Which electric water pump ?
#2589743
12/10/18 09:54 AM
12/10/18 09:54 AM
Posts: 247 Brisbane Australia
crash520
Brisbane Australia
Hi guys, have a SB stroked, lower half of the block is grouted, closed chamber W2 race heads, 11.25 CR, solid roller cam, it’s mostly street driven but also 1/4 mile ground pounding, I have a PRW mechanical pump but would also like the option of running an electric pump, so, should I get a Moroso or a Meziere pump, which one fella’s???
Re: Which electric water pump ?
[Re: crash520]
#2589754
12/10/18 11:09 AM
12/10/18 11:09 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I have had great luck with Meziere, I have run it for around 20 years with lots of street miles. I did have an issue with it a few years ago and they repaired it quickly and for a fair price.
If you have the room I would get the higher flow pump, I have the 35GPM and I think the higher flow pump would cool better on the highway. I don't have cooling problems really but my highway situation could be better.
68 Barracuda Formula S 340
[Re: MR_P_BODY]
#2589921
12/10/18 05:21 PM
12/10/18 05:21 PM
crash520
Brisbane Australia
Make sure you get a 45 gal pump and oil cooler.. I like the Meziere pump Mr P, my set up is in an E Body, remote filter etc, do you have a preferred/ recommended/suggested oil cooler, brand type size maybe? I have an oily temp sender set up in the pan. I could place the cooler in front of the right front wheel inside the fender (not preferred due to potential damage from tire pickup etc) the only other place would be lower front balance however I think that would limit me to a cooler only without fan, thoughts anyone?
[Re: crash520]
#2589937
12/10/18 05:44 PM
12/10/18 05:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Make sure you get a 45 gal pump and oil cooler.. I like the Meziere pump Mr P, my set up is in an E Body, remote filter etc, do you have a preferred/ recommended/suggested oil cooler, brand type size maybe? I have an oily temp sender set up in the pan. I could place the cooler in front of the right front wheel inside the fender (not preferred due to potential damage from tire pickup etc) the only other place would be lower front balance however I think that would limit me to a cooler only without fan, thoughts anyone? You can look at Summit or Jegs to find a cooler but you want to look at 1/2" in and out.. you want flow.. B&M makes a nice cooler.. I run one from the filter using a remote then to the cooler
[Re: crash520]
#2590129
12/10/18 11:33 PM
12/10/18 11:33 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
I'm using an oil cooler like this, and it works awesome. It's easier to plumb water lines than oil lines. And it's light. cooler
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Moparteacher]
#2590290
12/11/18 11:21 AM
12/11/18 11:21 AM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I have CSR reverse flow. Never again. May sell this one and take the hit. PITA. Doesn't purge air. Tried every trick I know. Raised the front end 3 feet in the air, pulled a vacuum on the system to maximize fill. Damn near lost a new engine due to cavitation. I finally installed a zerk fitting next to the pump motor, on top, to bleed air from the vane cavity. Works, buts makes a mess.
I also installed hollow bolts in the cylinder heads on the intake face LF and RR. Drilled through the bottom of the bolt hole into the coolant passage to bleed air from being trapped in the cylinder heads. Crazy how much air was trapped even after I got the coolant flowing. Makes an even bigger mess when bleeding.
CSR makes a quality product, or so it seams, but the reverse flow pump has issues....FWIW Buy this and it will fill and remove air at the same time. Works great. https://www.tooldiscounter.com/ItemDispl...ASABEgKgSfD_BwE
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: crash520]
#2590400
12/11/18 02:59 PM
12/11/18 02:59 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
I have had several of the Moroso units. The older ones didnt pump a ton of water and were admittedly marginal for street use. That said, the new ones( been out 4 or 5 years now) pump WAY more water and work fine on the street. I like how they look, and how they come ready to bolt up to the stock location as opposed to others needing extra plates, etc. Like anything, the cooling system involves more than just the water pump. Having a good fan and other components are important too. Both the older style Moroso and this newer one have given me zero issues failure wise in the probably 20 ish years i have now run them. I wont run anything else. They new ones are great, cool excellent, little cheaper, good looking, and super reliable. Anybody thst has the newer one i am sure would agree. Nice piece
