Re: How sensitive is the air-fuel ratio to fuel level changes?
[Re: BradH]
#2586710
12/03/18 06:53 PM
12/03/18 06:53 PM
fast68plymouth
So. Burlington, Vt.
My experience has been, unless the floats are just “too low” or “too high” for proper carb function, it is usually more of a “fine tune” to the fuel curve on the dyno. However, I’ve seen it where the best power came from a float position that just didn’t work out well with the motor in the vehicle.
[Re: BradH]
#2586813
12/03/18 11:02 PM
12/03/18 11:02 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Not quite an apples to apples comparison, but when we made the switch here to e10, a lot of small engines had lean issues. Raising the float levels has an effect on the emulsion tubes, so a quick tweek to the float level would(and still does) make them run nicer. I would imagine the same effect would apply to a Holley.
[Re: BradH]
#2586862
12/04/18 01:18 AM
12/04/18 01:18 AM
Posts: 4,213 New York
polyspheric
New York
Or when the G force acts on it and the gas tries to climb the back wall.
Boffin Emeritus
