Re: Looking for header opinions
[Re: challenger451ci]
#2600002
01/01/19 05:28 PM
01/01/19 05:28 PM
Posts: 4,457 Washington
madscientist
Washington
Most likely the collector is too small and way too short. The 2 inch primary isn't so bad, but the collector is small and too short which is typical.
#2600004
01/01/19 05:36 PM
01/01/19 05:36 PM
Posts: 4,213 New York
polyspheric
New York
Bigger primary - if you can do it without a tight bend at the port to make the turn.
Boffin Emeritus
[Re: madscientist]
#2600192
01/01/19 10:22 PM
01/01/19 10:22 PM
Posts: 292 NY
challenger451ci
NY
Most likely the collector is too small and way too short. The 2 inch primary isn't so bad, but the collector is small and too short which is typical. By too short do you mean the merge section of the collector or the overall length? Does the exhaust add to the effective length of the collector?
[Re: polyspheric]
#2600194
01/01/19 10:25 PM
01/01/19 10:25 PM
Posts: 292 NY
challenger451ci
NY
Bigger primary - if you can do it without a tight bend at the port to make the turn. Kinda what I'm thinking too. I still have The bars and a factory steering box to work around too.
#2600378
01/02/19 12:30 PM
01/02/19 12:30 PM
Posts: 19,654 north of coder
moparx
Most likely the collector is too small and way too short. The 2 inch primary isn't so bad, but the collector is small and too short which is typical. By too short do you mean the merge section of the collector or the overall length? Does the exhaust add to the effective length of the collector? i have wondered about the collector/exhaust relationship before as well. if running same size tubing as the collector to an x or h pipe, does that effectively lengthen the collector ? or am i not taking something else into account ? ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: moparx]
#2600465
01/02/19 03:33 PM
01/02/19 03:33 PM
madscientist
Washington
Most likely the collector is too small and way too short. The 2 inch primary isn't so bad, but the collector is small and too short which is typical. By too short do you mean the merge section of the collector or the overall length? Does the exhaust add to the effective length of the collector? i have wondered about the collector/exhaust relationship before as well. if running same size tubing as the collector to an x or h pipe, does that effectively lengthen the collector ? or am i not taking something else into account ? I mean the overall length of a straight collector. And as poly says, exhaust length counts. You can also get too long on collector length too. If you are running full exhaust you live with the extra long collector. I first learned there was an issue with collectors that were too short in the late 70's. My local track started requiring mufflers on everything. And the great majority of guys kept saying their cars went faster with mufflers, which to me was (and still is) counterintuitive. The case was in fact collectors that were too short to begin with and the extra length of "collector" the muffler gave was why they were going quicker with mufflers. Had they started with the correct length and diameter of collector in the first place, the muffler would have always slowed the car down. Of course, dealing with bracket racers who didn't really care if their car was .4-.5 tenths slower was also an issue. I still have not reconciled my mind to the mind that willingly thinks it's ok to go slower. But that's me.
[Re: madscientist]
#2600507
01/02/19 04:32 PM
01/02/19 04:32 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
Every car I've tested at the race track, both stick shift and automatic picked up ET and a tiny bit of MPH with longer collectors ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) On a low compression pump gas street motor, 426 Max wedge, it picked up HP and Torque on the DTS engine dyno by going from a set of Hooker BB A body 1 7/8 (42 inch long) with a 3.5 inch collector to a set of 2 1/4 primary 25 inches long with 4.0 inch collector ![work work](/ubbthreads/images/graemlins/custom/work.gif) On your deal I would look at a set of 2/18 to 2 1/4 primary with 4.0 inch merged collectors or 2 1/4 to 4.0 inch collectors
#2600531
01/02/19 05:31 PM
01/02/19 05:31 PM
polyspheric
New York
The exhaust gas is looking for a change in area, in either direction: a step, collector, X pipe, even a really bad weld bead, whatever (but not a curve). Any of these cause a reflected pulse. If you're smart or lucky (I'll have to rely on lucky) the extra pulse "lines up" with an existing pulse (called superposition) at a useful RPM and enhances it. If not, it (partially) dampens it or does other evil things. That's why the old advice "built some length adjustment into it" is still valuable.
Boffin Emeritus
[Re: polyspheric]
#2600583
01/02/19 07:26 PM
01/02/19 07:26 PM
madscientist
Washington
The exhaust gas is looking for a change in area, in either direction: a step, collector, X pipe, even a really bad weld bead, whatever (but not a curve). Any of these cause a reflected pulse. If you're smart or lucky (I'll have to rely on lucky) the extra pulse "lines up" with an existing pulse (called superposition) at a useful RPM and enhances it. If not, it (partially) dampens it or does other evil things. That's why the old advice "built some length adjustment into it" is still valuable. Yep. Most guys would look at you like they swallowed a canary if you told them they need an "adjustable" header!!!!
