2009 Ram weak headlights #2571700
10/30/18 05:50 PM
10/30/18 05:50 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Does anyone care to give a 2009 Ram 1500 Headlight upgrade recommendation?
Re: 2009 Ram weak headlights [Re: marvo451] #2571711
10/30/18 05:57 PM
10/30/18 05:57 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Phillips extreme vision +130. Great clear light. (not blue tinted)
Re: 2009 Ram weak headlights [Re: marvo451] #2571818
10/30/18 09:54 PM
10/30/18 09:54 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
We are assuming the lenses are clear... If not, start there.
Then make sure the lights have good grounds and do not have corrosion at any of the headlight wiring joints. The charging system is up to par, right?
If all that is good, then aftermarket lights might be the answer. Gene
Re: 2009 Ram weak headlights [Re: marvo451] #2572043
10/31/18 11:54 AM
10/31/18 11:54 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Someone’s getting “old eyes” smile. My 01 sucked from the factory.... thank god for the led technology. Bought a set of slim lights off Amazon (NiLight) for like 30 bucks and it totally changed my night driving experience. Mounted them in the lower bumper opening and wired then into the factory fog lamp circuit.
Re: 2009 Ram weak headlights [Re: J_BODY] #2572076
10/31/18 12:37 PM
10/31/18 12:37 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Absolutely on the old eyes... 66 years has that effect. Plus, the back roads around East Texas are dark with all the trees and winding roads. I have Sylvania Ultra Stars in the truck and am not impressed. A full on headlight to projectors change and better bulbs would be fine with me.
Re: 2009 Ram weak headlights [Re: marvo451] #2572108
10/31/18 01:36 PM
10/31/18 01:36 PM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
I had morimoto HID conversions in my 14. What a difference.
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: 2009 Ram weak headlights [Re: marvo451] #2574241
11/05/18 02:11 AM
11/05/18 02:11 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
https://www.nilight.com/collections/led-...ant=25013218121
These lil suckers were a game changer...
Re: 2009 Ram weak headlights [Re: J_BODY] #2574303
11/05/18 11:14 AM
11/05/18 11:14 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Looks like a nice auxiliary lite for deer thirty commutes.
Wouldn't consider it a head lite though.
I have mechanical Aptitude.
I can screw up anything.
Re: 2009 Ram weak headlights [Re: J_BODY] #2574468
11/05/18 04:17 PM
11/05/18 04:17 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
The headlights in my Durango are pretty sad, even with new lenses and bulbs. I just ordered a pair of these to give them a try. up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 2009 Ram weak headlights [Re: I_bleed_MOPAR] #2575615
11/07/18 11:44 PM
11/07/18 11:44 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Tim
Let us know your $.02....
I pretty much had it after towing with a friends new 17 truck... man it lit things up. My 01 sucks!!
I installed these and wired them in with my fog lamps. I also aimed them fairly low. My first trek into the darkness I thought I had wasted my $$$.... WAY bright! Wasn’t until my race-cation last summer that I tried them. First was on a divided interstate. Cool! Nobody’s flashing me! Even on two lane roads I only had a couple people flip their brights at me. Lowered the adjustment ever so slightly. Still helps me immensely and everyone else seems to tolerate them.
Re: 2009 Ram weak headlights [Re: J_BODY] #2581873
11/23/18 12:17 PM
11/23/18 12:17 PM
Buford, GA
Buford, GA
Finally had a chance to install them (I actually ordered the 6.5 inch 36w lights) and wired to my factory fog lights also.
All I can say is WOW!!! eek
I never knew how dim my stock head and fog lights were. frown
J_BODY was right on the money. They are definitely game changers. up
Only change I am going to make is to trigger them off my high beam headlight circuit instead of the fogs. I would rather drive with just low beams and the new lights on with highs. blush
Tim
'71 Charger 383/727
Re: 2009 Ram weak headlights [Re: marvo451] #2582584
11/24/18 09:29 PM
11/24/18 09:29 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Where you guys mounting these lights?
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: 2009 Ram weak headlights [Re: Adobedude] #2582735
11/25/18 10:11 AM
11/25/18 10:11 AM
Buford, GA
Buford, GA
Easiest for me was to trim the upper grille bars and mount them there. I originally wanted to mount them behind the grille but not enough room on a Durango/Dakota. Since it's a beater DD anyway it's fine for me but probably not what you would do with yours. wink
Tim
'71 Charger 383/727
Re: 2009 Ram weak headlights [Re: marvo451] #2583628
11/27/18 11:57 AM
11/27/18 11:57 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I have a jumper on my fog lamp relay so they are on all the time when I go from hi/low beam smile
I also bought a set of bumper mount led lights and wired them into my R lamp circuit. Daylight backing out of my dark side yard now laugh2
Re: 2009 Ram weak headlights [Re: J_BODY] #2588705
12/07/18 06:13 PM
12/07/18 06:13 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
So, it appears that nobody has don an LED conversion or thinks they are worthwhile for the cost.
Re: 2009 Ram weak headlights [Re: marvo451] #2592469
12/15/18 07:02 PM
12/15/18 07:02 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
I have.
2014 1500, replaced all 4 bulbs with supernova v3, I think it was. Low beam was easy, the high beam conversion was a pain in the neck, drilling, plugging and stuffing the cavity in the headlight. Pay particular attention to the orientation of the light elements.
It was a big improvement on low beam, the high beam was only more light in the same area, but reached no further, so, for me was no better than using the lows. Which of course is what is used probably 99% of the time any how.
There is a v4 now for the high beams, and I am tossing the idea around to try them. Supposed to be a big improvement.
Go to Headlight revolution to see the comparison. Good Ram light info.
BTW, bulbs are different between 2 bulb and 4 bulb systems, before you order.
About $200 per pair of bulbs when I got mine, and if I had known that the high beam side would be so little of an improvement over just the lows I would have waited, but it does look like the v4 might be worth it.
I am very happy with the low beam ones,though. WAAAY better.
They will require adjustment, several actually, before oncoming traffic stops high beaming you.
And remember you have no left/right adjustment, only up/down.
It takes gasoline to interest me.
Re: 2009 Ram weak headlights [Re: VL21] #2603036
01/07/19 06:16 PM
01/07/19 06:16 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Mine is a dual headlight model. Perhaps I’m expecting too much. I have LED fog(driving) lights and they are very white and excellent.
