Re: Starting mockups for a 572 build... ugly pictures
[Re: ZIPPY]
#2592695
12/16/18 12:05 PM
12/16/18 12:05 PM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
Hi Doug, Yes sir I have encountered that before after first start up with others. They hold quite a bit that can't be easily drained.
May not need to mark the stick as the style I decided on traditionally reads 1 qt overfilled with 7 quarts in it...but will test and find out. Marking the stick and all is part of the plan if needed + I'm going to make provisions for a sight tube so I can get a visual of the oil level at higher rpm.
Rich H.
Esse Quam Videri
[Re: astjp2]
#2592795
12/16/18 03:11 PM
12/16/18 03:11 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
Here are some more but I cant seem to attach them I'm assuming these pictures are with the valve fully closed, correct? If so are you concerned on the contact of the rocker arm pad on the inner edge of the lash caps? I am Hemiroid motors
[Re: ZIPPY]
#2593148
12/17/18 02:24 PM
12/17/18 02:24 PM
ZIPPY
S.E. Michigan
Pics seem hard to post for so many. From email and for info purposes, here's a shot of Ron's 572 showing the pan that was swapped on, right after the high rpm oil pressure issues were found with the reproduction street hemi pan. I really like the shallow depth/ground clearance of this one.
For the time being I'm going to try to avoid centerlink pass-through and external lines, but it's good to know what works and it's all there if I need it later.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2593853
12/18/18 04:43 PM
12/18/18 04:43 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
I like the hard line made idea from the pump to the pan. I should have done something like that on mine. Between the -12 180 degree fitting I used & the -20 An fittings I used on my water pump & radiator it made for some tight clearances.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: DoubleD]
#2593977
12/18/18 09:57 PM
12/18/18 09:57 PM
Posts: 9,826 MI, usa
dvw
MI, usa
Doug - I am guessing based on the drawing your engine is moved back about 1.5 inches?? Motor placement was years ago. As I remember it is up about 3/4" and back about 1". Doug
[Re: ZIPPY]
#2596349
12/24/18 04:40 PM
12/24/18 04:40 PM
ZIPPY
S.E. Michigan
Oiling again.... blacksmith skills required but I was prepared. Side of the pan interfered with both the pickup and the stick, had to heat and provide clearance here and there. Pickup location is different because of the different block. Ordered a couple windage trays from 440 s@urce to try, and after checking them out believe I will probably modify a traditional style tray slightly to fit.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2596354
12/24/18 04:43 PM
12/24/18 04:43 PM
ZIPPY
S.E. Michigan
Being header-equipped I didn't see the point in a fancy stick, so I made do. Research brings up numerous threads here how this simple part seems to frustrate folks.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2596361
12/24/18 04:57 PM
12/24/18 04:57 PM
ZIPPY
S.E. Michigan
An early present showed up, the Crane 420 circle track roller I was asking about on another thread. It's from B@rton's stash sold through a 3rd party. It checked out perfectly.
Don't make fun of my little degree wheel lol. I had a larger one but I loaned it out, and it never came back (thanks alot, Roy). Smaller wheel is harder to read. It works fine but it's best to triple check. Crane lifter (sitting on top) won't work...tie bars hits the block on the base circle. Comp 829 fits fine and will probably get the nod.
Intake centerline came out to 110, Crane calls for 107 on this grind With 572ci I'm not sure I need to worry about advancing the cam. Considering trying it as is. Any input?
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2599055
12/31/18 01:52 AM
12/31/18 01:52 AM
ZIPPY
S.E. Michigan
The pictures are still ugly so this should fit right in. CC'd piston tops for 1" down.
You know, it's not just measuring dome volume because there's more going on than that. These pistons have a 73cc dome but with 13cc of dead space around the edges (below the deck) + the valve reliefs, they're effectively the same as a flat at zero + 60cc dome...that's how I like to figure it anyway but my mind is pretty warped.
Dont have any finished heads ready to go but checked a beat/repairable one to ballpark it. Looks like it'll be 10.25:1 with a .040 gasket. Need to Clay piston-to-head to confirm no hemi problems.
ML are the same as CC's....For anyone wanting to do this, you need a drill, a chunk of plexiglass, a 100ml syringe from eBay, some grease and some water. It's not lab quality but will get you within 2 CC's which is plenty accurate enough for anything I'll ever do.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2599056
12/31/18 02:11 AM
12/31/18 02:11 AM
ZIPPY
S.E. Michigan
Cam is degreed in and corrected. I misspoke earlier, Crane calls for 107 intake centerline and that's what I went with. It's 112 straight up on both intake and exhaust, so it's confirmed 112 LSA and installed 5 degrees advanced. I've never run 112 LSA in anything "hot", but it's getting up there at .050 so maybe that will make it slightly more street friendly.
Change of heart on the oil pickup. I'm going to run single line static in this deep pan, so I took this pic to stare at and imagine the line routing. After all the dinking around with the internal pickup I just didn't like how thin I had to make it,to clear the rod. "What if it cracks and sucks air?". It also had very little purchase into the adapter threads as well, maybe 3 threads at the most....just didn't like it.
Now with the deep pan more or less locked in, the "stroker" windage tray actually makes sense, so I'll give it a try.
Chip's considerable influence had me looking closely at the 440 source aluminum pan, but I only have steel welding capability right now and will need to change the pan somewhat, so I went with steel.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2599188
12/31/18 01:42 PM
12/31/18 01:42 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Cam looks to be of the vintage when they(Crane) were still manufacturing billet cores.
My experience has been that the Crane cores were fairly friendly with regards to wearing out the bronze distributor gears.
