Dying/Painting Vinyl Door Pads - Black to Tan #2565108
10/16/18 10:30 PM
10/16/18 10:30 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I am interested in a set of door pads for my Dart, 4dr parts aren't that easy to come by. Problem is, they are black and I need them to be tan to match the rest of the interior.
Has anyone had success with that drastic of a color change?
I repainted my plastic trim in the 'Cuda with great results using the SEM process, however that was black over black.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: GoodysGotaCuda] #2565123
10/16/18 10:52 PM
10/16/18 10:52 PM
IMGTX Offline
IMGTX  Offline
I went from white to black on my Challenger.
I found that if you wipe the plastic/vinyl down with a heavy dose of acetone right before you paint it the adhesion is better. It softens and opens up the plastic to be ready to bond with the paint. Just painting according to the instructions had spots peel in very little time.
Just be sure the acetone is dry enough to paint over.
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: GoodysGotaCuda] #2565126
10/16/18 11:05 PM
10/16/18 11:05 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I had good luck with the Eastwood products. Going from white to black, though.
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: IMGTX] #2565132
10/16/18 11:15 PM
10/16/18 11:15 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Did you try their adhesion promoter?
2020 RAM 1500
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: GoodysGotaCuda] #2565139
10/16/18 11:29 PM
10/16/18 11:29 PM
IMGTX Offline
IMGTX  Offline
This was back in the days of old... Before you were born and all they sold was the dye, you young whipper snapper.
Still I would whole heartedly suggest the acetone cleaning because the Acetone will remove all traces of oils & wax as well as soften the surface getting better adhesion.
As plastic ages the surface oils evaporates and it dries out. There isn't a way to replenish the oils lost in the surface but the acetone will help dissolve the surface and get better adhesion. Not dissolve enough to melt or distort the surface though. It evaporates long before that happens.
I did the vinyl seats and after 50K and 10 years there was no spots worn off enough to see white through. A couple scratches but the wear was minimal at best.
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: GoodysGotaCuda] #2565170
10/17/18 12:51 AM
10/17/18 12:51 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've used SEM over the decades, dosen't matter, light to dark, dark to light... here's my 70 Charger interior, the seats upholtery, headliner and lower door panels are white Legendary repros, but the upper soft pads, arm rests, seat plastic hardware/trim, back window trim and other assorted panels and metal/plastic trim pcs were all black originaly, color changed with SEM, I DON"T use the adhesion promoter, I've found that causes the finish topcoat to take forever to fully dry (weeks)...
I just "wash" everything in lacquer thinner and clean white rags several times to leach out any oils/silicone/etc and make the surface "raw" for good adhesion (just allow some time between washes to let the vinyl/plastic "breath" as lacquer thinner is very aggressive), I recommend you spray from a gun for best results, and thin layers, allowing for flash time between coats, avoid one coat coverage and thick build up, for all light colors I finish with a final coat of SEM's satin or low lustre clear depending on what sheen your trying to achieve, the Low Lustre clear is basically invisible and does not alter the color/tint, and aids in cleaning without disturbing the color fastness...
I did this interior over 14 yrs ago and it still looks as fresh as day 1 with ZERO issues...
Mike
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: GoodysGotaCuda] #2565189
10/17/18 01:34 AM
10/17/18 01:34 AM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Mike, as DAYCLONA stated use the SEM product! They sell a adhesion promoter and it real helps. More money then the off the self brands, but the results are well worth the efforts and extra expense.
My Monster are real!
Living within your means makes life pretty easy.
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: GoodysGotaCuda] #2565231
10/17/18 07:51 AM
10/17/18 07:51 AM
None
71rm23 Offline
71rm23  Offline
None
I used a wax/grease remover, applied adhesion promoter, then interior color of your choice. My panels turned out awesome
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: GoodysGotaCuda] #2565429
10/17/18 04:22 PM
10/17/18 04:22 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Adhesion promoter!!! Works awesome. I did my steering wheel, leather wrapped. Hands on it allll the time. Absolutely awesome.
