Borgeson steering box
#2571449
10/30/18 05:40 AM
10/30/18 05:40 AM
Posts: 640 Graz, Austria
DGS
Graz, Austria
The Borgeson steering box seems to be based on two different OEM boxes but if I were to order one which one will I receive? I don't trust the pictures @ Summit, JEGS etc. One box is based on the Delphi 600 box that was used in Grand Cherokees. The other one is apparently a JKC box (not entirely sure but I think Hitachi owns JKC). These boxes can be found in in Isuzu Trooper/Opel Frontera A/Opel Campo/some RHD Nissans. here is the Delphi based box (note the part where the PS lines connect and the housing extends past the sector shaft) : the other PS box has a shorter housing (ends shortly after the intersection with the sector shaft) and the part where the lines connect looks different as well:
Re: Borgeson steering box
[Re: DGS]
#2571874
10/30/18 11:15 PM
10/30/18 11:15 PM
Posts: 4,748 Florida
BDW
[Re: DGS]
#2571982
10/31/18 08:27 AM
10/31/18 08:27 AM
DGS
Graz, Austria
did some more research and I believe that they do not use the Delphi box anymore. They claim that their boxes are 100% new and apparently the Delphi 600 box is out of production. Furthermore the Delphi box had to be cut and rewelded as it was too long (see weld on sector shaft housing in first picture).
[Re: mgoblue9798]
#2572259
10/31/18 05:14 PM
10/31/18 05:14 PM
DGS
Graz, Austria
I wonder what it would take to install a used jkc box out of a trooper into an a/b/e body? This is what I'm trying to figure out obviously you would need to cut off the old mounting ears and weld on new ones. And you would need to find a pitman arm that matches the spline count and taper of the Isuzu box (or cut off the spline part of an Isuzu arm and weld it to the Mopar arm).
[Re: DoctorDiff]
#2574049
11/04/18 07:59 PM
11/04/18 07:59 PM
Posts: 623 Zombieland
Car Nut
Zombieland
Borgeson discontinued the Delphi boxes several years ago.
They are now using new (un-welded) castings to produce Isuzu based steering boxes for Mopar applications.
I assume a bunch of boxes built around welded Isuzu castings are still in the pipeline, however. Are the new boxes a lot lighter too?
[Re: DGS]
#2575753
11/08/18 09:49 AM
11/08/18 09:49 AM
DGS
Graz, Austria
Looks like the Isuzu box.
Seems the NZ government is not too happy about the modified Borgeson steering boxes as they issued a safety alert:
https://www.lvvta.org.nz/documents/safety_alerts/LVVTA_Safety_Alert_09_-_2018_-_Modified_%27Borgeson%27-brand_Steering_Boxes.pdf
Maybe that is one of the reasons they are coming out with a new box...
[Re: DGS]
#2576833
11/10/18 05:58 PM
11/10/18 05:58 PM
Posts: 15,472 Omaha Ne
TJP
Omaha Ne
I would be a bit leery of anything steering box wise that Borgeson is selling. I have installed a few of their units in different applications and had a lot of problems. Wrong angles on the pitman, groaning at low speeds or when stopped, Fluid overheating for a few examples. Their tech support consists of 1. Try a different fluid. 2. We'll send you a new box / pump etc. When asking to speak with one of their engineers I was told they don't have any. They use consultants. I was further told that they design for more popular application (think Camaro) and if it works there they then adapt it over to others. Having trouble believing all of this I tried to reach the owner / CEO and was told good luck. Digging into it, the father built the company with a stellar reputation for u joints etc. He has basically retired and his son along with the father are more interested in making guns. So Proceed with caution. And should there be any non believers, Google "Gerry Zordan" and do your own research
[Re: TJP]
#2646200
04/17/19 07:49 PM
04/17/19 07:49 PM
Posts: 7,798 Lyons, CO
MileHighDart
Lyons, CO
Well, i can add a little info to this conversation.
I just installed a borgeson box in my '68 Dart
I decided to pull the trigger on this because of the slop in my original box, and the leaking became a big problem..
Purchased a unit from BAC, seems to be the newer style, its a one piece casting, meaning it doesn't have anything welded to it. It is smaller and lighter, but I still had to bang on my headers in a new spot to get clearance for the Borgeson unit, (dougs headers). Install went well enough, I used BAC's coupler. New box has absolutely no play in the center like my old box, it has a nice feel, nice and firm. No slop, no leaks. Also installed a new Moog pitman arm when I did the box cause its the only component in front end that I had not replaced or upgraded yet.
