SS Spring A Body Shocks #2565848
10/18/18 11:42 AM
10/18/18 11:42 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
There was a post a few weeks ago on shocks. Didn't see an answer for a lower HP. My latest build is an A body with about 390 HP. For simplicity, I'm using SS springs. 30 years ago, you just looked for the longest rear shock and that was it. Not a lot of selection now and most shocks, that are available, are only online and there are no length specs. So looking for a shock recommendation using a DOT drag radial, street/strip car. I thought of the Rancho adjustable but couldn't find shock length. Is longest shock length not a good solution for SS springs?
Re: SS Spring A Body Shocks [Re: A/MP] #2565851
10/18/18 11:51 AM
10/18/18 11:51 AM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
Calvert Racing (the Cal-Trac guys) have a good 90/10 for the front and adjustable rears that are cost effective and work twocents You might give them a call and they can set you up
Curator at Adams County Speed Shop
Re: SS Spring A Body Shocks [Re: A/MP] #2565885
10/18/18 01:00 PM
10/18/18 01:00 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I went 9’s( and the car was remarkably consistent) in a 3350 pound Duster on 002/003 leafs and CE 3 way shocks at all 4 corners.
Fronts set at 90/10, rears i had staggered settings, buts its been awhile now and i forget just how i had them, know left rear was looser, and right rear tighter.
Had the car forever and never had the need to change shocks because of any hooking issues.
Car went 1.34/1.37 60 foot depending on weather. Only issue was with wheelstands, which could be dealth with using limiters, hanging weight, or rear air pressure.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: SS Spring A Body Shocks [Re: A/MP] #2565928
10/18/18 02:02 PM
10/18/18 02:02 PM
AndyF Offline
AndyF  Offline
Calvert has several different lengths of shocks. They don't list them all on the website since it tends to confuse the customers so just call them and tell them what you need. SS springs tend to require a really long shock.....
Re: SS Spring A Body Shocks [Re: A/MP] #2566005
10/18/18 04:32 PM
10/18/18 04:32 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Well I am still old school and cheap since I live on disability. I just run SS springs and the longer MP shocks. Not the greatest 60 but for a street car raced on pump through the full exh and just SS springs I guess its not to bad. Running 10.70's my best 60 is a 1.50. Course that's on my 63 B-body. Ron
Re: SS Spring A Body Shocks [Re: A/MP] #2566140
10/18/18 08:59 PM
10/18/18 08:59 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
When I bought my Rancho shocks I found them on the Summit website. There were several pages with shock lengths.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: SS Spring A Body Shocks [Re: A/MP] #2566173
10/18/18 10:09 PM
10/18/18 10:09 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
The trick was to get SW rear shocks. They were about 2-3" longer.
Re: SS Spring A Body Shocks [Re: A/MP] #2566192
10/18/18 10:50 PM
10/18/18 10:50 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
here's some info.
Attached PDF document
Re: SS Spring A Body Shocks [Re: Mr340] #2566386
10/19/18 11:31 AM
10/19/18 11:31 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Thanks. Couldn't get much satisfaction from the Summit online catalog.
Re: SS Spring A Body Shocks [Re: A/MP] #2566417
10/19/18 12:23 PM
10/19/18 12:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What about shock extensions.. the height of the
springs is your issue
wave
Re: SS Spring A Body Shocks [Re: A/MP] #2566419
10/19/18 12:25 PM
10/19/18 12:25 PM
STL
cdstl Offline
cdstl  Offline
STL
That was probably my post. '70 Duster 8.75 rear and SS springs.
Stock Duster shock specs..
Extended 21.75"
Compressed 13.0"
Travel 8.25"
1986 Dodge truck specs (what everyone said to find)...
X-25"
C-15.6"
T-9.5"
Monroe 58577 coil over (I also have a set for my Cuda)...
X-22.5"
C-13.75"
T-8.75"
My buddy used a set of Monroe coil over 58496 on his Demon, but he has stock springs.
X-21.25"
C-13.00"
T-8.25"
We used a Monroe coil over 58577. I did have to remove the sleeve at the top to fit the upper shock bolt through. Two washers on either side compress the rubber washer inside.
With that being said, the stock upper shock mounting bolt was gone and it has an after market bolt in that place.
We also got a longer rear rubber brake hose for a 2 wheel drive Dodge truck. I don't remember the year but I think they're all the same.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: SS Spring A Body Shocks [Re: MR_P_BODY] #2566573
10/19/18 05:12 PM
10/19/18 05:12 PM
that's what I did on a 65 dart daily driver that came to me as a roller with 003/003's. they look unsightly which may or may not be an issue (just saying) & there is "something" about you want the compressed % of the shock choice to be right (not my area, just a heads up) but iirc something about halfway compressed at rest.
Re: SS Spring A Body Shocks [Re: A/MP] #2566610
10/19/18 07:23 PM
10/19/18 07:23 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I did shock extenders on mine. I had cheap stiff KYBs and CE drag shocks at different times- both were fun
Re: SS Spring A Body Shocks [Re: A/MP] #2566705
10/19/18 10:48 PM
10/19/18 10:48 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I knew that Mr. Gasket had them but could not find then for a Mopar. From 30 + years ago, I remember how the SS springs would arch and the shocks could not keep up with the suspension movement, and the shocks could no longer do their job. I assume that this is still true, the longer shock keeps the tires to the ground and free from the bounce/hop.
Re: SS Spring A Body Shocks [Re: A/MP] #2566742
10/20/18 12:56 AM
10/20/18 12:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You will need stronger shocks.. if your using
some sort of stock shocks you need a stiffer
set up to control the axle
EDIT
more than likely the hop is the shocks are too
short and once they top out they lift the axle
housing so you need to find longer and stronger
shocks or use shock extensions to try and get
the correct design length and set them up at
the length
wave
