904 frictions #2577652
11/12/18 10:22 PM
11/12/18 10:22 PM
Aus
hysteric Offline OP
hysteric  Offline OP
Aus
What are the differences between front and rear clutch frictions? They look remarkably similar to me. The only difference i noticed was one set had a tooth missing.
Re: 904 frictions [Re: hysteric] #2577675
11/12/18 11:03 PM
11/12/18 11:03 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Fronts are .086" thick, rears .061". Rears are generally smooth, fronts are grooved or a checkered pattern.
Doug
Re: 904 frictions [Re: hysteric] #2577679
11/12/18 11:07 PM
11/12/18 11:07 PM
I'm thinking there is a thickness difference & I saved an article in the Jan 1999 "high performance mopar" magazine regarding using thinner frictions to use 6 clutches in a 5 clutch 3rd speed (their words) drum from a 75-79 360 eng. 10 second drag raced 904 based '66 valiant. I have one to do & I am going to Google it.
Re: 904 frictions [Re: hysteric] #2577688
11/12/18 11:14 PM
11/12/18 11:14 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I use 5 thin ones from the rear in the front to get 5 disc instead of 4...
Tony
70 AARCuda Vitamin C
Re: 904 frictions [Re: hysteric] #2577736
11/13/18 12:23 AM
11/13/18 12:23 AM
Aus
hysteric Offline OP
hysteric  Offline OP
Aus
I also have 5 in the front and 5 in the rear. I have access to alto reds @ 0.61 grooved but can they be used in both the front and rear drums? This is a street strip deal 450 hp.
Re: 904 frictions [Re: hysteric] #2577750
11/13/18 12:52 AM
11/13/18 12:52 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
OEM the rears were more aggressive and smooth since it's not a shift element. Fronts are waffle or grooved for the fluid to escape on apply. Now you can get about any configuration. A good performance material or the blues. I use rears (.063) in both to get 5 in the front. You may have to juggle steels and maybe trim the pressure plate to dial in the clearance.
Re: 904 frictions [Re: hysteric] #2577779
11/13/18 01:34 AM
11/13/18 01:34 AM
Aus
hysteric Offline OP
hysteric  Offline OP
Aus
The blues are 2 x the price of the Alto reds. Any benefit in using the blues over the alto's?
Re: 904 frictions [Re: hysteric] #2577815
11/13/18 04:24 AM
11/13/18 04:24 AM
what clearance(s) should a person shoot for (front/rear)?
Re: 904 frictions [Re: hysteric] #2577827
11/13/18 07:38 AM
11/13/18 07:38 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Not that I've heard, at your power level a standard style friction material will hold up. Getting the clearance right is the important part I was always told.
Alan Jones
Re: 904 frictions [Re: hysteric] #2577837
11/13/18 09:50 AM
11/13/18 09:50 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use 5 .061" smooth red Altos/Kolenes in the high clutch, .012"-.015" clearance per friction (.060"-.075" total). The rear uses 4 factory style silver frictions/factory steels at .025" total clearance. This package currently has 350 passes, 9.1@150, 3350lbs.
Doug
Re: 904 frictions [Re: LA360] #2577839
11/13/18 10:20 AM
11/13/18 10:20 AM
Aus
hysteric Offline OP
hysteric  Offline OP
Aus
Raises a good question. How much power can standard frictions take in a 904?
Re: 904 frictions [Re: hysteric] #2577863
11/13/18 12:06 PM
11/13/18 12:06 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The 1st Pro trans I ever serviced had the standard silver rear frictions run in the front location. 727 with 904 guts.
Doug
Re: 904 frictions [Re: dvw] #2577891
11/13/18 01:16 PM
11/13/18 01:16 PM
Doug thank you (& noted!)
Re: 904 frictions [Re: dvw] #2577928
11/13/18 02:32 PM
11/13/18 02:32 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Doug
How long ago was that? That was an old trick before the blues, Altos, etc. were available, since the rear frictions were typically more aggressive. Any serious unit I've seen, (Stock/Super Stock, low line pressure, high horsepower) has had, or I used, blues, front and rear, along with Kolene steels. I keep the rear clutch clearance snug, maybe .025. Front, depending on trans brake or not, 010 to 012 per friction.
Re: 904 frictions [Re: hysteric] #2577993
11/13/18 05:27 PM
11/13/18 05:27 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Long time ago for sure. But I opened up for inspection at 100 passes. The clutches looked like new. Put them right back in. Car made 800+@3400#.
Doug
Re: 904 frictions [Re: CMcAllister] #2578040
11/13/18 07:17 PM
11/13/18 07:17 PM
Is that .010-.012 with or without a trans brake?