[Re: HardcoreB]
#2600870
01/03/19 12:17 PM
01/03/19 12:17 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) I definitely feel like a bigger header will be worth power on the spray.
#2601088
01/03/19 07:27 PM
01/03/19 07:27 PM
Posts: 4,701 On the parachute mount
n20mstr
I'm looking for some real world examples on whether my hoagie would pick up with bigger headers. Current combo in a 3500lb E-body... 528ci Low deck, 12:1 on E85, Indy SR heads Max Wedge ported by Modern. 1050 Dominator. The car is setup for a decent amount of spray with a fogger. 3.73 gear, 28" tire, 2.28 first gear 727. Cam specs: .816"/.799", 284/300 @.050, 114LSA. Current headers are 2" primary 3.5" collector Super Comps that were probably bought during the Reagan Administration. I plan to run mufflers. WOW, gave up all the info here !! I can tell you from my real world experience. I went from Pro parts 2" to a set I made 2 1/4 with 4" collector. Really didn't pick up. Now after getting my engine Dyno'd at BES, he says whats holding it back is the LENGTH more than the diam. He told me 25" long primaries. (my current headers have 35 - 40" primaries, but its hard in an A body without going fender exits) And we have pretty similar combinations. Also I cant believe you have so much starting line ratio...?
....BAD A$$ STREET CAR.....
#2601099
01/03/19 07:53 PM
01/03/19 07:53 PM
n20mstr
I also think a lot of guys here are missing the point...this car has nitrous on it, and im sure plenty of it. I cant see collectors helping low end on this car..LOL
[Re: n20mstr]
#2601312
01/04/19 02:12 AM
01/04/19 02:12 AM
Posts: 292 NY
challenger451ci
NY
I'm looking for some real world examples on whether my hoagie would pick up with bigger headers. Current combo in a 3500lb E-body... 528ci Low deck, 12:1 on E85, Indy SR heads Max Wedge ported by Modern. 1050 Dominator. The car is setup for a decent amount of spray with a fogger. 3.73 gear, 28" tire, 2.28 first gear 727. Cam specs: .816"/.799", 284/300 @.050, 114LSA. Current headers are 2" primary 3.5" collector Super Comps that were probably bought during the Reagan Administration. I plan to run mufflers. WOW, gave up all the info here !! I can tell you from my real world experience. I went from Pro parts 2" to a set I made 2 1/4 with 4" collector. Really didn't pick up. Now after getting my engine Dyno'd at BES, he says whats holding it back is the LENGTH more than the diam. He told me 25" long primaries. (my current headers have 35 - 40" primaries, but its hard in an A body without going fender exits) And we have pretty similar combinations. Also I cant believe you have so much starting line ratio...? Haha! Well, I figured the only way to get good answers was with good info. Besides, the my junk is waaaay to heavy and down a few hundred HP to hang with you guys! When you're talking collector length, is that the length before a muffler or including a muffler? I'm on the fence for fender exits. Half my buddies are twisting my arm to do it and the other half have threatened to beat my @ss if I cut the car that much. I'm surprised to hear yours didn't gain with bigger primaries. I know you're throwing some spray at it. I had 4.10 gear with a stock 1st gear. That was plenty of SLR! Not sure if it could pull a Glide at 3500lbs???
#2601320
01/04/19 02:35 AM
01/04/19 02:35 AM
madscientist
Washington
I'm looking for some real world examples on whether my hoagie would pick up with bigger headers. Current combo in a 3500lb E-body... 528ci Low deck, 12:1 on E85, Indy SR heads Max Wedge ported by Modern. 1050 Dominator. The car is setup for a decent amount of spray with a fogger. 3.73 gear, 28" tire, 2.28 first gear 727. Cam specs: .816"/.799", 284/300 @.050, 114LSA. Current headers are 2" primary 3.5" collector Super Comps that were probably bought during the Reagan Administration. I plan to run mufflers. WOW, gave up all the info here !! I can tell you from my real world experience. I went from Pro parts 2" to a set I made 2 1/4 with 4" collector. Really didn't pick up. Now after getting my engine Dyno'd at BES, he says whats holding it back is the LENGTH more than the diam. He told me 25" long primaries. (my current headers have 35 - 40" primaries, but its hard in an A body without going fender exits) And we have pretty similar combinations. Also I cant believe you have so much starting line ratio...? Haha! Well, I figured the only way to get good answers was with good info. Besides, the my junk is waaaay to heavy and down a few hundred HP to hang with you guys! When you're talking collector length, is that the length before a muffler or including a muffler? I'm on the fence for fender exits. Half my buddies are twisting my arm to do it and the other half have threatened to beat my @ss if I cut the car that much. I'm surprised to hear yours didn't gain with bigger primaries. I know you're throwing some spray at it. I had 4.10 gear with a stock 1st gear. That was plenty of SLR! Not sure if it could pull a Glide at 3500lbs??? I don't like fender well headers. The primary pipes are always way too long. Collector length starts from where the 4 pipes come together (assuming 4-1 headers) and terminates at the point where you have a reducer, or the collector stops. If you have a full exhaust, it's a bit different. If there is pipe right off the collector, I count that as collector IF it's the same diameter as the collector. If it's smaller than I don't count that. If you bolt a muffler right on the end of the collector then it's collector length. Again, if using mufflers I always go up one size in collector. Fender well headers have at least two faults. Primary tubes that are way too long and a collector that's way too short.
