Re: Different Nag-1 controller [Re: hudsonhornet7x] #1997893
01/24/16 08:15 PM
01/24/16 08:15 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
Thanks Joe. I have spoken to Hotwire and they assured me they handle this swap,I just wanted to hear from someone who had done it. By the way, did you make your own adapter for the trans output to mate up to a regular u joint?
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Different Nag-1 controller [Re: hudsonhornet7x] #1997914
01/24/16 08:55 PM
01/24/16 08:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Different Nag-1 controller [Re: Darius] #1997919
01/24/16 09:03 PM
01/24/16 09:03 PM
Catskill Mountains, NY
Joe12459 Offline
Joe12459  Offline
I'm not sure when he got it all figured out, but I bought my system in June last year. I had actually seen your build thread, while I was working out my details, and contacted Russell Drake. At that time, he was still perfecting his setup( probably in your car), and advised me that it still needed some programming work. I'm not exactly a computer genius, so I went looking for another answer. The Hotwire setup made sense, as I had the complete 08 Charger donor car. This setup uses all of the factory modules, and programs them to read the speed signal from his tone ring, which is very similar to the PCS tone ring except it used two sensors. I have put several thousand miles on it now, and it performs flawlessly, just as the 08 Charger did. I have an 8 3/4 rear with 3.23 gears and it is great on the highway and plenty fast on the street.
Originally Posted By Darius
This is news to me. I looked into Hotwire and was led to believe they did not have the NAG1 stuff figured out, maybe that all happened after my debacle. Awesome news it is though as this drive line with an 83/4 rear is great! I have a 2.76 gear and I get 20 mpg 70mph=2000 +or- rpm. It is pretty quick off the line and I can smoke the tires all I want .It chirps 2nd and 3rd when I am on it hard but not spinning the tires. It would be a beast out the hole with even a 3.55.
More guys will make this swap now the right equipment is available. It is worth it!
Re: Different Nag-1 controller [Re: rattler] #1997922
01/24/16 09:05 PM
01/24/16 09:05 PM
Joe12459 Offline
Joe12459  Offline
I bought a driveshaft from www.thedriveshaftshop.com , which has an aluminum adapter that bolts to the trans flange, and a high speed CV joint that takes the place of the front u-joint/slip joint. I've had the car to 140+ mph, and it doesn't vibrate at all. Very nice setup.
Re: Different Nag-1 controller [Re: hudsonhornet7x] #1998006
01/24/16 10:57 PM
01/24/16 10:57 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
Thanks Joe. Do you remember what your driveshaft and adapter cost? You can PM me the answer if you like.
Re: Different Nag-1 controller [Re: rattler] #1998019
01/24/16 11:11 PM
01/24/16 11:11 PM
Joe12459 Offline
Joe12459  Offline
It was around $800.00 shipped, and it took about two weeks from the time I ordered it until it arrived.
Re: Different Nag-1 controller [Re: Joe12459] #1998022
01/24/16 11:14 PM
01/24/16 11:14 PM
Joe12459 Offline
Joe12459  Offline
You have to let them know if your trans has the three bolt (5.7) or the four bolt (6.1/6.4) flange, so they send you the right adapter, and you have to measure very accurately. If you use the Hotwire tone ring, allow 1/8" between the adapter and the flange for the tone ring.
Re: Different Nag-1 controller [Re: hudsonhornet7x] #1998035
01/24/16 11:29 PM
01/24/16 11:29 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Great info gents
Re: Different Nag-1 controller [Re: hudsonhornet7x] #1998250
01/25/16 10:55 AM
01/25/16 10:55 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I am happy to see this. Lots of questions in my mind but they probably are more specific to MY particular build as I was trying to swap EVERYTHING including the dash over and that created a different set of issues with the instrumentation and such.
Had I seen this I surely would have gone this route. I know I looked at Hotwire and they had nothing on their site at the time about sending them my computers and all.
Great new for those who want to do this. I do notice they don't have a reference for Chargers or Challengers as donor cars, wonder if there is a difference as far as programming goes on Hotwire's part?
Driving modern convenience in classic beauty
Re: Different Nag-1 controller [Re: hudsonhornet7x] #1998258
01/25/16 11:16 AM
01/25/16 11:16 AM
Canada
onig Offline
onig  Offline
Canada
I don't have or plan to use a Nag1 trans at this time.
But this is a good interesting thread.
Carry on men.
69 Dart
Re: Different Nag-1 controller [Re: hudsonhornet7x] #1998593
01/25/16 08:02 PM
01/25/16 08:02 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Good news, next do any of the converter company's make a high stall converter? I want a street strip one about 3500.
Re: Different Nag-1 controller [Re: hudsonhornet7x] #1998598
01/25/16 08:12 PM
01/25/16 08:12 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I think Paramount is a big name on NAG1 converters. There's other company's as well but that one stands out in my mind
Re: Different Nag-1 controller [Re: hudsonhornet7x] #1998697
01/25/16 10:39 PM
01/25/16 10:39 PM
USA
hudsonhornet7x Offline OP
USA
Guys,
I just got off the phone with Holley. Had a few questions about the dominator efi setup.
1st- Answer a few basic questions and you will have a start up tune
2nd- Supercharged engines can easily have a startup tune as well.
3rd- Once you do the start up, it DOES have self learning
4th- The Dominator currently has control over 4L60-80 transmissions, and they WILL have it for the NAg-1, but not right away. They are working on it for the future.
Hope this helps as you might as well get an efi that can control the trans at the same time.
Re: Different Nag-1 controller [Re: hudsonhornet7x] #2013962
02/17/16 03:05 PM
02/17/16 03:05 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Nice info. I'm still too busy to start on the 6.1L/NAG swap into the '69 Coronet. BTW, anyone have an extra power steering pulley? Looks like mine was broken when the engine shipped?
Re: Different Nag-1 controller [Re: hudsonhornet7x] #2600404
01/02/19 01:23 PM
01/02/19 01:23 PM
The Netherlands, OV
dickdale Offline
dickdale  Offline
The Netherlands, OV
I found a website calles www.ofgear.dk. Ole Fejer owns it. He sell a controller for the Nag1 that costs 800 euro's, as me being a overseas mopar owner I seriously consider this as an option.
