Headers tips & tricks!
#2563978
10/14/18 06:04 PM
10/14/18 06:04 PM
Posts: 78 Sweden
ChallengerRag
Sweden
Hi, as i might swap out mine original type iron headers your ideas of brands & recomendations are welcome. Facts 71 Chally, 440six pack, auto trans, ps, pb, has the original a31 hp axle package, so discs in front, 3;91 sure grip, short ratio pitman is included. So this is ordered same as an RT but is an Conv.. was 340 now 440sp Have looked at TTI 1-7/8 440 headers, think mini starter is a must but more? is it best throw in an slant six hehe.. any advice what headers to look for? Thanks Michael Stockholm
Re: Headers tips & tricks!
[Re: ChallengerRag]
#2563999
10/14/18 06:48 PM
10/14/18 06:48 PM
Posts: 4,794 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Car like that I wouldnt dream of any header other than TTI, Dougs or Schumacher. All above mentioned with ceramic coated are above $700. The Shumachers are easiest to install and work around but also are limited to 450 horsepower as stated by the MFGR. If it were my car Id go 1 7/8" Dougs or TTI.
Keep old mopars alive.
[Re: ksat]
#2564198
10/15/18 12:35 AM
10/15/18 12:35 AM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have Doug's 2" headers on my Savoy and they fit absolutely perfect even with a 4 speed. I have a steel bellhousing and I had to trim the edges so the tubes would clear. A stock bell would not be an issue. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: ChallengerRag]
#2564249
10/15/18 04:14 AM
10/15/18 04:14 AM
Posts: 4,848 Memphis
HemiRick
Memphis
TTI all the way, I have a set on the 451 in my Challenger and they fit great and make the engine 10-15% more HP.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Cudajon]
#2564261
10/15/18 06:54 AM
10/15/18 06:54 AM
2boltmain
Holland MI Ottawa
Unless you're planning other modifications I'd stick with stock manifolds on a car like that. You're not gonna get a big improvement in power with headers. Beautiful car by the way. This s so true but the hobby has to do with tinkering and trying new stuff.. I love the look of a high quality silver ceramic coated header.
[Re: ChallengerRag]
#2564380
10/15/18 01:31 PM
10/15/18 01:31 PM
Posts: 17,915 S.E. Michigan
ZIPPY
S.E. Michigan
I still use Hooker Super Comps. I've had the same gaskets on mine since circa 2003. I do use copper collector gaskets. Not a ton of miles in that time, I will admit, but when I take it out I seldom baby it. They work ok. I would never pay retail for them though.
Rich H.
Esse Quam Videri
[Re: ChallengerRag]
#2564391
10/15/18 01:52 PM
10/15/18 01:52 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Hi, as i might swap out mine original type iron headers your ideas of brands & recomendations are welcome. Facts 71 Chally, 440six pack, auto trans, ps, pb, has the original a31 hp axle package, so discs in front, 3;91 sure grip, short ratio pitman is included. So this is ordered same as an RT but is an Conv.. was 340 now 440sp Have looked at TTI 1-7/8 440 headers, think mini starter is a must but more? is it best throw in an slant six hehe.. any advice what headers to look for? Thanks Michael Stockholm If you never rev the motor past 4500 rpm, keep the cast iron manifolds. If anything add a set of Hooker Aero Chamber mufflers to give the car a deeper exhaust note. Most of my friends in Stockholm and Finland have already put their cars away for the long winter. Rust from the inside out is an issue with headers that sit for long periods of time. Even if they are coated inside and out, which helps extend their life. Get the full TTI exhaust if you are going to pull the trigger on upgrading your exhaust. It's the best, but pay for the inside and out coatings.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: ChallengerRag]
#2564429
10/15/18 03:09 PM
10/15/18 03:09 PM
Posts: 2,578 sweden
1Fast340
sweden
If that was my car i would get the TTI headers,after owning one set it was a nobrainer to buy TTI again when i decided i needed a bigger set. Do the ceramiccoated inside and out. Regarding ministarter or not,check the application notes from TTI but overall i like them anyway since they are smaller lighter and i guess they might need less power to start an engine due to not be of a stoneage design. That looks like one fine car you have there! Still a few nice cars on the roads before the long dark winter sets in!
[Re: ChallengerRag]
#2564502
10/15/18 05:24 PM
10/15/18 05:24 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
I like going fast so headers for me. If you do get headers, go with TTI.
[Re: ChallengerRag]
#2564519
10/15/18 06:13 PM
10/15/18 06:13 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
headers like to hug the starter so much that you have to move them to get the couple apart. I'd stay with stock manifolds
I built a brand new motor and not being filthy rich,had one set of TTI's to install. The bummer was TTI stated NOT to install the headers on an engine to be broken in as it would ruin the ceramic coating. Nice