The problem I'm having is the steering wont return to center by itself after turning. It returns somewhat, but slowly, and not all the way to center. You still have to straighten up by turning the wheel back to center yourself. Kind of annoying to say the least. BAC told me I probably didnt have enough caster. So I went though my alignment last sunday. When I first checked I had 3 degrees of caster. After some adjusting I managed to get 6 degree, thanks to my QA1 upper arms. Old box return to center great with 3 degrees. But adding more caster didn't fix the issue. Maybe slightly better. Sent an email directly to Borgeson, They suggested backing off the adjustment on the top of the box 1/4 turn and see if that fixes it.
Nope, tried 1/4 turn, and then another 1/4 turn, but the problem persists. Just sent an email back to Borgeson again telling them the adjustment didn't work. We'll see what they say.
[Re: MileHighDart]
#2646494
04/18/19 02:46 PM
04/18/19 02:46 PM
TJP
Omaha Ne
Welcome to the world of Borgeson close engineering where 90% is good enough. Next thing you'll hear is we've sold hundreds of these and you're the only one having a problem (we really do need a BS smilie) Similar experience/ problems with Eddie Motorsports on their S Drive serpentine BB conversion. Maybe I'm the one's thats wrong in expecting the "kits" to work without a bunch of hair pulling BS
[Re: krautrock]
#2646684
04/19/19 01:54 AM
04/19/19 01:54 AM
MileHighDart
Lyons, CO
is it the photo or is there a bit of an angle at the coupler in the steering shaft? Yes there is actually quite an angle difference between the shaft coming out of the box, and the steering column shaft I emailed Bergman auto craft about this, his answer was that because the box is smaller Than the original the angle is necessary, and his coupler is designed to handle the angle.
[Re: MileHighDart]
#2646830
04/19/19 12:57 PM
04/19/19 12:57 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I've been tempted to purchase and install ... and try the Borgenson box (and get it through BAC with their coupler, hoses, etc), primarily interested in the reduced weight (~10 lbs?)... but the ratio is only stated at ~14:1... whereas the T/A box with fast ratio long pitman arm (and the C-body longer idler arm... aka "fast ratio matching idler arm)... seems to be the faster setup for quickest steering response. I had my T/A box recently rebuilt by Firm Feel (Stage 3)... still to drive the car as its waiting for the new SB engine.
I've always wondered IF the longer "fast ratio" pitman arm would work with the Borgenson box... and what the ratio would become.. and the resulting steering effect. I want the fastest steering response. (Using a smaller diameter steering wheel also helps.... I use an 11.5" thick deep-dish padded wheel... works great!)
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2647558
04/21/19 01:10 PM
04/21/19 01:10 PM
Posts: 2,578 sweden
1Fast340
sweden
I've always wondered IF the longer "fast ratio" pitman arm would work with the Borgenson box... and what the ratio would become.. and the resulting steering effect. I want the fastest steering response. (Using a smaller diameter steering wheel also helps.... I use an 11.5" thick deep-dish padded wheel... works great!) Ok i will admit right a way that i dont have any experience with the Borgeson box.the fast ratio pitman arm or a firm feel box for that mather,but i will throw in a few thoughts from an outside osberver anyway, The longer idler arm and pitmanarm will push your steering linkage rearwards and may create interference with your headers/exhaustpipes just one of those things that may be good to keep an eye on. Also i dont know how those firm feel boxes "feel" but just getting away from that big "dead" spot around center that most stock boxes has should be a great advantage from the borgesonboxes from what i undertsand.
[Re: AndyF]
#2647644
04/21/19 09:33 PM
04/21/19 09:33 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Sounds great, good to know you are enjoying it. I'm still rounding up the parts for my conversion. I was going to use the Saginaw pump but now I'm considering going with a late model Type II pump instead. I suppose if I'm going to make it modern I should go ahead and make it modern. I've had my share of issues with a Type II pump, but they now seem to be resolved. I ended up going through one generic Speedway motors pump, one junk parts store pump before landing my PSC Motorsports pump that seems to be getting the job done. They are quite particular about their fluid, I use the recommended AC Delco power steering fluid, and nothing else. PSC ball bearing "race" Type II pump with integral reservoir and a Borgeson box. I'd like to add the long arms to the box and idler, the steering is too slow for me. My pump mount design doubles as a torque strap mount as well. [final hose routing is not shown]
[Re: AndyF]
#2648286
04/23/19 09:24 PM
04/23/19 09:24 PM
Posts: 4,449 Michigan
MarkZ
Worthy
Worthy
Is there any benefit to going to a type II box over the Saginaw? I'm actually looking at buying a new pump this season and haven't had any luck with junk parts store boxes. Borgeson sells them and I just planned on get a pump from them to match the steering box. They're $350 though and for that I can get the brackets and type II pump from Unisteer.