#2601379
01/04/19 10:44 AM
01/04/19 10:44 AM
n20mstr
collector length ? well if you plan on running a muffler I guess that would be included in the overall length. I would say go bigger if its longer. Instead of 4" consider 5"
The fender exits...Ughhh I really don't like them, but they are the way to a real short primary tube. Again you probably want 25-30" max. If you going fender exit im assuming you going to use a Burns type real short muffler? If under car then do what I did, Cut a cheap dynomax or similar straight through, I cut 5" off each end and ...there you go instant "shorty" mufflers LOL.
On the SLR, don't be shy. Im leaving in 2nd (1.48) and 4.11 out back. I hate to say it but the trend right now is 1.40 or less and 4.30 or more. Works well with little SLR and a lot of gear out the back to pull the car through. Those 3.73 gears are lugging the car on top, but I know you got to work with what you got. Less SLR will always help with No Prep and junk tracks. If possible consider going back to the 4.10 or 4.30 and get a valve body that will allow leaving in 2nd. This also may require a stator change in your converter. Yes the powerglide could be a good option for you. It will also dump a bunch of weight over that 727...lots of stuff to think about
Do you have any racepak or data logger ? A sportsman racepak will give you so much real world info and help you see whats going on, it will eventually pay for itself in good decisions rather than useless testing. especially with converter and gearing...
[Re: n20mstr]
#2601536
01/04/19 03:58 PM
01/04/19 03:58 PM
Posts: 292 NY
challenger451ci
NY
Do you have any racepak or data logger ? A sportsman racepak will give you so much real world info and help you see whats going on, it will eventually pay for itself in good decisions rather than useless testing. especially with converter and gearing... Thanks for all the input! I value everyone's help. Fender exits are pretty much not an option at this point. I still like to drive the car occasionally. Loud is one thing...4"-5" open header mufflers out the side is a whole new level of obnoxious. I'm going to see what I can fit up close to the headers and keep everything as short as possible. Right now it's 3.5" all the way back to 2 chamber Flowmasters right in front of the rear. So it's a very loooong and small diameter collector the way it sits. Gotta be killing some power on the big end I would think. Lenny at Ultimate told me I'm most likely driving thru the converter with 3.73's and a 29" tire and it's about as tight as he can make it. One of the reasons I knocked the tire down to 28", but still not going to make the difference back to a 4.10. Now I'm trying to stick the 28" tire....It's a vicious circle! The 2.28 1st gear did make it possible to get on the ramp a little faster than the stock 1st gear. I have a 2nd gear leave CRT valve body but can't get a decent high gear shift. RPM drops about 300-400 from 2-3 on the sauce. Put an A&A VB back in and it's back to 700-800rpm on the 2-3. I haven't had the time to dig into that, but wanted to try 2nd gear for sure especially for zero prep stuff. I use an LM-2 that I've added Pan vac, nitrous pressure and fuel pressure sensors to. It's no Racepak but helps see what's going on.
#2601671
01/04/19 09:20 PM
01/04/19 09:20 PM
n20mstr
you racing through the mufflers ? If so i would bet its a lot faster open headers ...youll lose a lot of weight, those flowmasters are heavy, and they really dont flow well either lol.
Have you tried tractor fluid in the trans ?
[Re: n20mstr]
#2601874
01/05/19 12:42 PM
01/05/19 12:42 PM
Posts: 292 NY
challenger451ci
NY
Have you tried tractor fluid in the trans ? Yep, right through the ancient, heavy Flowmasters! I occasionally still run where open headers might be frowned upon. Would be an easy check to see how much it picks up. I do have JD low viscosity oil in the trans. I'm going to try the high viscosity. I also think I need to bump the line pressure, but will see with the heavier fluid. Lenny also wants me to make sure I have enough pressure in the cooler lines. Apparently low pressure there can cavitate the converter.
