More missing screws: '71 B Body Rallye Cluster dash #2590827
12/12/18 01:46 PM
12/12/18 01:46 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Hi all,
At the bottom of the Rallye Cluster panel, from behind the dash, there are two screws/bolts that hold the panel to the metal dash frame (circled in pic below). I don't remember removing these, so they may have been missing already. Can anyone tell me what type/size screws/bolts go in here? In the pic, the left hole has a sheet metal screw in it, but I'm sure that's not correct. Thanks for any help.
Roger
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: Fab64] #2590941
12/12/18 05:08 PM
12/12/18 05:08 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
When I dissasembled my car they were already missed on my car, so I simply installed any selftapping screw what fits there. I think used the same used on glove box liner in fact. I guess could search on my 74 Mopar parts catalog on the STANDARD PARTS section for screw specs, but didn't go that deep on that area where is enough to get some that just work
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: NachoRT74] #2590962
12/12/18 05:54 PM
12/12/18 05:54 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
That was my first thought also. Unfortunately, those are way too small. In fact, I've been trying progressively larger sizes, and I'm now up to the same size as those two silver bolts that hold the underside of the dash to the sides (the ones I asked about yesterday), and even those are too small in diameter. I can't imagine Chrysler using bolts that large for this purpose(?). I can't find anything around the garage that's just a tad larger, so I'm going to have to look at the hardware store. Loads of fun.
[Update]: Ok, just went to hardware store and tried a metric #7 (slightly larger than the 1/4" that I tried before, which was too loose) and it won't even go into the hole. I'm thinking that somewhere in the last 47+ years, some bozo stripped out both holes. tsk I'll try using a couple of large sheet metal/self-tapping screws, and hope for the best. Although, I could probably get by without using any screws at all in those two holes, since the panel doesn't seem to be sticking out much at all. Either that, or try to devise some other way of pulling it in. Thanks for the help!!
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: Fab64] #2590994
12/12/18 07:36 PM
12/12/18 07:36 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
maybe the J nuts inserts on cluster housing are worn out and needs to be replaced, being that the reason why screws don't fasten.
BTW just searched on my catalog and couldn't find any info about them
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: Fab64] #2591004
12/12/18 07:57 PM
12/12/18 07:57 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
you are missing also one of these at least ( can tell the one further down wink )
aside the column ground reinforcement wire with it
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: Fab64] #2591007
12/12/18 08:09 PM
12/12/18 08:09 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
check if the cluster got one of these fasteners there
Can't recall which one exactly is, but pretty much similar to the 9879
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: NachoRT74] #2591085
12/12/18 10:45 PM
12/12/18 10:45 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
You're very sharp-eyed! Yes, I was going to ask about that eventually. Thanks for the link - I only need one.
As for J-bolts, there are none at that point. These holes are in the metal part at the bottom of the instrument panel. I have an idea how to fix it. If it works out, I'll post my solution here. Thanks!
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: Fab64] #2591114
12/12/18 11:51 PM
12/12/18 11:51 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Gotcha! there you have the answer... you need to install couple of U nuts ( I thought it was called J nut, but is U ) on circled areas to be able to fasten the screws.
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: Fab64] #2591182
12/13/18 03:51 AM
12/13/18 03:51 AM
Shoreline, Washington
72roadrunnergtx Offline
To be clear, the u-nuts go on to the bezel, not the cluster frame. #8 screws pass through the cluster frame locations indicated.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: Fab64] #2591213
12/13/18 10:15 AM
12/13/18 10:15 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
true!!! my memory failed! ( 6 and a half years without my car at this moment frown )
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: Fab64] #2591214
12/13/18 10:18 AM
12/13/18 10:18 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: Fab64] #2591249
12/13/18 12:21 PM
12/13/18 12:21 PM
Lansing, MI
70gtx440dana Online content
70gtx440dana  Online Content
Lansing, MI
I have several of those star washers. PM me your contact info and I will send you one. Joe
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: 70gtx440dana] #2591450
12/13/18 07:22 PM
12/13/18 07:22 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Thank you, Joe - you have a PM.
NachoRT74 and 72roadrunnergtx: Thanks for the additional info. I've gone through all my pics, and can't find one of the back side of the cluster. I also can't believe I never noticed this when I had everything apart. I *assumed* the cluster was only held in by the four screws near the top (should have known, that didn't seem like enough). I found a pic online (below) and I think these are the two tabs that are resting up against those two holes I showed in my earlier pic. Unfortunately, there are no u-nuts on them, and I really don't want to pull everything back out to put them on. Instead, I'm going to devise a simple fix, which I will post when it's done. Thanks again!
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: Fab64] #2591572
12/13/18 11:49 PM
12/13/18 11:49 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
as mentioned, the U nuts are not on housing but on bezel... my bad
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: NachoRT74] #2591599
12/14/18 12:55 AM
12/14/18 12:55 AM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Unfortunately, I'm not familiar with the terminology used. What part are you calling the "bezel"? There are at least three parts to the instrument panel and "rallye cluster":
1. The metal dash frame, which runs across the entire front of the car.
2. The plastic, wood-grain "panel" that you see from the driver's seat.
3. A metal housing that mounts to #2 from behind, to which the instruments, lights and wire connections are attached (actually, this itself is in two pieces: a white plastic frame at the front, and the silver metal housing at the rear).
Numbers 2 & 3 are attached together, and the two tabs at the bottom of #3 (where I'm missing u-nuts) are attached from behind at the bottom of the dash (#1), on either side of the steering column.
At the top, there are four screws that go through the plastic, wood-grain panel (#2), and screw into u-nuts that are on tabs at the top of the metal dash (#1).
I don't know if this is the same for 1971 thru 1974.
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: Fab64] #2591616
12/14/18 01:46 AM
12/14/18 01:46 AM
1. Full dash frame
2. Cluster bezel, the two u-nuts in question are fitted to the bezel not the cluster frame tabs.
3. Cluster frame.
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: 72roadrunnergtx] #2591644
12/14/18 02:39 AM
12/14/18 02:39 AM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Originally Posted By 72roadrunnergtx
1. Full dash frame
3. Cluster frame.
Ah, thank you, that makes sense. So, it sounds like the two attaching screws first go through the holes in the cluster frame tabs, then into the u-nuts that are on the bezel? The screws must be pretty long, correct? Now I'm wondering if my u-nuts are actually there, and I just didn't reach in far enough? Do you happen to have a picture of the screws? Are they hex-head? How long are they? Are they sheet-metal type, as the four screws that hold the cluster bezel in at the top of the dash frame?
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: Fab64] #2591647
12/14/18 03:04 AM
12/14/18 03:04 AM
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: Fab64] #2591657
12/14/18 04:06 AM
12/14/18 04:06 AM
Akron, Ohio
VegasCharger Offline
Akron, Ohio
I have those U nuts and corresponding screws for your dash cluster. And I also have the steering column star washer.
If you're still looking for the hardware and want to use OEM please LMK.
Re: More missing screws: '71 B Body Rallye Cluster dash [Re: Fab64] #2591765
12/14/18 12:43 PM
12/14/18 12:43 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
already replied by 72roadrunnergtx so nothing else to add wink
( bezel is the exterior plastic cluster mask wink )
