Page 2 of 3 1 2 3
Re: sway bars, worth it? [Re: Magnum] #2578595
11/15/18 12:48 AM
11/15/18 12:48 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
A ford, or chevy, that's what.
Re: sway bars, worth it? [Re: RapidRobert] #2578606
11/15/18 01:27 AM
11/15/18 01:27 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
RR ... On a daily driver aBsOlUtLy ! .. Drag car ? Not
Re: sway bars, worth it? [Re: AndyF] #2578677
11/15/18 11:53 AM
11/15/18 11:53 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By AndyF
Originally Posted By MarkM
Originally Posted By Magnum
Originally Posted By 71birdJ68
My 318 B body never cam with a bar and it handles just fine.
Compared to what?
Need a picture of a pig on ice to fully capture the handling of a B body car with tiny torsion bars, no anti-sway bar and OEM tires!
B body without sway bars
Don't be the exception.
Re: sway bars, worth it? [Re: Supercuda] #2578716
11/15/18 01:39 PM
11/15/18 01:39 PM
RapidRobert Offline OP
You guys outdid your selves on this one!. It sounds like I should go ahead & nab it. Thanks guys.
Re: sway bars, worth it? [Re: RapidRobert] #2578744
11/15/18 02:40 PM
11/15/18 02:40 PM
Houston,Tx.
Lee446 Online content
Lee446  Online Content
Houston,Tx.
My 69 Satelite weighs in at 3860. I have SS springs on the back and 1.05 torsion bars on the front and KYB shocks. Also helping are 17" wheels and z rated tires. No sway bars. I am not trying to speak against sway bars, as long as you are not a commited drag racer, there is no down side other than expense. The point I am getting to, is that handling is an integrated system. If you springs/torsion bars are worn out, no sway bar is going to band-aid that. 40 year old tire designs, parts store shocks(not that KYB's are that much better) all lead to excessive body lean and poor handling. Like I said earlier, just switching to new bigger bars made a world of difference. I talk to Mopar guy's all the time and am amazed that better than 50% of them are still running 45 year old torsion bars, most of them were too small to begin with and now they are worn out. I talked several of my B body friends into new bigger bars and they loved the increase in handling with no downside in ride quality. Sub-frame connectors are a big plus also.
Re: sway bars, worth it? [Re: RapidRobert] #2578768
11/15/18 03:26 PM
11/15/18 03:26 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If I had to choose between thicker torsion bars or adding a sway bar, I would go for the torsion bars. That being said, I think the sway bars are great in a nose heavy car to help counter body roll in the turns. With something lighter I wouldn't be as concerned.
Re: sway bars, worth it? [Re: DaytonaTurbo] #2578828
11/15/18 05:12 PM
11/15/18 05:12 PM
That is a real good point on the tbars. Actually I will be doing 2 of em, One a BB (& not sure how much aluminum will be on the eng) & the other a SB daily driver. I kinda wanted to nab the sway bar for $80 before somebody else does. Here's one & I ain't got another one yet.
Re: sway bars, worth it? [Re: RapidRobert] #2578887
11/15/18 07:24 PM
11/15/18 07:24 PM
Sweet5ltr Offline
Sweet5ltr  Offline
Significant improvement, probably the best 'handling improvement' out of any suspension modification other than subframe connectors and a modern radial tire. My 69' Road Runner handles like a modern car, with the Hotchkis suspension & properly tuned Fox shocks. Hotchkis tuned all their components on track cars, torsion bar suspension works when it's designed properly.
I've previously owned a Corvette Z06, SRT 392 Challenger, and Saleen Mustang as a reference.
