Holley 850 parts question. #2591981
12/14/18 06:47 PM
12/14/18 06:47 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
I just got a Holley 850 DP (4781) and noticed something when taking it apart, the front metering plate is from a 3310 carb. I know this is for a 750 & 780 carb, is there going to be any problems using it on an 850? This is the kind of stuff you run into when buying off the web.
Re: Holley 850 parts question. [Re: 340Scamp] #2591993
12/14/18 07:23 PM
12/14/18 07:23 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Somewhere a while back I found a site that listed what metering blocks came with each List # (carb #). I think I found it through the all-carbs.com site.
Needed that info when I had a 4780 that had a vacuum-secondary metering block in it..."dang, why no secondaries?"
Re: Holley 850 parts question. [Re: 340Scamp] #2594550
12/20/18 02:13 AM
12/20/18 02:13 AM
Washington
madscientist Offline
Washington
The best advise I can give you is to spend a few bucks on aftermarket billet metering blocks. And call ThumprDart on here. He's easily found in the engine forum. He can help you.
I have no use for any of these OE Holley metering blocks.
