Dodge Demon 572
#2582065
11/23/18 07:23 PM
11/23/18 07:23 PM
Posts: 195 Italy
Raffaplymouth60
Italy
Hi ! This is my New Race Car ... Bought in Sweden this Rolling Chassis and im qorking for install a 572 that was installed in my 9 sec Cuda Some Soecs : weight 2700 Lb with driver and 572 the last engine was megablock 572 ET with 300 Shot 7.5@183 Powerglide with Mopar Bell ( no shifting solenoid ) Dana 60 4 link 45 spline 4.10 7 AL digital Nitrous Fogger gif hostimage sharing
1970 Cuda 496 street driven 9.22@150 1971 Demon 572 7.82@176 1957 Desoto Adventurer Convertible 345 Hemi 1958 Plymouth Fury Christine 2008 Dodge Ram 1500 Hemi 1970 Dodge ChallengerRT 6pack 4 speed 1 of 135 1968 Dodge Charger RT 4 speed
Re: Dodge Demon 572
[Re: Raffaplymouth60]
#2582117
11/23/18 10:11 PM
11/23/18 10:11 PM
Posts: 43,263 Bend,OR USA
Cab_Burge
Be careful with that oil system, me no likey Is the motor in the pictures the one your going to race? If so think about a better, bigger capacity oil pan and oiling system with less 90 degree fittings in it This car is similar in weight to my S/P Cuda but yours is a lot faster I think the A body are a better car to drag race also How hard is it (regulations wise) to get that car from Sweden to home ?
Re: Dodge Demon 572
[Re: hemi-itis]
#2582550
11/24/18 08:21 PM
11/24/18 08:21 PM
Posts: 195 Italy
Raffaplymouth60
Italy
I think it great that you finally have a dragstrip!! How far away are you from the track? around 70 miles from my City.... only 3 race at year in Italy...
Re: Dodge Demon 572
[Re: Cab_Burge]
#2582555
11/24/18 08:24 PM
11/24/18 08:24 PM
Posts: 195 Italy
Raffaplymouth60
Italy
Be careful with that oil system, me no likey Is the motor in the pictures the one your going to race? If so think about a better, bigger capacity oil pan and oiling system with less 90 degree fittings in it This car is similar in weight to my S/P Cuda but yours is a lot faster I think the A body are a better car to drag race also How hard is it (regulations wise) to get that car from Sweden to home ? hello ! yes in my Cuda oilimg was ok for 9.2 sec ... i have ordered 9qt milodon flat pan ... i will receive in a week ...this car in Sweden have made 7.5@183 mph with same 572 but in Aluminium..no problem for shipping car from sweden to Italy
Re: Dodge Demon 572
#2582647
11/24/18 11:58 PM
11/24/18 11:58 PM
Cab_Burge
I'm glad there was no problems on the shipping and customs bringing it into Italy On the oil system and going to a flat oil pan maybe it is time for a 3 quart Accusump to be use on the shut down to avoid loosing oil pressure I would try the new pan first and watch to see if it looses oil pressure on the shut down If it does address that I've heard a lot of guys with the funny car, dragster style flat oil pans loose oil pressure after the 1/4 mile during the shutdown
Re: Dodge Demon 572
#2582853
11/25/18 03:58 PM
11/25/18 03:58 PM
Posts: 452 Monrovia, So-Cal, USA
racerhog
Raffa.... That is a nice ride.... Should really Fly !!!! Hope to hear tat they get more races going at some point. You are your guys are a great inspiration over in Italy...
Again... Very Nice Race Car.... I'm happy for you !!!!! Cheers
Bob(Cowboy)Hogan Monrovia So-Cal
Re: Dodge Demon 572
#2592882
12/16/18 06:23 PM
12/16/18 06:23 PM
Posts: 195 Italy
Raffaplymouth60
Italy
someone have installed this adapter for Powerlide to RB mopar ? i have problem... converter end play is zero ... my mid plate is .150 can depend from this ? otherwise need a spacer from transmission to mid plate ( firewall)
