RAM TECHS--08 HEAT NOT HOT
#2578886
11/15/18 07:24 PM
11/15/18 07:24 PM
crabman173
crabman173
08 hemi--everything seems to work just not blowing hot--sort of very luke warm on the heat after extended driving and warm up Any ideas what to check? Thanks
Re: RAM TECHS--08 HEAT NOT HOT
[Re: stumpy]
#2578954
11/15/18 10:39 PM
11/15/18 10:39 PM
Posts: 16,841 Between Houston & Galveston TX
SattyNoCar
Has the coolant system ever been serviced? If the system was opened at anytime for parts replacement, there might be an air pocket. Maybe there is blockage in the heater core if the system has never been flushed. As stumpy said, check the temp of the hoses in and out. If they're consistent, check the blend door. If not, check for air or blockage.
John
[Re: ]
#2580310
11/19/18 07:45 PM
11/19/18 07:45 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
My 2013 300 has required all 3 blend doors to be replaced. They can allow a mix of hot/cool air. Does one side blow hotter than the other?
[Re: ]
#2584150
11/28/18 01:33 PM
11/28/18 01:33 PM
Posts: 1,607 Pgh, PA
Bull1tt
Pgh, PA
I have an 03 1500. Does not have split control heater. My blend doors are fully functioning, have no issue with air directing to defrosters or floor. I drilled a hole in the heater box to check door. I drained some antifreeze out and ran with cleaner added to water for two weeks. I then flushed heater core, got a bit of rust out of it, ran garden hose to both sides multiple times until nice and clear. Drained by lower radiator hose and added new antifreeze. Let truck warm up to temp and had hot air blasting through heater/defrosters. Test drive down the road and then a gurguling sound from dash, and heat goes away, barely warm on lowest blower setting. These get air locked? Cap no good? I’m back to where I was before, but I had it working on the first part of test drive, doesn’t plug up that fast
[Re: Bull1tt]
#2584340
11/28/18 07:54 PM
11/28/18 07:54 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
Gurgling in the dash is an indication of low coolant and also why you lost heat. Did you check the level after your test drive? Not familiar with the Ram cooling systems so I don't know if there's a trick to getting the air out. You may have to pull the heater hoses and fill the core that way.
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: Bull1tt]
#2585081
11/30/18 10:59 AM
11/30/18 10:59 AM
I_bleed_MOPAR
Buford, GA
I would pull both. Fill through one and the other will allow any air to be pushed out. Tim
[Re: ]
#2586448
12/03/18 02:24 AM
12/03/18 02:24 AM
Bull1tt
Pgh, PA
Here’s the update! I removed air filter box and I have two inline hose connections on the hoses there. I had reversed hoses last time. Today I put the 5/8 garden hose repair fitting on my garden hose nozzle, they are threaded! I can control the water that way. I pinched the hoses off with clamps on the engine side on the fittings. Then I took connectors apart. I put the nozzle in one hose and put the water through it. First comes antifreeze, then a lot of rusty looking water, then clean water. Went back and forth flushing both ways, then connected hoses and warmed engine. I now have heat as it should be. It is working fine, drove a few times today and working great! So, between the cleaner, swapping hose connections, and a couple flushes, it’s done!
