Part Number look Up Question #2566404
10/19/18 12:07 PM
10/19/18 12:07 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
Can someone help me with a part number application.Control arm #3408934 Thanks for any help !!
Re: Part Number look Up Question [Re: 44D6PAKCUDA] #2566439
10/19/18 01:02 PM
10/19/18 01:02 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That's not list in the Passenger car 70-71 parts book
Re: Part Number look Up Question [Re: 44D6PAKCUDA] #2566544
10/19/18 04:12 PM
10/19/18 04:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Where are you finding the part number? If it's on the part itself, it often isn't the part number.
Re: Part Number look Up Question [Re: John_Kunkel] #2566854
10/20/18 10:45 AM
10/20/18 10:45 AM
Someone had hand written it on a tag.I didn't find anything either.Pretty sure it's an A body arm.These would have the "VL" stamped on them correct? And is there a difference between 1970-2 lower arms and 1973 up arms? I know the spindle size of something changed,
Re: Part Number look Up Question [Re: 44D6PAKCUDA] #2566876
10/20/18 12:01 PM
10/20/18 12:01 PM
md
mopars4ever Offline
mopars4ever  Offline
md
it might suppose to be 3402934 but that would be a cuda challenger lower arm
Re: Part Number look Up Question [Re: 44D6PAKCUDA] #2567046
10/20/18 08:31 PM
10/20/18 08:31 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
post a picture
Re: Part Number look Up Question [Re: Morty426] #2567804
10/22/18 01:32 PM
10/22/18 01:32 PM
I don't have a picture yet,but is there any difference between 1970-2 lower control arms and 1973-6 arms? Or just a different/supersede part number? I think they used larger spindles or brakes on '73 and up,but did the lower arms change at all?
Re: Part Number look Up Question [Re: 44D6PAKCUDA] #2567828
10/22/18 02:23 PM
10/22/18 02:23 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Sway bar brackets are welded in different locations. 67-72 is out near end. 73-76 is in middle of LCA.
All performance A-bodies 340, 360, 383, 440 got front sway bars.
Other than that, I think? there is a date code stamped on them?
