If I'm remembering correctly the numbers on all Holley jets are flow numbers, not the inside diameter
I had a chart that showed several of the upper 70s jets, 75,76,77 maybe, that had the same I.D. but different tapers on the fuel outlet sides of those jets which changed the flow number results
As far as jetting I do most of my tuning in two jet numbers up at first until the car slows down and then down one jet size at a time until it slows down again in the 1/4 mile MPH while watching the spark plugs for color and spotting on the insulator
