Short Pistons height reliability
#2566682
10/19/18 10:05 PM
10/19/18 10:05 PM
Posts: 1,030 ohio
67mprfan
ohio
Any issues with running a piston with 1.320 height on the street and is there longevity concerns...
Only 1 question and not multiple threads from me LoL
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
Re: Short Pistons height reliability
[Re: 67mprfan]
#2566686
10/19/18 10:10 PM
10/19/18 10:10 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
1.32” wouldn’t be considered short in my book. That’s a typical low-deck / long rod 451 piston ht. Not even a second thought.
Until the ring lands are into the pin bore, you’re fine.
[Re: StealthWedge67]
#2566711
10/19/18 10:59 PM
10/19/18 10:59 PM
Posts: 1,030 ohio
67mprfan
ohio
Until the ring lands are into the pin bore, you’re fine. Yep they are Ross dome 10cc a friend of mine is basically giving them to me they were used in a 470 build which I might do or a 451. Just waiting to see if my block sonic checks okay
[Re: 67mprfan]
#2567118
10/20/18 11:44 PM
10/20/18 11:44 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
No issues at all, they won't give you any trouble.
Rich H.
Esse Quam Videri
[Re: 67mprfan]
#2567120
10/20/18 11:47 PM
10/20/18 11:47 PM
Posts: 4,210 New York
polyspheric
New York
Fragile vs. life expectancy: 2 different answers
Boffin Emeritus
[Re: polyspheric]
#2567198
10/21/18 09:52 AM
10/21/18 09:52 AM
Posts: 1,030 ohio
67mprfan
ohio
Fragile vs. life expectancy: 2 different answers How fragile will they be for street strip build ( of course everyone definition is different) Ross piston probably Molnar Crank maybe scat rods. not planning on turning it pass 6500 when I do go to the track so what would life expectancy be
[Re: 67mprfan]
#2567208
10/21/18 10:37 AM
10/21/18 10:37 AM
ZIPPY
S.E. Michigan
I've had three personal vehicles with 5.7 Hemi engines. One had 190,000 miles on it when it was totalled. It used no oil, ran perfect.
When it was totalled, I replaced it with another one which recently turned 150,000 miles. Same thing as above.
I feel both vehicles have had good maintenance.
I also have a truck that is about to turn 250,000 miles. I bought it from a machine shop that used it to haul tools all over the country. I believe it was probably maintained using whatever the cheapest bulk oil the quick oil change sold them. Same thing, it uses no oil and runs fine.
Compression height is 1.220.
You wont have any trouble.
I could go on about the engine in my signature car which has 1.32, but I feel the 5.7 hemi is a better example.
ps. That demon sounds cool!!
Rich H.
Esse Quam Videri
[Re: 67mprfan]
#2567267
10/21/18 01:05 PM
10/21/18 01:05 PM
Posts: 1,030 ohio
67mprfan
ohio
Thanks Zippy I sold the demon last year in August. Then I bought the belvedere as I wanted to be able to drive around on the street when racing didn't happened that weekend for whatever reason, now trying to get together a game plan for a engine for the belvedere because right now the 318 in it is TIRED
[Re: 67mprfan]
#2567425
10/21/18 07:00 PM
10/21/18 07:00 PM
ZIPPY
S.E. Michigan
Too bad it's gone....but myself I do prefer the bigger cars even if they carry more weight. There is something about the proprtions of a B body that totally does it for me and always has.... There is an intimidating street presence a B body has that, in my opinion a smaller car just doesn't. Not sure why....and of course the smaller cars are usually faster but it's not always about that one thing.
All the stroker combos that use 1.32 ballpark CH are "known good"....I have a feeling your Belvedere is going to be a good runner.
Rich H.
Esse Quam Videri
