Optimum lifter preload UPDATE
#2590795
12/12/18 12:39 PM
12/12/18 12:39 PM
Posts: 6,406 Abilene, Texas
fastmark
Abilene, Texas
On a mild hydraulic cam, what is the optimum preload? How much is too much?
Re: Optimum lifter preload
[Re: fastmark]
#2590838
12/12/18 02:27 PM
12/12/18 02:27 PM
Posts: 1,505 TN
SCATPACK 1
TN
Assuming you have adjustable rocker arms or adjustable pushrods. Tighten until there is zero slack in the rocker to pushrod and then turn another 1/4 to half turn. IF you are using the stock rockers and stock pushrods, then you are stuck with what you have unless you can get rocker shaft shims. This would move the rockers away from the valve tip and pushrod giving you less preload. OR order custom length push rods to give you the preload you want. I assume you know about leaving the lifters sitting in oil over night to get all the air out of the lifter plungers. IF not, you will never get the prelaod right.
Old Geezer Racing
[Re: fastmark]
#2590959
12/12/18 05:43 PM
12/12/18 05:43 PM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
.020 to .040 is what I was taught, Should be fine for stock replacement but it probably depends on the exact parts used.
Rich H.
Esse Quam Videri
[Re: fastmark]
#2590960
12/12/18 05:43 PM
12/12/18 05:43 PM
ZIPPY
S.E. Michigan
What is the OP working on, and what is the parts/machine work combination?
Rich H.
Esse Quam Videri
[Re: fastmark]
#2591012
12/12/18 08:22 PM
12/12/18 08:22 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Yep .020 to .040 is good. If you are going to race it then I like to set mine closer to almost no preload but they can be a little noisier. I had my old 383 at about .010 because I raced it some and it was less chance of lifter pump up if over reved. Years ago my buddy used to race me in my 273 Dart and he was not good with his 4-speed Chevelle and he missed gears a lot. One day when we raced my little 273 was right with his 350 Chevelle and right after I yanked third and jumped a 1/2 a car on him with my Hurst Super Shifter he droped way back and disappeared. I went back to his house and about a 1/2 hr later he showed up. He missed third and over reved his eng and his lifters pumped up and held the valves open and shut the eng down. He said he could not get it started for almost the 1/2 hr as the lifters had to bleed back down below 0 preload to get comp back. Ron
[Re: fastmark]
#2591073
12/12/18 10:23 PM
12/12/18 10:23 PM
fastmark
Abilene, Texas
Sorry guys, should have been more specific. My good machine shop built the short block and the heads, so I know they were correct. The problem was the shop that installed the heads and installed the motor was terrible. It is a 70 383 with stock non adjustable rockers and very mild cam. I took on the job and found the carb was very rich, the the total advance was 80 degrees and the button was missing in the rear end and the brake drums were rubbing on the backing plates. Therefor, the test drive was limited but the motor ran terrible with very little power. The car is going back together now so when I pulled the valley pan to fix the leaks, I noticed the lifters had way too much preload. .110 to be exact. I think it was holding the valves open slightly above 2500 rpm. I use adjustable rockers on all my builds and I do the 1/4 to 1/2 turn and never actually measure preload. She does not want to spring for the adjustable rockers, so I’ll have to shim the stands or get new pushrods. I called Hughes Engines and they said they liked .080 to .090 preload. That seams high as well. My bud said .060 is fine for a street engine. This motor has less than 100 miles, if that, on this rebuild.
I should add that the lifters are not performance lifters. They have the small wire retainer for the plunger and I have seen them break if not enough preload is used.
[Re: fastmark]
#2591149
12/13/18 01:10 AM
12/13/18 01:10 AM
RapidRobert
there is a school of thought that haveing the cup a few tho up from the BOTTOM is the way to go. I do not think your preload is an issue. On the snap rings there is a snap ring HO-68 from www.huyette.com (iirc) that is cheap/works well & it was suggested to install em with the squared edge on the bottom which I thought was backward but the guy (on here but I forget who) sounded sharp. I previewed this & huyette ain't right but I have the receipt if needed. MORE EDIT it is www.huyett.com HO-68 housing ring internal 11/16 CS PH
[Re: fastmark]
#2591233
12/13/18 11:46 AM
12/13/18 11:46 AM
Posts: 1,260 Netherlands
72Challenger
Netherlands
And any influence by the amount of oil pressure? As in might to much pressure makes hydraulic lifters act like solids?
