Re: Black Crackle Paint
[Re: A727Tflite]
#2575813
11/08/18 12:18 PM
11/08/18 12:18 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Who offers the best paint - for use on Hemi valve covers? Have them powder coated in black wrinkle, you'll be glad you did
[Re: DAYCLONA]
#2575821
11/08/18 12:38 PM
11/08/18 12:38 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Powder coating is a valid option if they are perfect, however every flaw in the metal will show if they have any. If repairs have been made and any kind of filler has been used powder coating is a bad idea. Also, powder coating looks nice/even but does not look O.E. correct so if that matters in your case I'd advise against it. Paint brand is less important than prep and application of the paint Start with CLEAN bare metal, no primer, and warm the covers in an oven or sunlight (not hot, just warm, 100-120F or so is plenty). Shake cans for several minutes (have at least 3-4 cans handy for a pair) apply first coat evenly and fairly heavy, its a tightrope as its easy to get runs and sags so go easy (I'd buy a spare can to practice on a junk cover first). Wait 10 full minutes and add a second coat, wait another 10 minutes and add a 3rd coat, all as even and as heavy as you dare short of runs or sags (sags can take a while to show so you really need to be careful). Once coated let them dry for several days before handling as the paint stays gummy longer than you might think and can mark easily so dont let them rest against anything. Originals usually has some small runs and sags so dont worry if you get a few small ones. If they sag or run a bunch, more paint wont fix the issue, you'll need to strip them and start over. .02
[Re: A727Tflite]
#2575846
11/08/18 01:31 PM
11/08/18 01:31 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
The VHT High Temp Wrinkle Paint & some heat lamps & a hair dryer worked great on my covers. The second picture is about the best picture I have of them close up. These used to be chrome like polished covers before I painted them.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2576002
11/08/18 07:03 PM
11/08/18 07:03 PM
Posts: 3,089 Michigan
A727Tflite
The VHT High Temp Wrinkle Paint & some heat lamps & a hair dryer worked great on my covers. The second picture is about the best picture I have of them close up. These used to be chrome like polished covers before I painted them. 👍👍. Very nice
[Re: NANKET]
#2576535
11/09/18 08:43 PM
11/09/18 08:43 PM
A727Tflite
Heat is very very important, so it the 10 minutes between coats. If you are painting outside in MI you may want to wait till summer. 50 degree day is a sure fail even with the oven. Paint one cover at a time, they are large and you will run out of time for the next coat, 11 minutes doesn't work.
I did my painting outside on a 95 degree day, it came out great. I prepped my work and used DP90LF as a basecoat over the bodywork and it worked just fine. Quality product that has dried for 2 days not rattle can junk. Good point. I have a powder coat guy near me - his building is like 90 degrees all the time - maybe I can do it over there.
[Re: A727Tflite]
#2588744
12/07/18 07:51 PM
12/07/18 07:51 PM
Posts: 28,606 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Awesome finish on the lid. What temperature did you use with the oven, same temps Scott uses? I think I would use my BBQ outside - my wife is still ticked about opening the dishwasher quite a while back to see my 6bbl intake inside. That reminds me I did the oven thing when I was 17 years old my mom was mad as hell. I did some manifolds with high heat VHT while my wif e was not home then baked some cookies to make sure it smelled ok before she got home. I did learn from my mistakes.