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
Re: sway bars, worth it? [Re: RapidRobert] #2579005
11/16/18 01:20 AM
11/16/18 01:20 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
A swaybar does basically three things:
1. Reduces body roll, which from a drivers perspective, often improves driver feel and confidence
2. Reducing roll can improve tire patch orientation IF it is excessive and/or not favorable to begin with, when cornering hard
3. It reduces total tire grip on that axle relative, to the improvement maybe gained in #2 above, by placing more load on one tire, and reducing tire loading on the other, which ALWAYS reduces that axles total grip. A swaybar never "equalizes" tire loading, quite the opposite, contrary to what many think.
#3 can be beneficial in that it might "balance" the two axles for improved driver "feel", but it is accomplished at the cost of tire grip.
Adding a rear bar is one way of reducing the effectiveness of an oversized the front bar.
Re: sway bars, worth it? [Re: RapidRobert] #2579012
11/16/18 01:45 AM
11/16/18 01:45 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Plan on doing some fabbing with Addco bars.
I think a front sway bar is almost always worth it. With the small early a-body, and no other changes, a factory bar or the smallest aftermarket bar will be a decent match.
JCC's summary is absolutely correct and the third point worth keeping in mind whenever faced with a pitch to make the suspension more rigid.
Re: sway bars, worth it? [Re: RapidRobert] #2579020
11/16/18 02:29 AM
11/16/18 02:29 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
If I was faced with the choice of using big torsion bars with KYB shocks OR a stock torsion bar, GOOD shocks and moderate sway bars, I'd take the second option every time.
KYB shocks are like a kick to the crotch. I'll never run them on any car that I am keeping.
Re: sway bars, worth it? [Re: jcc] #2579100
11/16/18 12:30 PM
11/16/18 12:30 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Originally Posted By jcc
3. It reduces total tire grip on that axle ... by placing more load on one tire, and reducing tire loading on the other, which ALWAYS reduces that axles total grip...
This explains why a front sway will increase understeer, and a rear sway will increase oversteer: Whichever end has a sway will tend to break away before the end without a sway.
There's probably a lot more on this in the "Corners Are Best" forum.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: sway bars, worth it? [Re: RapidRobert] #2579216
11/16/18 04:35 PM
11/16/18 04:35 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
You don’t have to plan on building a toad racer to use a sway bar, they make a great improvement on a cruiser.
I would see if helwig has something for your car, they make a great tube bar. Much better brackets, fit and finish, than addco for the 67+ a bodies.
Re: sway bars, worth it? [Re: JAMESDART] #2579314
11/16/18 09:07 PM
11/16/18 09:07 PM
I will see what Hellwig offers for the earlier A & the Addco I am eyeballing doesn't have ANY brackets/links along with it but it is only $80
Re: sway bars, worth it? [Re: RapidRobert] #2579329
11/16/18 09:42 PM
11/16/18 09:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I have an ADDCO early A sway bar on my 65 Cuda. You are better off without the brackets, pretty lame and you'd end up making your own. The Hellwig is much better.
Re: sway bars, worth it? [Re: Supercuda] #2579377
11/16/18 11:36 PM
11/16/18 11:36 PM
Noted (cant beat actual experience)
Re: sway bars, worth it? [Re: RapidRobert] #2579382
11/16/18 11:48 PM
11/16/18 11:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Re: sway bars, worth it? [Re: Supercuda] #2579383
11/16/18 11:49 PM
11/16/18 11:49 PM
Thanks Supercuda, I will dig in.
Re: sway bars, worth it? [Re: RapidRobert] #2579556
11/17/18 02:10 PM
11/17/18 02:10 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I wouldn't drive one without, at the very least, the stock handling package parts...
Re: sway bars, worth it? [Re: RapidRobert] #2579579
11/17/18 03:01 PM
11/17/18 03:01 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
on my 74 Duste360, I upgraded the t-bars with 1.06" and left the factory front sway bar - added urethane bushings to it ! Then added ADDCO 3/4" rear sway bar, used KYB Gas-A-Just shocks on all corners . . . car handled great, and I really did not see or feel change in ride - put over 100k miles on that combination . . .
Page 2 of 3 1 2 3
