinter van output that had 4 bolts and you can get a slip yoke for.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: 5280Dart]
#2603191
01/07/19 11:57 PM
01/07/19 11:57 PM
rattler
Crofton, Ky.
Thanks, that's a big help. Do you know where I could get the 4 bolt Nag 1 output flange? Mine has the 3 bolt.
