Re: Is MSD the best??
[Re: fast68plymouth]
#2583514
11/27/18 01:23 AM
11/27/18 01:23 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Uuummm....... the engine is going 27% faster than the driveshaft? Where in the run was that happening?
Not the finish line I hope. I never programmed the DS sensor,that was at the shift.
[Re: Dave Hall]
#2583700
11/27/18 03:12 PM
11/27/18 03:12 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
With the HVC-II coil #8261, MSD recommends a .020 plug gap. Guys running boost and high amp mags run .010 or less. This is the first time I saw this. I had that coil and it melted the tip off the rotor. I was running .040 gap. Makes sense why it would burn up the cap & rotor now, but I bet the phasing being so far off didn't help either.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
