Re: Max Wedge Block?
[Re: GY3]
#2579995
11/18/18 10:22 PM
11/18/18 10:22 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
It's NOT a Max Wedge block. Wrong "Font" engine stampings, on the id pad. Just a standard 413 hp engine block, nothing special about it.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: MadMopars]
#2580000
11/18/18 10:32 PM
11/18/18 10:32 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
41 - 413 S - 1962
That's the correct casting number though it's not unique to the MW engine and my info says the block was only notched on the exhaust side.
As for the HP stamp (low compression version), it's either got that or the HPHC (high compression version) stamp as well. With the fonts being different, looks like it could be one.
[Re: 70HemiGTX]
#2580002
11/18/18 10:41 PM
11/18/18 10:41 PM
Posts: 1,292 Tucson AZ,
MadMopars
Tucson AZ,
It should have the casting "AAQA" on the driver's side front. "Google" Max Wedge block pictures. It does. I have not pulled the heads yet though. Thoughts?
[Re: Supercuda]
#2580051
11/19/18 12:32 AM
11/19/18 12:32 AM
Posts: 4,678 Wichita
GY3
Wichita
41 - 413 S - 1962
As for the HP stamp (low compression version), it's either got that or the HPHC (high compression version) stamp as well. With the fonts being different, looks like it could be one. Yes, notches only on exhaust side of the bores.
[Re: MadMopars]
#2580530
11/20/18 08:23 AM
11/20/18 08:23 AM
Posts: 3,076 Michigan
A727Tflite
Looks like you scored a nice set of rockers and pushrods in the deal too.
When you work on the engine check the passenger side rocker shaft - rear - in your picture it looks like the soft plug might be missing. There is a black spot that looks like the bolt hole is visible.
Should be one in each end of each shaft. Could also be that the builder hammered them in past the bolt hole too.
[Re: MadMopars]
#2580668
11/20/18 04:04 PM
11/20/18 04:04 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
What diameter are the exhaust valves? What about head casting numbers? All the Chrysler 300 motors before 1962 had solid lifters and those type adjustable rocker arms. All the letter series 300 motors had them until 1964 also I think the 1964 300 letter cars used the six bolt valve covers and the later style rocker arm pedestals cast into the heads also You may have gotten very lucky
[Re: Cab_Burge]
#2580713
11/20/18 05:56 PM
11/20/18 05:56 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
All the Chrysler 300 motors before 1962 had solid lifters and those type adjustable rocker arms. No they did not. 1960 and 1961 standard 375 horsepower engines had stamped rocker arms and hydraulic lifters. The optional engines had solids.
[Re: NANKET]
#2580830
11/20/18 10:57 PM
11/20/18 10:57 PM
Cab_Burge
All the Chrysler 300 motors before 1962 had solid lifters and those type adjustable rocker arms. No they did not. 1960 and 1961 standard 375 horsepower engines had stamped rocker arms and hydraulic lifters. The optional engines had solids. I've never seen or heard of any Chrysler 300 Letter cars made before 1962 that didn't come standard with 2x4 barrels carbs and solid lifters, 375 HP or not Mopar decided to add the non letter 300 cars in 1962 including 4 door hardtops with 383 motors
[Re: MadMopars]
#2580963
11/21/18 04:37 AM
11/21/18 04:37 AM
NANKET
northwest USA
You never heard of it? OK so that makes it so? "Every human is wrong sometimes" just caught up with cab. Well look it up, ok I did that for you, read this. Or just read the factory service manual. 375 horse had hydraulic lifters, optional engine shad solid lifters. It's true, and it's OK. https://www.allpar.com/cars/chrysler/300C/300F.html
