Re: 70 Cuda 440. Help with hacked (spliced) ignition wiring.
[Re: David1971]
#2586308
12/02/18 09:16 PM
12/02/18 09:16 PM
Posts: 2,386 White Plains, NY
VCODE
White Plains, NY
You are correct. The wire coming out of the distributor goes to the neg on the coil. If the b wire is gray then it would be tach going to neg coil. Hope this helps. You may want to replace with a M&H wire harness those wire are 45 year old Hope this helps Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: David1971]
#2586544
12/03/18 12:47 PM
12/03/18 12:47 PM
Posts: 12,244 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
That 'B' lead appears to be shot. It is brittle and the splice is close enough to the bundle so that the bundle will need to be opened. The coil wire terminals are unique. You will probably either need to buy a new harness assembly or, as I do, try to find an old Dodge car or truck in a self service salvage yard and get the wiring harness from it and splice the last foot or two from it on your harness and re-wrap it. You can get the tape that doesn't have the glue on it on Ebay.
Master, again and still
[Re: David1971]
#2587065
12/04/18 03:50 PM
12/04/18 03:50 PM
VCODE
White Plains, NY
Also Jamie at Mega Parts can sell you M&H harnesses. Better service and cheaper shipping. Check him out first. Bob
