1993 Dodge Dakota ball joints -- UPDATE we have a problem #2567514
10/21/18 10:50 PM
10/21/18 10:50 PM
Between Houston & Galveston TX
SattyNoCar Offline OP
Happy Birthday SattyNoCar  Offline OP
'93 Dakota 2 wheel drive, is it normal that the bottom ball joint is pressed in and the top threaded?
Guess who has the wrong ball joints on the way because of this. mad
Was trying to save time and money. I could clearly see the top one is threaded, the bottom one was so caked with grease/mud/funk, I couldn't readily tell and just guessed it was threaded too.
The joints don't look that bad really, but I figured I'd replace them since I'm tearing everything down to replace the bushings. Truck has 178K
Anybody want to buy a set of threaded lowers? realmad
John
Re: 1993 Dodge Dakota ball joints -- is this normal? [Re: SattyNoCar] #2567515
10/21/18 10:52 PM
10/21/18 10:52 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
You remind me of me!
Re: 1993 Dodge Dakota ball joints -- is this normal? [Re: SattyNoCar] #2567518
10/21/18 10:56 PM
10/21/18 10:56 PM
BDW Online content
BDW  Online Content
Why can't you return them?
Re: 1993 Dodge Dakota ball joints -- is this normal? [Re: BDW] #2567522
10/21/18 11:05 PM
10/21/18 11:05 PM
I'm sure I can return them, it was meant more as a joke. up
So, why the heck would they have one pressed and one threaded?
John
Re: 1993 Dodge Dakota ball joints -- is this normal? [Re: SattyNoCar] #2567654
10/22/18 02:31 AM
10/22/18 02:31 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
So they can sell the entire control arm - OE captive. Don't you love it?
Re: 1993 Dodge Dakota ball joints -- is this normal? [Re: SattyNoCar] #2567676
10/22/18 07:00 AM
10/22/18 07:00 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Lot of newer cars have pressed in joints, but are usually held in with a retainer clip.
Re: 1993 Dodge Dakota ball joints -- is this normal? [Re: SattyNoCar] #2568007
10/22/18 08:48 PM
10/22/18 08:48 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
yup. just like your old 73 wagon. threaded uppers and pressed lowers.
as far as Dakota.... same upper ball joints as an old C body or a B van or a D150. same lowers as the old cars too.... upper bushings are the same as (I forget what exactly,) I think an F body. I just went thru this on my 96.
2wd and 4wd take same upper control arm bushings (have a 92 2wd and a 96 4wd) and same upper ball joints, lowers are different between 2wd and 4wd.
Re: 1993 Dodge Dakota ball joints -- is this normal? [Re: volaredon] #2568420
10/23/18 04:26 PM
10/23/18 04:26 PM
I should say, we MAY have a problem.
Ordered MOOG press in lower ball joints, part # K7025.
They look a lot smaller than the original. Taking the nut off the original and putting it on the new one, the nut doesn't even engage the threads. It just slides down to the taper on the joint.
It's pouring down rain right now so I didn't get to look any closer than what I mentioned above.
I hope this hasn't become a part that was superseded by something that 'may' fit because of age.
drinking
John
