505" stroker carb recommendations
#2586356
12/02/18 10:35 PM
12/02/18 10:35 PM
Posts: 2,107 Third Stone from the Sun
Scotts72Rallye
Hey guy's looking for carb recommendations for my 72' Challenger. It's got a 71' 440 block bored 30 over, stroked(4.25) out to 505", redline about 6,500 rpm, 440 EZ-1 Indy Aluminum Heads, Max Wedge Intake, mechanical fuel pump, full reverse manual valve body 727 trans, Dana 60 with 355 gears, TTI headers going into a full 3" exhaust. Car will be street driven with very little trips to the track planned. Holley tech recommended a 850 Street HP (link below). What would you run???? Holley link: https://www.holley.com/products/fuel_systems/carburetors/hp/street_hp/parts/0-82851SA
1972 Dodge Challenger Rallye UNDER CONSTRUCTION
Re: 505" stroker carb recommendations
[Re: Scotts72Rallye]
#2586359
12/02/18 10:45 PM
12/02/18 10:45 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
I like that choice of carburetor too
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
#2586420
12/03/18 01:06 AM
12/03/18 01:06 AM
Posts: 2,523 God's Country Maryland
GODSCOUNTRY340
Okay, you're running high flowing heads, high flowing intake, high flowing exhaust, 505 cubes. Why restrict everything with that 850 carb? I'd be looking for a 1050 Holley for that beast or that 3916 three barrel as stated above.
#2586424
12/03/18 01:15 AM
12/03/18 01:15 AM
BradH
Car will be street driven with very little trips to the track planned. Cam? Converter stall? Sounds to me like the emphasis should be on drivability, not peak HP potential.
[Re: BradH]
#2586426
12/03/18 01:24 AM
12/03/18 01:24 AM
Posts: 4,687 Wichita
GY3
Wichita
I have almost the identical combo and run a Demon 850 Speed Demon.
Most people initially think the car has some sort of fuel injection because it starts instantly, never loads up in traffic and puts up good numbers.
I could not be happier with a carb and used to run all Holleys.
#2586533
12/03/18 12:25 PM
12/03/18 12:25 PM
Posts: 12,158 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
In my experience, an 850 would be a cork in that combo. My 500 was a bit milder than your combo and I started with an 850. Tried a 950 and went faster. Tried a 1050 Dominator and went faster still.
I also have a 1050 on my 540 Hemi. Both combos were primarily street.
Thumper can put a 1050 together for you that will rival any self tuning throttle body EFI. And certainly will start, run, and drive better than any OOTB carb, whether it is a 4150 or 4500 platform.
A Thumper carb will cost more than a generic carb, but a lot less than an EFI set-up and with fewer mods to the rest of the fuel system.
Master, again and still
[Re: DaveRS23]
#2586537
12/03/18 12:37 PM
12/03/18 12:37 PM
GY3
Wichita
Did you use an adapter or change intakes when you went from 4150 to 4500?
[Re: GODSCOUNTRY340]
#2586558
12/03/18 01:15 PM
12/03/18 01:15 PM
Posts: 31,050 Oregon
AndyF
Okay, you're running high flowing heads, high flowing intake, high flowing exhaust, 505 cubes. Why restrict everything with that 850 carb? I'd be looking for a 1050 Holley for that beast or that 3916 three barrel as stated above. Really? You're suggesting the guy put a Dominator carb on a street car? That seems like a bad idea, the guy clearly isn't building a race car and he doesn't have a 4500 intake.
[Re: GY3]
#2586560
12/03/18 01:16 PM
12/03/18 01:16 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Lack of hood clearance has kept me from trying an adapter. I have used Dominator flanged intakes and I have modified 4150 intakes to accept the 4500.
The 4500 mod is simple. Just thread aluminum bolts into the original bolt holes. Cut them flush and then drill and tap the new bolt holes. A little plenum massage is all that is left to do.
[Re: DaveRS23]
#2586563
12/03/18 01:17 PM
12/03/18 01:17 PM
AndyF
The 4500 mod is simple. Just thread aluminum bolts into the original bolt holes. Cut them flush and then drill and tap the new bolt holes. A little plenum massage is all that is left to do. This isn't the race forum, why are you guys trying to turn everything into a race car?
[Re: AndyF]
#2586575
12/03/18 01:33 PM
12/03/18 01:33 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Okay, you're running high flowing heads, high flowing intake, high flowing exhaust, 505 cubes. Why restrict everything with that 850 carb? I'd be looking for a 1050 Holley for that beast or that 3916 three barrel as stated above. Really? You're suggesting the guy put a Dominator carb on a street car? That seems like a bad idea, the guy clearly isn't building a race car and he doesn't have a 4500 intake. BAD IDEA?!?!?!? Have you read any of the posts on here and elsewhere from happy Thumper customers? Many, many happy street cars running his Dominators. Including mine. Why don't you try one Andy, and see for yourself? The OP's combo is not particularly mild. He will run out of carb long before his anticipated 6,500RPM peak with a 4150. Why have what he has under the carb and then plug it up with too small a carb?
#2586611
12/03/18 02:48 PM
12/03/18 02:48 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
See my thinking is that if you build a big block Stroker engine you want it to run great or why not just build a stock stroke engine to cruise around. Would an 850 work, heck ya but so would a 750. As far as fuel injection man have I heard some nightmare tuning stories getting them set up right. We all can’t afford taking to to someone’s dyno and paying them to set it up for us only to have it run different in the car.
