Re: A-body console carpet pics
[Re: njmopar]
#2593532
12/18/18 12:59 AM
12/18/18 12:59 AM
Posts: 6,480 Kingston, IL USA!
gts340swinger
Kingston, IL USA!
You should have the grommet on your high beam switch. It is just a piece of plastic that the carpet slips inside the edge so it probably wouldn't leave much of a mark. As for the carpet panels, I will see is I can get some pictures. From memory, the panels do hang down past the console to seal up the gap.
Mr. Norm's "Fanatic" (idiot) 71 Mr. Norm's Demon GSS 77 Mr. Norm's personal B250 GSS van 76 Mr. Norm's KZ900 Motor Sports Special 69 Mr. Norm's M code Dart GTS 69 D100 68 Barracuda 64 Valiant V200 07 Charger Daytona SST 6 speed test mule.
[Re: njmopar]
#2594585
12/20/18 05:03 AM
12/20/18 05:03 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
This is factory console carpet from a '69 Barracuda M4. The driver side hangs down farther than the passenger side.
[Re: njmopar]
#2594586
12/20/18 05:11 AM
12/20/18 05:11 AM
kentj340
Cut and Shoot, TX
Next two show backside of driver side. What looks like a tear behind the hand is apparently the way the factory made it.
Last one is entire console carpet laid flat. Driver side is away from the camera; passenger side is closest.
[Re: njmopar]
#2594885
12/21/18 12:36 AM
12/21/18 12:36 AM
kentj340
Cut and Shoot, TX
Photos of the molded hump. The front half is laminated paper, about 10-12 layers or more, maybe with varnish on it? The rear is just glue on the back of stretched/shaped carpet.
[Re: kentj340]
#2595057
12/21/18 01:56 PM
12/21/18 01:56 PM
Posts: 2,255 New York
rarefish
New York
This is factory console carpet from a '69 Barracuda M4. The driver side hangs down farther than the passenger side. Is that the original color of your console or has it been resprayed? I can't tell it its blue or green in color...
[Re: njmopar]
#2595381
12/22/18 04:42 AM
12/22/18 04:42 AM
kentj340
Cut and Shoot, TX
That's the factory original paint, Bayou Green Metallic Low Gloss, according to the FSM.
Car is ready soon to go to paint shop, and the console is just about the only thing that doesn't need repaint.
I might make molded humps for sale later, but not now - I'm building my climate controlled Mopar man cave.
