Re: molnar cranks [Re: BradH] #2584173
11/28/18 02:37 PM
11/28/18 02:37 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Originally Posted By BradH
Any truth to some comments I've heard that K1's QC has gone down since Tom Molnar sold it and started his new company?
I don't have both pre and post Tom-departure parts to compare.
However I haven't found any issues with the K1 I picked up recently.
I will admit the only reason I chose it is because it was $150 less than the Molnar, which I'll gladly put towards some other small aspect of the build. If I needed another one today, I would purchase it again without a second thought.
I'm using it with Tom's connecting rods, so I do have some faith in his products, both past and current.
Personally I don't think you could go wrong with either one.
Rich H.
Esse Quam Videri
Re: molnar cranks [Re: mopar dave] #2584179
11/28/18 02:47 PM
11/28/18 02:47 PM
AndyF Offline
AndyF  Offline
I like Molnar cranks and rods. I used both in my last low deck 470 engine. That engine made 750 hp on the dyno and everything ran smooth as silk. Rear main seal was dry as a bone which is important too.
Re: molnar cranks [Re: racerx] #2584229
11/28/18 04:03 PM
11/28/18 04:03 PM
NY
challenger451ci Offline
NY
Originally Posted By racerx
Originally Posted By jyrki
I have used them in boosted application. Zero problems with the crank. Calculated 1660hp.
Thaxs this what I wanting to hear. up
Well then....I guess it's time to step up the fogger jets! Zero issues with my low deck 4.15" Molnar crank. Just a small shot of spray....for now.
Re: molnar cranks [Re: challenger451ci] #2584269
11/28/18 05:19 PM
11/28/18 05:19 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Same thoughts here. My biggest concern is the factory block now. shake_head
'63 Dodge 330
11.19 @ 121 mph
Re: molnar cranks [Re: mopar dave] #2584434
11/28/18 10:57 PM
11/28/18 10:57 PM
Superfreak
Superfreak
I was just emailing them again and they said they do not have any center counterweighted cranks. They would be willing to make not one but min five from billet and just stated they would be very expensive.
Re: molnar cranks [Re: STEFF] #2584477
11/29/18 01:05 AM
11/29/18 01:05 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Originally Posted By STEFF
Tom Molnar started/owned K1. He then sold it to Carrillo, and started Molnar Technologies.
I thought it was Weisco...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: molnar cranks [Re: astjp2] #2584600
11/29/18 11:18 AM
11/29/18 11:18 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
It is...
5.53 @ 125 1/8th on the launch control..more left in her!
Re: molnar cranks [Re: Eric] #2584725
11/29/18 03:36 PM
11/29/18 03:36 PM
dogdays Offline
dogdays  Offline
W I S E C O is how you spell it. If you're wise.
ANY forged crank that costs less than $1000 got its start in China. I thought it was common knowledge by now.
Most, if not all, of the cast aftermarket cranks were poured in China.
Why China? Because most Americans won't work in a hot, dirty, dangerous place like a foundry. You have to pay them extra. Then, you have the EPA regulating what they can waste into the air and water. Ever wonder why getting new blocks is so difficult? Ever wonder why American foundries are overbooked? They are a dying breed, even as demand stays the same or goes up.
R.
Re: molnar cranks [Re: dogdays] #2584774
11/29/18 05:01 PM
11/29/18 05:01 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
R.
Boy you hit that on the nail head.
Even in the steel mills are hands were tied. As a Millwright we used to melt and pour our own lead and babbit bearings for or 30-36 inch shaft rolling mills. We poured our molds and sent them to our in house machine shop to machine after they cold down. We would then get them back to our shop and frost them (hand scrape) then stack them for measuring. We had to outsource them in the late 1990's because we weren't allowed the melt the lead and babbit in our Millwright shop. Quality went down big-time after that.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: molnar cranks [Re: mopar dave] #2584777
11/29/18 05:13 PM
11/29/18 05:13 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I thought molnar and k1(wiseco) were made at the same place by the same company. The molnar box in the pic above looks exactly like a k1 rod box I have... just doesn't say molnar.
Edit: boxes aren't the same, was thinking of another set of rods I had.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: molnar cranks [Re: mopar dave] #2584787
11/29/18 05:36 PM
11/29/18 05:36 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I recently ordered K1 crank and Molnar rods at the same time.
The crank drop shipped from Wiseco in Ohio, the rods shipped from Molnar in Michigan.
I have very limited knowledge of the performance business these days but feel it's probably pretty safe to assume these two companies are closely related, and there is a good chance they share some intelligence.
Rich H.
Esse Quam Videri
Re: molnar cranks [Re: mopar dave] #2585066
11/30/18 09:54 AM
11/30/18 09:54 AM
ma.
roadrunner34 Offline
ma.
Currently building a 540 for a blown application. When I called molnar they said the crank could handle it. Machine shop checked it-everything good.I'm having a second keyway cut into it. The indy block on the other hand.....
Re: molnar cranks [Re: mopar dave] #2585439
11/30/18 11:36 PM
11/30/18 11:36 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thaxs for that info. I'm going to ask my motor builder about these cranks and see what he thinks. I'm getting good reviews on this up
Re: molnar cranks [Re: mopar dave] #2585587
12/01/18 11:51 AM
12/01/18 11:51 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I just received my Molnar Crank yesterday and I only unpacked for a quick glance it looks awesome
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: molnar cranks [Re: racerx] #2585591
12/01/18 11:57 AM
12/01/18 11:57 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Why not call Tom himself? He'll ask you about your combo and give an honest answer. I'm sure he knows way more about cranks than all of us and most engine builders.
Doug
Re: molnar cranks [Re: dvw] #2585599
12/01/18 12:12 PM
12/01/18 12:12 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Why not call Ton himself? He'll ask you about your combo and give an honest answer. I'm sure he knows way more about cranks than all of us and most engine builders.
Doug
iagree that will be the call to make up but just like to get an opinion from a respectable well known engine builder here ………….
