Re: 4 DOOR WITH 2 DOOR LOOK
[Re: therocks]
#2604836
01/11/19 12:02 PM
01/11/19 12:02 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
Sold my 65 Plymouth sedan to a guy from Michigan that was converting a 4 dr to 2 dr.Body wast bad but he wanted from the doors back.Said it was pretty easy to convert.Rocky Rocky's statement is correct. The conversion is not that difficult. There've been posts here and elsewhere on the conversion, on a number of different cars. Here's one for my car for example. board.moparts.org/ubbthreads/ubbthreads.php/topics/1347457/2.html The toughest parts to find in my experience are the 2 dr door jambs and the rear quarter window frames. That said, it's worth the hunt and the effort. I always thought removing the rear door handles and/or welding the rear doors shut resulted in a car that looks out of proportion. A 2 dr sedan looks so much better as a drag car.
Lead, follow or get the hell out of the way
[Re: peabodyracing]
#2604871
01/11/19 12:48 PM
01/11/19 12:48 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
It's hard to make out in the photos but you need to open up the sill on the four door rocker or swap in a two door version. I have seen people weld right to the sill but if you do that the water has nowhere to go and you'll eventually have problems.
[Re: RapidRobert]
#2604989
01/11/19 03:48 PM
01/11/19 03:48 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Just goes to show how similar the basic bodies are. In the early B's it looks like all but the convertible were built as 4-doors and the rear door opening covered over.
[Re: A/MP]
#2605046
01/11/19 06:12 PM
01/11/19 06:12 PM
Posts: 4,563 Motor City
6PKRTSE
Motor City
I know a dude that has two four doors and another dude that has another four door. I have seriously been considering trying to get all three, find the two door parts & start doing conversions on this 62-65's.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: dvw]
#2605079
01/11/19 07:13 PM
01/11/19 07:13 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
The 62-65 2 door and 4 door share the same body. Move the B pillar back. Install 2 door doors. Patch the 1/4 panel with a piece of the 4 door skin. Instant 2 door sedan from a pristine 4 door. Though my son says converting his 62 4 door to a 2 door would only result in a ugly 2 door. Doug "Embrace the doors. All 4 of them! beer" quoted Look at that MORE door!! If I were to try and build a car nowadays,4 doors and wagons are cool!!!
[Re: hemi-itis]
#2605224
01/12/19 12:12 AM
01/12/19 12:12 AM
RapidRobert
I didn't read all the posts but I am assuming that was a 4dr originally!
[Re: Montclaire]
#2605321
01/12/19 10:37 AM
01/12/19 10:37 AM
peabodyracing
Minnesota
[/quote]
It's hard to make out in the photos but you need to open up the sill on the four door rocker or swap in a two door version. I have seen people weld right to the sill but if you do that the water has nowhere to go and you'll eventually have problems. [/quote]
You're right. In my case we'd studied the remains of the 2dr parts car and reworked the 4 door rocker to provide for drainage in roughly the same manner.
[Re: hemi-itis]
#2605334
01/12/19 11:54 AM
01/12/19 11:54 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
The 62-65 2 door and 4 door share the same body. Move the B pillar back. Install 2 door doors. Patch the 1/4 panel with a piece of the 4 door skin. Instant 2 door sedan from a pristine 4 door. Though my son says converting his 62 4 door to a 2 door would only result in a ugly 2 door. Doug "Embrace the doors. All 4 of them! beer" quoted Look at that MORE door!! If I were to try and build a car nowadays,4 doors and wagons are cool!!! I wouldn't change this for anything !!
