Re: Starting to work on the Duster
[Re: JAMESDART]
#2594937
12/21/18 03:41 AM
12/21/18 03:41 AM
Posts: 31,051 Oregon
AndyF
What oil pans have you tried? the road race pan is cool but I think it's too wide for the Spool mount k frame. I like the hemi pan I just had to cut the lip off the k frame and weld it. That is a C body 187 pan in the picture. It could be made to work but I'd like a little more oil capacity. I tried a Hemi pan but the idler won't clear without making some major modifications. The Milodon road race pan won't fit the late model K frame without a lot of modification. I'm going to try the Mancini Hemi pan that has the 187 notch. That should be the perfect pan if it fits. It has the 6 qt capacity but it also has the 187 idler arm notch. So basically they took two good ideas and married them together. I haven't tried it yet so we'll see if it actually works like it is supposed to. If it doesn't work then I suppose it is time for something custom.
[Re: AndyF]
#2595635
12/22/18 09:54 PM
12/22/18 09:54 PM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
Time to fab up some lightweight bumper brackets! These are the brackets I have on my Duster. Got them a few years ago, they were made by a guy on here JBMopars. These shaved a bunch of weight but still hold the stock steel bumper up no problem. Obviously no spoiler mount but you get the idea.
'71 Duster '72 Challenger '17 Ram 1500
[Re: JAMESDART]
#2595808
12/23/18 03:35 PM
12/23/18 03:35 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
What oil pans have you tried? the road race pan is cool but I think it's too wide for the Spool mount k frame. I like the hemi pan I just had to cut the lip off the k frame and weld it. I've got the Milodon RR pan in my B engine A with the spool mounts. It's tight and I did some trimming on the lip when I welded it up. The K members aren't very consistent in the fine details, and I'm using the Schumaker conversion mounts so- YMMV.
[Re: AndyF]
#2596805
12/25/18 04:42 PM
12/25/18 04:42 PM
AndyF
Here are the oil pans I tried. The black one is the one from Mancini. It seems to work the best. They call it a Hemi pan but I think a better description would be a deep 187 pan. It basically looks like the 187 pan but is just deeper. The orange pan is a factory 187, the green pan is another Hemi pan from Mancini and the gold pan is the Milodon road race.
[Re: AndyF]
#2596881
12/25/18 07:22 PM
12/25/18 07:22 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
Nice selection. Is the engine already chosen?
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2596953
12/25/18 11:00 PM
12/25/18 11:00 PM
AndyF
Nice selection. Is the engine already chosen? Yep, I'm pulling the 512 out of my Coronet and putting it in the Duster. I'm building a 496 (426W with 4.25 stroke) for the Coronet.
[Re: JAMESDART]
#2596954
12/25/18 11:02 PM
12/25/18 11:02 PM
AndyF
For some reason I didn’t think the notch was needed on the 73+ steering? You tried these pans with the engine and trans in place in the car? It is required in my car. It doesn't need to be a big notch but there needs to be clearance for the idler or else the steering won't go full lock.
[Re: Cab_Burge]
#2597262
12/26/18 06:30 PM
12/26/18 06:30 PM
AndyF
[Re: cudadoug]
#2599259
12/31/18 03:23 PM
12/31/18 03:23 PM
AndyF
Curious Andy...
Why an OE radiator and not aluminum from one of the various suppliers? I like the OE look, especially for radiators and shrouds. Aftermarket radiators and shrouds tend to be ugly. Griffin does make some nice aluminum radiators that have an OE appearance but they are super expensive.
[Re: DusterKid]
#2599261
12/31/18 03:24 PM
12/31/18 03:24 PM
AndyF
It might just be the angle of the picture, but looks like it sticks up from the radiator support a fair amount. Does the hood close with it in place? It does stick up a fair amount but the hood has some clearance in that area so it seems to close okay. I'll keep an eye on it as the build progresses.
