Re: my 69 rr black, pewter int and pewter painted roof
[Re: Black 69 Beeper]
#2576978
11/11/18 01:16 AM
11/11/18 01:16 AM
Posts: 937 new jersey
Black 69 Beeper
new jersey
The dash is installed and everything hooked up as well as the steering column.
#2577008
11/11/18 03:03 AM
11/11/18 03:03 AM
Superfreak
Superfreak
You can buy that glass from AMD.
[Re: modelmakerinc]
#2598526
12/29/18 08:38 PM
12/29/18 08:38 PM
Black 69 Beeper
new jersey
Most of the car is made up of reproduction parts. They can be test fit 10 times and still have to be messed with. Everything is edged in and put together and made to fit and work. The engine will also go in and be running as well as brakes and front end alignment before the car is painted. I would rather have all that finished then lean on fresh body and paint work and take the necessary steps when masking to prevent any damage to the body and paint work. Plus what is seen on some of these tv shows isn't always as simple as metal work, paint work, body work, paint, and assemble. It requires a lot of room. This car is being done in a home garage with the use of a spray booth from a shop. Thats a very logical question, its just the way I do things. When its finished you won't know how or why I did it this way.
#2602936
01/07/19 02:32 PM
01/07/19 02:32 PM
Posts: 6,710 KY
65pacecar
KY
I used a dual action polisher with 3m compound super duty compound on a wool pad, then a foam waffle polish pad w 3m micro-fine glaze and finally a black waffle foam pad w 3m glaze. It was a process. As for the moldings, I purchased a pneumatic Ingersol-Rand headlight polish kit. It had a wool pad, and 3 different foam polish pads. I used Mothers aluminum mag wheel polish on the polisher and the moldings came right up. Unbelievable they look new.. Again, it was a process over a couple of weekends but it makes all the difference. The results are outstanding. I have some spare glass that I will practice on before trying it on my good stuff. Thanks.
#2605351
01/12/19 12:58 PM
01/12/19 12:58 PM
moparpollack
Lil Herman
Lil Herman
85086
Thank you guys! The main thing that I'm trying to get out there is what materials work for me and how to do this stuff. Also it can be done at home. I'm not sure any of this can be on a budget and I will say I have a lot into this car. Even with me doing all the work, I have more than it will probably be worth. But, at the end of the day I'll know what I have and that its been done right. That's the best reason to do your own car.
#2629411
03/05/19 10:34 PM
03/05/19 10:34 PM
Superfreak
Superfreak
Finally got a windshield installer to do the windshield. I didn't want to do the install because, well if it broke. Simple as that. I ended up calling about 15 shops that I work with and everyone who's left in this hobby. All the shops who do collision work said," man I wouldn't trust my guys to do that" and if I did find someone who would even speak with me they had no clue at the end of the day about the rubber windshield seal. IT WAS PAINFUL! The hobby is in the same trouble as everyone else, no one is doing this anymore. Anyway enjoy and if your in NEW JERSEY and need a guy let me know. thanks Are you still going to be able to install the chrome trim?
