Re: Still having to prime my carb to get my car to start
[Re: Sixt8Chrgr]
#2570397
10/27/18 10:31 PM
10/27/18 10:31 PM
Posts: 4,453 Morristown Tn.
71birdJ68
Morristown Tn.
Just the way gas is now a days. If my car sits more than 2 days I have to crank it to fill the bowls.
[Re: dragon slayer]
#2570430
10/28/18 12:24 AM
10/28/18 12:24 AM
Posts: 177 NC
Sixt8Chrgr
NC
What is a fuel sending unit? Cars can do this. Some add an electric pump to prime the carbs before starting.
You can break the fuel fitting after the pump and vapor cannister at the carb. Crank car and see if you get fuel out of line. Even measure pressure if you have a gauge. If not some thing amiss and work your way back to the pump.
But it can take a long time to prime the carb(s) and line when the car sits and the fuel evaporates. [i][/i] Fuel pick up in the tank with the sock is what I should had said. What my car is doing is not normal. It did not do this prior to the resto and the fuel vapor canister. I did re use the fuel pick up and should had changed it. I did take the fuel line off the carb after cranking if for a long time and it was bone dry. Did the same with the line off the carb and had the line in a bottle...no fuel. Did not crank real long though. Since the fuel gauge is not 100% correct might as well change out the gauge sending/pick up with a new sock and see if that fixes it
[Re: Challenger 1]
#2570431
10/28/18 12:26 AM
10/28/18 12:26 AM
Posts: 177 NC
Sixt8Chrgr
NC
Yes I bet the sock on your pickup in the tank is dirty if you have not checked it.
I have a 440 and a 340 with stock mechanical fuel pumps and fresh socks in the tanks. They both start after sitting for months. Yes I have to crank them for 15-20 seconds while pumping the gas petal but they start consistently for more than 10 years now. The 440 has a 6 pak and the 340 has a edlebrock 600 on it with mechanical chokes that work. The chokes help too. I haven't had the air cleaners off in years literally.
Besides the sock check for any rust, even the smallest pin hole will cause problems starting in your steel suction line. Can't have any leaks in your suction line, check it. Will do thanks
[Re: Sixt8Chrgr]
#2570509
10/28/18 09:56 AM
10/28/18 09:56 AM
Posts: 1,567 Ky
jt4406
Ky
Agree with all the "above", but would like to add: check length of your fuel pump push rod against a known good one (this fooled me recently) and seems I remember reading that some of the repop six pack vapor canisters had a return orifice that was too large? May be worth looking at if your pickup sock and fuel pump pushrod prove to be good. jess
Yeah, it's hopped up to over 160...
[Re: Sixt8Chrgr]
#2570566
10/28/18 01:04 PM
10/28/18 01:04 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Only thing to add is there should be some fuel in bowl when first starting. It should not need the fuel pump to run to refill it. There should be enough fuel in the bowl to start and run it for a minute or so. Quick check: Remove air cleaner lid and see if the accelerator pump shoots fuel out. If yes. Do it again to see if there's enough fuel in bowl to refill the pump. If no. remove top of carb to see if there is fuel in the bowl. If yes, accel pump may need new seal or check valve. If no, its either weeping out or evaporating. Also, just know there's several service bulletins in 70s addressing the issues of starting. Some models got an internal bypass in the pump which helped hot starting but made cold starting more difficult. http://www.imperialclub.org/Repair/Lit/Master/307/index.htm
[Re: Sixt8Chrgr]
#2570571
10/28/18 01:16 PM
10/28/18 01:16 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
Today's Ethanol laced fuels evaporate at a much higher rate than normal "gas" and that is your problem. If you let the car set for more than a week all the fuel in the carb will evaporate and you wind up having to crank the engine for a while to fill the bowls again. You don't find this problem with fuel injected cars since they all use electric pumps and run on high pressure. You also won't find this problem with a carburetor setup when using an electric pump.
With the crap we have for fuel now days you basically have three choices. Change to an electric pump and eliminate the mechanical pump, add an electric pump with a check valve to bypass the mechanical pump so you can fill the bowls before starting, or fill the bowls manually before starting.
Those are pretty much your options. Good luck.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: Sixt8Chrgr]
#2570608
10/28/18 03:09 PM
10/28/18 03:09 PM
Posts: 25,811 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Do modern cars have this problem? No. Do modern cars have carburetors? No. The answer to the OP's problem lies here, modern fuel is gonna evaporate from open reservoirs.
[Re: jt4406]
#2570721
10/28/18 08:53 PM
10/28/18 08:53 PM
Posts: 404 IL us
ink
IL us
Agree with all the "above", but would like to add: check length of your fuel pump push rod against a known good one (this fooled me recently) and seems I remember reading that some of the repop six pack vapor canisters had a return orifice that was too large? May be worth looking at if your pickup sock and fuel pump pushrod prove t.. be good. jess this... got me new push rod was the fix !
[Re: ink]
#2570759
10/28/18 10:18 PM
10/28/18 10:18 PM
Posts: 299 Hinckley, Ohio
KWF340
Hinckley, Ohio
Agree with all the "above", but would like to add: check length of your fuel pump push rod against a known good one (this fooled me recently) and seems I remember reading that some of the repop six pack vapor canisters had a return orifice that was too large? May be worth looking at if your pickup sock and fuel pump pushrod prove t.. be good. jess this... got me new push rod was the fix ! Same here. If the car hadn't been started for an extended time period (maybe a week or two - can't remember) then no matter how long I cranked the engine it would not start. To get the engine to start I also had to manually prime the carb. I eventually found that the push rod was worn and once replaced the problem was gone.
1968 Charger R/T, 440 Auto, GG1; 1969 Super Bee, 383, 4-speed, T5; 1969.5 Road Runner, 440-6, 4-speed, 96; 1970 Duster 340, 4-speed, EV2; 1970 Charger R/T SE, 440 (496), Auto, EB3; 1970 Dart Swinger 340 (416), 4-speed, EV2; 1970 Corvette coupe, LS5, 4-speed, Daytona yellow; 2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
[Re: Sixt8Chrgr]
#2571095
10/29/18 05:12 PM
10/29/18 05:12 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
3RD vote for a fuel pump push rod being worn. I had this problem before on one of my other Hemi's when it sat for a period of time. Seems it would not give it large enough pump shot while cranking. Once fired it would idle & run fine. Once it changed out for a new push rod the problem went away & start right up every time afterwards. Even seemed to pull harder at higher RPM also, so it must have been losing fuel pressure at high RPM's also.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
