28" tall skinny front RADIALS?
#256972
03/17/09 01:04 PM
03/17/09 01:04 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Anyone know a good radial tire that's 28" tall and skinny for a 15" rim? Pics? Thanks, CHIP
Re: 28" tall skinny front RADIALS?
[Re: 65signet]
#256974
03/17/09 05:22 PM
03/17/09 05:22 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Nope Problem is when you get that tall, the aspect makes the tires wide 8"+. 205/75/r15 is a 27 inch tall but the tread is 8"+. Compared to the 195/65/r15, which is a inch shorter about 26" and the tread is about 1/2 more narrow.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#256975
03/17/09 05:34 PM
03/17/09 05:34 PM
Bob_Coomer
Rock Springs
BTW I forgot about the tires 165/80/r15...these are most peoples best bet, they are skinny, and ar about 25 1/2" tall. these are readily available, for about $50 and this will be the route I go. Hope this helps....
[Re: an8sec70cuda]
#256977
03/18/09 04:11 AM
03/18/09 04:11 AM
Posts: 793 Utah
topbrent
Utah
We used Firestone FR380 205/75/15 on the front. 27.1 tall and it's mounted on a pair of Vintage Wheelworks 15x4 Mags. We went with that tire because it does not have the modern square block profile. It has a sloped shoulder to it and when mounted on a small rim it has a great bulgey look. It also has a nice stiff sidewall to it, which many tires this size do not. Looks aggressive on a musclecar. It's a white wall on one side, but if you use some Kiwi brand, black shoe dye, it will take care of that nicely. The black dye really does work fantastic, although we hadn't applied yet in these photos. FR380 web page
[Re: topbrent]
#256979
03/18/09 04:18 AM
03/18/09 04:18 AM
Posts: 793 Utah
topbrent
Utah
[Re: topbrent]
#256980
03/18/09 04:30 AM
03/18/09 04:30 AM
Posts: 793 Utah
topbrent
Utah
[Re: 70Cuda383]
#256982
03/18/09 04:44 AM
03/18/09 04:44 AM
Posts: 793 Utah
topbrent
Utah
Poppin' wheelies with no engine even... ....that's fast, yo. BTW: My brother has it up for sale currently. Quote:
Another.
whew! that car IS fast!
it's doing a wheel stand in the garage, when it's not even moving!
(Looks good!)
[Re: Bob_Coomer]
#256983
03/18/09 09:30 AM
03/18/09 09:30 AM
Posts: 12,120 City of Champions
Prostock
City of Champions
I'm not so sure that would be a speed rated tire, or one designed to support the weight of a heavy car.
[Re: SRT8Challenger]
#256987
03/18/09 01:41 PM
03/18/09 01:41 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
215 70R 15 radials in the signature picture At the time I was trying for the stock size at the time, F70 15 but in a radial....
I also have a pair of 28" (27.5" actual) DS2's on 4" wide wheels to try at the track sometime. I'm thinking they will save about 20lbs and might help ET by a few hundredths if I'm lucky. I've driven them on the street just long enough to know I can do it if I have to....but that I don't really want to...
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#256988
03/18/09 02:08 PM
03/18/09 02:08 PM
an8sec70cuda
Would someone please tell me why this was moved out of the race section????? Not many outside the race section are using skinny front tires...I posted it in the race only section for a reason. CHIP
[Re: an8sec70cuda]
#256989
03/18/09 02:28 PM
03/18/09 02:28 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Any quality modern tire is rated for at least 100 mph or more.Thats the least.The 165s on my 65 are doing fine.You arent running Bonneville with them and they arent going under a diesel dually.Anyone that sayd they run MT sportsmans fronts on the street and they handle are full of you know what or they drive a staright line on perfect roads.Rocky
Chrysler Firepower
[Re: an8sec70cuda]
#256990
03/18/09 04:40 PM
03/18/09 04:40 PM
ZIPPY
S.E. Michigan
I didn't do it Chip, dunno
I'll move it back if you want, but that might be worse
