1970,1971 'Cuda convertible question
#2590199
12/11/18 01:59 AM
12/11/18 01:59 AM
Posts: 1,550 Mattituck NY.
FJ6AAR
Mattituck NY.
Hi, is there anybody out there that owns a 1970 or 1971 'Cuda/Barracuda convertible that can give me a measurement? The measurement needed is the width of the rear Deck Filler panel. As you know, the convertible uses a smaller width piece than a hardtop. I need to modify a hardtop piece and the original piece is no longer available to take measurements from. The places I need measured are in the photo below. Basically, I need the measurements of the three black lines. To be clear, it is only the visual part when the trunk is closed and the center molding is attached. I understand that the two end measurements should be the same. Any help will be greatly appreciated. Thanks. https://ibb.co/12d2dz5
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
Re: 1970,1971 'Cuda convertible question
[Re: 340clone]
#2590540
12/11/18 07:58 PM
12/11/18 07:58 PM
FJ6AAR
Mattituck NY.
Hi, that is a good question. I know a lot of the inner unseen unique convertible pieces are not the same between the two. I'm going to guess it probably isn't. Maybe somebody can chime in who knows for sure?
[Re: FJ6AAR]
#2590628
12/11/18 11:31 PM
12/11/18 11:31 PM
FJ6AAR
Mattituck NY.
Chally426 - thank you..! And thank you 340clone too. Chally426, that is for a 'Cuda/Barracuda, correct? Thank you , Rob
[Re: FJ6AAR]
#2591264
12/13/18 12:50 PM
12/13/18 12:50 PM
FJ6AAR
Mattituck NY.
Thanks Dayclona, I'm aware of Ken. I had a local fabrication shop convert my quarters and they did a fantastic job. They will be making this piece for me as well.
[Re: FJ6AAR]
#2591933
12/14/18 05:04 PM
12/14/18 05:04 PM
Posts: 521 Virginia
larry4406
Virginia
Thanks Dayclona, I'm aware of Ken. I had a local fabrication shop convert my quarters and they did a fantastic job. They will be making this piece for me as well. Any step by step pictures of the conversion process you can share?
[Re: FJ6AAR]
#2592322
12/15/18 02:17 PM
12/15/18 02:17 PM
Posts: 283 Massachussetts
RCKTMN
Massachussetts
Hello FJ6AAR,
Couldn't figure out how to post them, so I sent you an email with some pics off my 1970 Barracuda convertible.
Regards,
Paul
1970 Barracuda Convertible 1970 Newport Convertible 1970 Satellite Convertible 1974 'Cuda shell - '71 conversion 1988 Oldsmobile Cutlass w/455 2003 RAM3500 CTD 2007 Caliber R/T AWD 2007 Magnum SRT-8 2016 Chrysler Town & Country
[Re: FJ6AAR]
#2592395
12/15/18 03:49 PM
12/15/18 03:49 PM
FJ6AAR
Mattituck NY.
Hi Paul, I replied to your email - Thank You, Rob
[Re: larry4406]
#2592401
12/15/18 04:01 PM
12/15/18 04:01 PM
FJ6AAR
Mattituck NY.
Larry, you have a PM. Rob