[Re: MileHighDart]
#2648318
04/23/19 11:37 PM
04/23/19 11:37 PM
Posts: 2,138 tucson az
frank
tucson az
is it the photo or is there a bit of an angle at the coupler in the steering shaft? Yes there is actually quite an angle difference between the shaft coming out of the box, and the steering column shaft I emailed Bergman auto craft about this, his answer was that because the box is smaller Than the original the angle is necessary, and his coupler is designed to handle the angle. The same for the box I put in my Charger. I'm using my Saginaw pump that I already had. Have not driven the car yet but just turning the wheel staticly I could feel a big difference.
[Re: MarkZ]
#2648330
04/24/19 01:18 AM
04/24/19 01:18 AM
Posts: 31,060 Oregon
AndyF
Is there any benefit to going to a type II box over the Saginaw? I'm actually looking at buying a new pump this season and haven't had any luck with junk parts store boxes. Borgeson sells them and I just planned on get a pump from them to match the steering box. They're $350 though and for that I can get the brackets and type II pump from Unisteer. The Type II box is lighter and more popular with the aftermarket than the Saginaw pump. I also think it looks better. I can't tell you on performance since I don't have any experience yet with either box. I think the Saginaw pump works okay but it doesn't seem to be the hot setup for the road race guys. They all seem to be using the Type II pump these days. So for a street car I think the Saginaw probably works just fine. The Saginaw is also dirt cheap to buy and rebuild (if you have the proper tools). Personally I think I'll end up with the Type II pump on my car but that is because I'm more Mod than Resto. I already have the EFI, Porsche brakes, Toyota alternator, digital dash thing going on. Might as well keep it rolling with a Type II PS pump........
[Re: 71TA]
#2649557
04/27/19 02:59 PM
04/27/19 02:59 PM
Posts: 2,578 sweden
1Fast340
sweden
Turns out I need to use the Type II box since the Saginaw pump will not fit with the motor mount that I'm using. The outlet port runs right into the motor mount and there is no easy fix that I can see. What are those there shorty headers? I would guess its a set of these: https://www.engine-swaps.com/Pages/ProductsType/BRB_Headers.html
[Re: AndyF]
#2652076
05/05/19 05:42 AM
05/05/19 05:42 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
My Borgseon box was angled deadstraight when installed at first (small sectorshaft but '73 K-member/Dart). But after I installed Doug's headers a few years later I had move the engine and P/S around a bit to have the (stock) steeringcoupler clear the nr. 7 exhausttube. It's at a very slight angle now.
[Re: Sxrxrnr]
#2653080
05/07/19 05:33 PM
05/07/19 05:33 PM
Posts: 602 Portage Wisconsin
Lou_Steger
Portage Wisconsin
Installed in our Ebody, 5 plus years ago. Like now, but one hell of an adventure to get it dialed. Do a search on Borgeson and read some of the older threads. Also put one in wife’s 55 T Bird. Another adventure as they had never offered a system for the Bird. Adapted a full size Ford unit to the Bird. Works well Could you elaborate on what you mean by "adventure"?
[Re: Lou_Steger]
#2653132
05/07/19 07:48 PM
05/07/19 07:48 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Installation was a real pita. After many weeks finally came up with shimming of box in order to get proper toe alignment. Borgeson tech support was let me put it politely,,,,less than adequate. It was always user error until I discovered their real problem which was in machining and jigs to attach mounting ears. Subsequently others found exact same issues. Once shim was created an installed, all was ok. I did a search for my old threads. For some reason only found going back to 2016. Those from 2014 til then are not listed. This is where main adventure and photos were. This url will show some of my thread,,,,but only those 2016 or later. They are listed by my handle. https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/dosearch/topic/0/Searchpage/8.html
[Re: Sxrxrnr]
#2653593
05/09/19 08:07 AM
05/09/19 08:07 AM
Lou_Steger
Portage Wisconsin
Installation was a real pita. After many weeks finally came up with shimming of box in order to get proper toe alignment. Borgeson tech support was let me put it politely,,,,less than adequate. It was always user error until I discovered their real problem which was in machining and jigs to attach mounting ears. Subsequently others found exact same issues. Once shim was created an installed, all was ok. I did a search for my old threads. For some reason only found going back to 2016. Those from 2014 til then are not listed. This is where main adventure and photos were. This url will show some of my thread,,,,but only those 2016 or later. They are listed by my handle. https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/dosearch/topic/0/Searchpage/8.html For some reason I can't get the link you provided to work. Anyway is the box you are using the welded or cast one?
