Re: What gear lube in Dana 60? [Re: Cab_Burge] #2598886
12/30/18 06:41 PM
12/30/18 06:41 PM
Washington
madscientist Offline
Washington
Originally Posted By Cab_Burge
Originally Posted By DoubleD
Does anybody remember the mopar sperm oil rear end additive - man that stuff really had a smell to it
You can still buy it (Ford Brand) at your local Ford dealer, it is needed with any clutch type posi up
You can buy stuff way better than whale sperm today and not deal with the smell. It's 2019 for Petes sake. Why use crap like that?
Re: What gear lube in Dana 60? [Re: Roughbird72] #2598902
12/30/18 07:08 PM
12/30/18 07:08 PM
Kirkland, Washington
Pacnorthcuda Offline
The additives today, including the Ford product, are NO longer an actual whale product, and haven't been for many years.
But the Ford product IS a good additive!
Re: What gear lube in Dana 60? [Re: Roughbird72] #2600850
01/03/19 11:39 AM
01/03/19 11:39 AM
an8sec70cuda Offline
I use conventional 75w140 in whatever brand was easiest for me to grab off the shelf. The Dana 60 in my 3800+ lb cuda had the same oil in it for 12 years and saw 2 years worth of 10 sec passes, then 10 years of 9 sec passes w/ a few 8 sec runs right before I pulled the cover off for inspection. Not to mention a whole lot of street abuse.
Everything looked great inside. Just swapped the 4.10 out for a 3.54 over Thanksgiving and the gears looks great.
No more than 2 quarts.
Not saying synthetic isn't good, or any other type of oil is bad...just saying the regular cheap stuff works just fine.
CHIP
'06 GMC 2500HD LBZ Duramax