CrAzYMoPaRGuY
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: GoodysGotaCuda] #2565444
10/17/18 04:43 PM
10/17/18 04:43 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I changed colors and used SEM spray with great success. Lasted quite awhile until some peel started on steering wheel, which I cleaned often. I did not use adhesion promoter. Love SEM sprays, never tried their dyes.
I cleaned first with Isopropyl Alcohol.
Facts are stubborn things.
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: larrymopar360] #2565480
10/17/18 05:49 PM
10/17/18 05:49 PM
Canada
Canada
Try adhesion promoter imo.
CrAzYMoPaRGuY
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: DAYCLONA] #2565604
10/17/18 09:39 PM
10/17/18 09:39 PM
Ontario, Canada
D149 Offline
D149  Offline
Ontario, Canada
Can you get SEM in colours other than the standard white, black etc.? If so, where?
1968 Valiant Signet 4dr. 273 4spd
1969 Road Runner 383 4spd
1969 Barracuda 318 auto
1970 Dart Swinger 340 4spd
1975 Cordoba 400-4bbl
1988 Caravelle 318 Auto
1999 Dakota R/T
2000 Viper GTS
2001 Ram 2500 Diesel 6spd
2018 Dodge Challenger GT (Winter beater!)
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: GoodysGotaCuda] #2565610
10/17/18 09:51 PM
10/17/18 09:51 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I scrubbed a set of green '68 Charger seats with trisodium phosphate, water, and a Scotchbrite. Emulsifies all oils and silicone, and most importantly, washes it all away. The acetone or lacquer thinner method just dilutes the contaminates as you wipe the surface. An autobody supply shop mixed up a quart of SEM to match the white rear seat I had, and it turned out great. No bleed through of the green, even in the pleats of the '68 seats, and it didn't peel or wear, but I sold the car in a couple years.
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: D149] #2565616
10/17/18 09:58 PM
10/17/18 09:58 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Amazon has some options.
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=sem+color+coat
The off white that is in my Dart is probably fairly close to this one [close enough]
https://www.amazon.com/SEM-15003-Phantom...=sem+color+coat
2020 RAM 1500
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: GoodysGotaCuda] #2565617
10/17/18 09:59 PM
10/17/18 09:59 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
thanks for the feedback all, I will see how this goes!
2020 RAM 1500
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: D149] #2565621
10/17/18 10:05 PM
10/17/18 10:05 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
I had a paint store that sells SEM custom mix colours for me and put it in spray cans, so the answer could be yes, depending who you get yours from. They also carry about 15 premixed colours in stock in spray cans in case you don't need an exact colour match.
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: D149] #2565711
10/18/18 12:00 AM
10/18/18 12:00 AM
Paducah, KY USA Earth
jcruse64 Offline
jcruse64  Offline
Call or email SEM, but yes, they can do about any color on the dyes for special order. I wanted to do dash, glove box lid, arm rests, and fiberglass door panels on my '73 truck, to the original green from that year. They said they did not have that color. One of the 4 arm rests had a section with the original color showing still. I sent it to them, and they matched it. Turned out well.
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: GoodysGotaCuda] #2565921
10/18/18 01:56 PM
10/18/18 01:56 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Heres the solution and it works great. Buy a rattle can of the SEM white. It covers the black with ease. No need to cover it perfect. Just get it even. A fog coat and a second pass will do. Shoot the tan over the white using a detail gun in the same session. You won’t need near as much tan. It will cover evenly and really pop. I learned this trick from my paint jobber. Tried it both ways and the difference is very clear.
I’m listening.
Re: Dying/Painting Vinyl Door Pads - Black to Tan [Re: CrAzYMoPaRGuY] #2566647
10/19/18 09:03 PM
10/19/18 09:03 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Next time I will. But I was impress without the promoter.