[Re: 72Challenger]
#2591256
12/13/18 12:28 PM
12/13/18 12:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Take a 1/8 of a turn out of all of them and see if it acts better.. if not I would look at the cam timing.. if its retarted it will be a mutt.. and dont take the word of your shop.. we are all human and make mistakes
[Re: fastmark]
#2591283
12/13/18 01:20 PM
12/13/18 01:20 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
“Too much” preload is when the plunger is down far enough to plug off the feed hole in the side of the lifter. Other than that........ any preload that doesn’t result in that happening should work fine in a daily driver type application.
In the OP’s situation, if he’s not comfortable with .110 preload, a set of .050 shorter pushrods would certainly put him well within the preferred range.
In a similar scenario as Rons Chevelle story....... I was out wailing on a car with a tired old 361 that did the exact same thing. I wound it out hard in 1st...... it sputtered a bit, then just shut off. I had no clue what it was. I was under the hood looking at wiring and such. When I cranked it over it was like the plugs were out of it.
Then, after a period of time, I tried it again.......just because.........and I could tell some compression was back, at least on a couple cylinders........ and it started. Running really rough at first, then started smoothing out, and then it was fine.
[Re: A727Tflite]
#2591357
12/13/18 04:10 PM
12/13/18 04:10 PM
Posts: 3,916 usa
lewtot184
usa
I see this preload topic brought up and battered to death with opinions and such.
Question for those that may have checked. How much plunger travel exists on a production Chrysler lifter? How much plunger travel exists on a late model aftermarket lifter?
Reason I ask.
The service manual calls out .060” - .210” dry lash. That equates to .040” - .140” plunger preload.
If you have production level plunger travel - your engine should not run poorly, idle poorly, perform poorly with this preload.
I ran production juice lifters in Stock Eliminator in the 70’s with a GK cam, production pushrods and rockers and never floated a valve, broke parts, etc. I kept my preload at .060”. No issues for 5 years using the same parts without replacement. Of course I only spun it 6K back then but it never failed me. all the tappets I've measured had .200+ plunger travel. this does not include any of the race tappets, just factory or OEM replacement.
[Re: A727Tflite]
#2591435
12/13/18 06:20 PM
12/13/18 06:20 PM
fastmark
Abilene, Texas
Fastmark - how did you determine how much preload you have ? What method did you use ? I used a dial indicator on the tip of the rocker by the pushrod and tightened the rocker stands until the pushrod had zero preload. The cam was on the base circle, of coarse. I tightened the bolts till the shaft was tight to the stands and then read the indicator. Comp had a different way in some instruction I had once. They said to mark the pushrod at zero preload and and then tighten the shafts and mark again. Measure the difference and you have your preload. Both methods came out the same, .110.
[Re: A727Tflite]
#2591442
12/13/18 06:49 PM
12/13/18 06:49 PM
fast68plymouth
So. Burlington, Vt.
A question for fast - in theory, wouldn’t weaker valve springs allow quicker and more violent lifter separation/pump up?
Wouldn’t weaker valve springs take longer to “pump down” the plunger versus a stronger spring? I would think so. In my case, the tired old 361 had the 100,000 mile stock single-without-damper springs...... so not much pressure.
[Re: fast68plymouth]
#2591475
12/13/18 08:23 PM
12/13/18 08:23 PM
Posts: 3,076 Michigan
A727Tflite
Wouldn’t weaker valve springs take longer to “pump down” the plunger versus a stronger spring? I would think so. In my case, the tired old 361 had the 100,000 mile stock single-without-damper springs...... so not much pressure. So in my mind ( and you seem to agree a bit ) a weaker spring would take longer to pump the plunger down - and that may be why some engines like Ron’s buddy and your 361 too so long to regain compression. Of course other factors may play in to this - condition of the lifter itself and maybe actual cranking oil pressure, would be a neat experiment.
