‘92 D-150
#2580050
11/19/18 12:15 AM
11/19/18 12:15 AM
Posts: 1,286 IN
GTX4spd
IN
I have a ‘92 D-150 with a 318. It cranks, but sometimes won’t start, sometimes starts but only runs a few minutes then instantly dies. I tested the coil, cold, seemed within specs. Checked for fuel at the rail, has pressure part of the time, seemingly none others. Replaced the fuel pump relay, still the same problem. I replaced the fuel pump last year so it would seem unlikely that it would be bad, but am seeking advice on whatever anyone else may suggest before I go through the hassle of getting to the pump again. Does the pump seem likely, or am I missing something? Forgot to add that when the truck does run, it will sometimes slightly surge a few times before it dies. Thanks.
"Gentlemen, we must all hang together, or surely, we shall all hang seperately."--Benjamin Franklin
www.wwnboa.org if you're interested in '62-'74 B-Bodies
Re: ‘92 D-150
[Re: GTX4spd]
#2580052
11/19/18 12:33 AM
11/19/18 12:33 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Run the codes, what do they say?
Re: ‘92 D-150
[Re: Supercuda]
#2580056
11/19/18 12:52 AM
11/19/18 12:52 AM
Posts: 1,286 IN
GTX4spd
IN
On a ‘92? Don’t recall seeing a port for a scanner.
Re: ‘92 D-150
[Re: iapco103]
#2580121
11/19/18 10:49 AM
11/19/18 10:49 AM
Posts: 1,286 IN
GTX4spd
IN
Thanks for the tip. I didn’t think OBD went that far back.
Re: ‘92 D-150
[Re: GTX4spd]
#2580981
11/21/18 10:17 AM
11/21/18 10:17 AM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
I wouldn't rule out the fuel pump. I had an '88, had a new pump put on, and it crapped out in a few months.
1981 Dodge D150 360 auto
Re: ‘92 D-150
[Re: GTX4spd]
#2580986
11/21/18 10:32 AM
11/21/18 10:32 AM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
You know those have a frame rail mounted fuel filter don't you? Neglect that and that pump may be bad again.
