Dana 60 Ford disc brake swap questions
#2589294
12/09/18 12:14 PM
12/09/18 12:14 PM
Posts: 4,452 Michigan
MarkZ
Worthy
Worthy
Sorry if this is rehashing old information. I poked around with the search function and found some stuff, but not everything I need. I have a D60 at the axle shop now getting prepped and it's going to get disc brakes. The shop quoted a price of $475 for a kit; which doesn't seem bad at all, but I think I could get by significantly cheaper if I source the parts myself going with the Ford Explorer rear disc swap. There is a large self service junk yard near by, so getting the brackets should not be an issue. Rotors and calipers would be purchased brand new from a parts store. Would there be much savings doing this myself, or should I just get the kit? If I do decide to source the parts myself, what year Explorers should I be looking at for caliper brackets? I found this photo linked in another thread here: These the brackets I should be looking for? Thanks again.
Re: Dana 60 Ford disc brake swap questions
[Re: MarkZ]
#2589320
12/09/18 01:30 PM
12/09/18 01:30 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
Call your parts store and price it out... then call the salvage yard and price it out... then figure what your time is worth and ...you guessed it price it out. Let us know what you came up with.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: MarkZ]
#2589350
12/09/18 02:18 PM
12/09/18 02:18 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Used to be a time FMS sold the Explorer rear disc kit all new for less than that quote. Doesn't seem to be so anymore, but that $475 quote is cheaper than any Explorer kit I can find these days.
[Re: DoctorDiff]
#2589429
12/09/18 04:21 PM
12/09/18 04:21 PM
Supercuda
About to go away
About to go away
up yours
I sell NEW Explorer rear disc brake kits for $395. there you go, I knew I saw that kit somewhere
[Re: DoctorDiff]
#2589462
12/09/18 05:06 PM
12/09/18 05:06 PM
Posts: 31,078 Oregon
AndyF
I sell NEW Explorer rear disc brake kits for $395. I thought you did but I couldn't find them on your website so figured they had gone away.
[Re: MarkZ]
#2589473
12/09/18 05:36 PM
12/09/18 05:36 PM
MarkZ
Worthy
Worthy
I looked at your store before and didn't see the kit either. You also sell the Ford housing ends? Probably just make things a whole lot easier going through you and that is a good price. I'll call you Monday.
[Re: MarkZ]
#2589718
12/10/18 03:02 AM
12/10/18 03:02 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I did the kit from Teraflex, uses explored rotors, calipers, etc.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: MarkZ]
#2596214
12/24/18 12:04 PM
12/24/18 12:04 PM
MarkZ
Worthy
Worthy
Got everything from Dr Diff to rebuild my 60 and also got the Explorer disc brake kit. The brake kit was only $390 and sure beats going junkyard shopping in the dead of winter. Honestly, even if this were summer I'd still go this route. The shop has everything now and I should pick the completed axle up a couple weeks after the new year. Thanks again Cass...
[Re: AndyF]
#2596399
12/24/18 06:14 PM
12/24/18 06:14 PM
MarkZ
Worthy
Worthy
You need a big piston up front to work with the Explorer caliper out back. Are you using the factory calipers up front? If you have room for a 11.75 rotor (15 inch wheel) you might want to upgrade the front rotors. All you should need would be the bigger rotors and the taller caliper brackets. You shouldn't even need to bleed the brakes, just lift the calipers off and change the rotors and brackets and drop them back on. I figured I would need to change the master and distribution block. The car has 18" wheels that I bought in that size specifically for upgrading the factory front disc to a 13" rotor. I do have the 11.75" brackets though. I may just do that and see how it works for now since the budget is shot already. Trouble is I don't want to change the master twice if I decide to go 13" brakes up front later. Eh, I'll figure it out in the Spring. ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: MarkZ]
#2596893
12/25/18 07:41 PM
12/25/18 07:41 PM
MarkZ
Worthy
Worthy
I didn't realize going manual was an option. Would be nice being able to toss the booster. I was planning on Cass's 13" Cobra kit, but the Viper kit the two of you are putting together looks real nice too.
Do you think I would be able to run with the factory calipers up front for the season with a master cylinder that would be compatible with one of those two options?
Thanks again.
[Re: MarkZ]
#2596934
12/25/18 10:14 PM
12/25/18 10:14 PM
AndyF
You could run a manual setup with the factory calipers and 11.75 rotors up front. It would stop but you might need to put more effort into it than you're used to. Once you changeover to the 13 inch rotors the effort would drop a bit.
I run manual brakes on my Coronet with 13 inch rotors up front. It stops really well and that car is 4000 lbs. So if you car is less than 4000 lbs you should be fine with manual brakes.