[Re: lewtot184]
#2592265
12/15/18 12:13 PM
12/15/18 12:13 PM
383man
Balt. Md
the valve spring controls pump-up, not pre-load. reducing pre-load just reduces pump-up distance. Yes but the point here I believe is if you run the lifters with almost no preload even if you over rev the eng the lifters cant pump up enough to hold the valve off its seat. I have seen that a few times over the years on stock type engines. When I worked at a used car dealer I ran a 351 Mustang real hard on a road test and the lifters pumped up enough to hold the valves off the seats and stall the eng. I had to wait a bit before it got comp back. That's why I ran only about .010 preload in my old 383 since I raced it sometimes and used basically the stock valvetrain with Comp single springs. Course to close to no preload and it has more valve train noise. But I understand what you mean also about the spring tension making a difference if you run the normal preload. Ron
[Re: fastmark]
#2592266
12/15/18 12:15 PM
12/15/18 12:15 PM
383man
Balt. Md
Most stock lifters will pump up and hold the valves open at the upper RPM if they have to much preload, setting the preload from .010 to .030 hot will help stop that I keep going over this I’m my brain and I think this is has got to be the case. The higher the rpm, the more they will pump up. The more room they have to pump up, the more like they are to hold open the valves. Basically your right but the stronger valve springs will fight against the lifters pumping up and holding the valves off the seats. Ron
[Re: A727Tflite]
#2592705
12/16/18 12:30 PM
12/16/18 12:30 PM
RapidRobert
Fastmark - how did you determine how much preload you have ? What method did you use ? What I do is: with it mocked up, put a swath of dykem on the pushrod, then slide a thin flat razor blade over sideways from the valve cover flange on the head & make a slight mark in the ink then undo the rocker to let everything raise up till the cup "just" reaches the snap ring then make another razor mark then measure the distance between the (2) "marks" on the pushrod.
[Re: RapidRobert]
#2592733
12/16/18 01:27 PM
12/16/18 01:27 PM
fastmark
Abilene, Texas
Fastmark - how did you determine how much preload you have ? What method did you use ? What I do is: with it mocked up, put a swath of dykem on the pushrod, then slide a thin flat razor blade over sideways from the valve cover flange on the head & make a slight mark in the ink then undo the rocker to let everything raise up till the cup "just" reaches the snap ring then make another razor mark then measure the distance between the (2) "marks" on the pushrod. I’ve done it this way before. I got the same measurements both ways. I fixed the problem yesterday without buying adjustable rockers at he customers request. I settled on .035 to .045 using Shim’s under the stands. It was a royal pain. Way too time consuming just to save the customer money and be a one time fix. I had to use more shims at one end of the drivers side head. Better than .110 to .145 preload though.
[Re: fastmark]
#2592748
12/16/18 01:47 PM
12/16/18 01:47 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
I had to use more shims at one end of the drivers side head. Better than .110 to .145 preload though. That just doesn't sound like a good solution to me Wouldn't that stress the shaft? I wouldn't sign off on that repair Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fastmark]
#2592763
12/16/18 02:14 PM
12/16/18 02:14 PM
fast68plymouth
So. Burlington, Vt.
Aaaaahhh yes........ the old “stand splitters”, er...... I mean shims.
#2592783
12/16/18 02:57 PM
12/16/18 02:57 PM
RapidRobert
I dont have the last word on this but it recollected something about custom shims that someone offered that are thinner on the "sides" to counteract this.
[Re: fastmark]
#2592834
12/16/18 04:25 PM
12/16/18 04:25 PM
fastmark
Abilene, Texas
I gave her the options and she chose the cheapest ones. I don’t like them but that is what she would go for. I used the tapered shims from Hughes.
[Re: fastmark]
#2593091
12/17/18 11:51 AM
12/17/18 11:51 AM
Posts: 4,457 Washington
madscientist
Washington
As Dwayne pointed out, those shims are pedestal breakers. Also, they only half fix the issue. If the shaft needs to go up, it also needs to move away from the valve. Those shims don't do that.
The only good thing was if the heads had a bunch of money in them and it broke a pedestal, the customer was more inclined to fix them the only way I had back then which was to mill the stands off and use offset stands and shafts like should have been done in the first place.
