Adding electric fuel pump to supplement mech pump
#2599204
12/31/18 02:07 PM
12/31/18 02:07 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Currently running a carter strip mechanical pump feeding a 505 at about 525 hp. Adding new heads and cam and should be around 600+ hp when it's done. It's mostly a street car, but if I run it at the track I don't want to chance any fuel starvation. My guess is it would be running on the mechanical only prob 98% of the time
My thoughts are to add a carter electric pump on a switch near the tank for occasional use. I've done this before on a different car with carter strip and Holley blue pump, but with and a bypass and check valve. I'm thinking id be ok with the less powerful carter electric pump without the bypass.
My questions for you guys...
Do you see this set up working without bypass/check valve? Mechanical pump pull through the electric ok? Regulator necessary? Lastly, has anyone gotten away with just the carter strip mechanical pump in similar powered setups?
Thanks everyone
2 kids and a dog
Re: Adding electric fuel pump to supplement mech pump
[Re: TonyS451]
#2599218
12/31/18 02:43 PM
12/31/18 02:43 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
I have done this more than a dozen times with the carters. I put a momentary switch on the secondaries of the carb so when it they kick in it turns on the electric pump. When you get out of it it shuts off. Never have to worry about turning a toggle switch on or off.
JAKES AUTOMOTIVE
[Re: JAKE68]
#2599245
12/31/18 03:02 PM
12/31/18 03:02 PM
TonyS451
Chicago, IL
I have done this more than a dozen times with the carters. I put a momentary switch on the secondaries of the carb so when it they kick in it turns on the electric pump. When you get out of it it shuts off. Never have to worry about turning a toggle switch on or off. Great idea!
2 kids and a dog
[Re: TonyS451]
#2599277
12/31/18 03:41 PM
12/31/18 03:41 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I have exactly what you’re describing on my Satellite. I found that the Carter electric pump was not conducive to allowing the mechanical to draw through it. Sometimes it would allow flow, sometimes not. It seemed it just depended on where the electric pump settled when it was last turned off. So I ran a bypass line with a check-valve around it. Works perfectly. I have it on a rocker switch, and only use it to prime and at the track. 👍
[Re: StealthWedge67]
#2599342
12/31/18 05:56 PM
12/31/18 05:56 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I have exactly what you’re describing on my Satellite. I found that the Carter electric pump was not conducive to allowing the mechanical to draw through it. Sometimes it would allow flow, sometimes not. It seemed it just depended on where the electric pump settled when it was last turned off. That's been my experience also, I'm always amazed when some claim to use them on an auxiliary basis.
[Re: John_Kunkel]
#2599440
12/31/18 09:02 PM
12/31/18 09:02 PM
TonyS451
Chicago, IL
I have exactly what you’re describing on my Satellite. I found that the Carter electric pump was not conducive to allowing the mechanical to draw through it. Sometimes it would allow flow, sometimes not. It seemed it just depended on where the electric pump settled when it was last turned off. That's been my experience also, I'm always amazed when some claim to use them on an auxiliary basis. I wonder how it works for some and not others? Maybe some electric pumps don't "park" in a way that would prohibit fuel flow through?
2 kids and a dog
[Re: TonyS451]
#2599582
01/01/19 12:57 AM
01/01/19 12:57 AM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I've done it several times with no bypass. I used a Holley pump. The check valves on the electric pump should open easily from the suction of the mech pump.
One caveat: If the diaphragm in the mechanical pump ever ruptures, the electric pump will fill the crankcase with gasoline.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: TonyS451]
#2599748
01/01/19 12:27 PM
01/01/19 12:27 PM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
Other then noise what is the reason to not run an electric all the time? They have become more reliable and they work well. I used a holley blue for a very long time and put lots of miles on it, never a problem. Put some time and effort into mounting them and the noise is greatly reduced.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2599832
01/01/19 02:10 PM
01/01/19 02:10 PM
TonyS451
Chicago, IL
I'm not opposed to that. I've done both and if I was starting from scratch, I might do it all electric. I bought the car set up this way and the whole fuel system is brand new. The carter mech pump is simple and really works well. I've heard of some using the mech pump by itself in 600+ applications, and who knows when I'm going racing next. At this point, I'm probably more concerned about racing a 4 speed w the stock 8 3/4.
2 kids and a dog
[Re: Hemi_Joel]
#2599836
01/01/19 02:11 PM
01/01/19 02:11 PM
TonyS451
Chicago, IL
One caveat: If the diaphragm in the mechanical pump ever ruptures, the electric pump will fill the crankcase with gasoline. Thanks Joel. Holley red or blue?
2 kids and a dog
[Re: Hemi_Joel]
#2599943
01/01/19 03:48 PM
01/01/19 03:48 PM
John_Kunkel
Rio Linda, CA
The check valves on the electric pump should open easily from the suction of the mech pump. It's not about check valves but about the design of the pump; some rotor designs don't allow through-flow and some only allow flow in certain rotor positions.
[Re: TonyS451]
#2600239
01/01/19 11:47 PM
01/01/19 11:47 PM
Posts: 12,293 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Besides the pump, your success will also depend on the lines feeding it. My Carter mech. wouldn't feed my 500" wedge with an 850 until I started experimenting with how long it took to fill a quart jug. Found 2 fittings that were really holding back the flow.
Replacing one and drilling out the other made a full 20% difference in volume. That worked well until I had the heads ported and stepped up in cam and installed a Dominator. Started running out of fuel on the big end again.
Installed a Holley electric pump actuated by a micro switch on the carb's secondaries and all is happy again.
So make sure that your fuel flow is not restricted any where and try the mech. pump to see if it will work.
You do have 3/8" lines and pick-up, don't you?
Master, again and still
[Re: DaveRS23]
#2600424
01/02/19 01:58 PM
01/02/19 01:58 PM
TonyS451
Chicago, IL
You do have 3/8" lines and pick-up, don't you? Thanks Dave. Yes,the lines and sender are 3/8", and they are factory reproductions. I'll look over the lines more closely, I think they are all factory bends and hopefully not kinked. Which Holley pump did you use? Did you use a pre filter? Where did you mount it? I was thinking of a red pump or carter electric.
2 kids and a dog
[Re: TonyS451]
#2600652
01/02/19 09:35 PM
01/02/19 09:35 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Run the electric in parallel with a check valve, no more problem...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: TonyS451]
#2600653
01/02/19 09:37 PM
01/02/19 09:37 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
It's been a while, but I believe the pump is a Holley 140. I hung it on the rear shock cross member using a piece of tire sidewall. Kinda like some of our exhaust hangers. Eliminates most of the noise.
And I use a cheap regulator at the carb, just to be sure the pressure is not excessive. No additional filter before the pump, just the OE sock in the tank.
