Page 2 of 3 1 2 3
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564241
10/15/18 03:42 AM
10/15/18 03:42 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I also forgot to say that my car is 10.6 comp and I run 92 pump. Ron
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564317
10/15/18 11:29 AM
10/15/18 11:29 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
What’s the timing light being used?
FWIW, I’ve never dynoed anything where the best power was made at 28* timing.
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564348
10/15/18 12:18 PM
10/15/18 12:18 PM
New York
polyspheric Offline
polyspheric  Offline
New York
High VE means higher cylinder pressure: less spark
Boffin Emeritus
Re: 500" R/B Total Advance Timing [Re: polyspheric] #2564354
10/15/18 12:27 PM
10/15/18 12:27 PM
Come on now, you know you meant less lead, not less energy on the spark plug tip? correct grin whistling
Re: 500" R/B Total Advance Timing [Re: Cab_Burge] #2564375
10/15/18 01:17 PM
10/15/18 01:17 PM
N.W. INDIANA
moparjohn Offline OP
N.W. INDIANA
Here are some pictures of my timing light. It is still set at 28 degrees from the last run.
MJ
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564377
10/15/18 01:19 PM
10/15/18 01:19 PM
N.W. INDIANA
N.W. INDIANA
Here are some more pictures of the #1 and #2 spark plugs. The first 2 are #1 and the last 2 are #2. The one turned out real well and should help analyze.
MJ
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564395
10/15/18 02:04 PM
10/15/18 02:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What plug n heat range...........looks rich, wet and unhappy........
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564396
10/15/18 02:06 PM
10/15/18 02:06 PM
AndyF Offline
AndyF  Offline
Your plugs look horrible. Either those plugs have 100,000 miles on them or else you have something really wrong with your tune. Here is a plug out of my 514 engine after making 900 hp on the dyno. This engine is 15:1 compression.
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564416
10/15/18 02:45 PM
10/15/18 02:45 PM
So. Burlington, Vt.
So. Burlington, Vt.
Dial-back timing lights...... I don’t trust them.
The first thing I’d do is get a light without the dial-back feature and redo the test at the track.
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564530
10/15/18 06:41 PM
10/15/18 06:41 PM
AndyF Offline
AndyF  Offline
That is another possibility. Your timing light could be lying to you and you are actually running 40 degrees of advance. That is why your plugs look like that and would explain why the engine is happier when you retard it a few degrees.
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564606
10/15/18 09:48 PM
10/15/18 09:48 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Those plugs look quite unhappy....First how many passes are on them? What plug is it?
Re: 500" R/B Total Advance Timing [Re: fast68plymouth] #2564630
10/15/18 10:49 PM
10/15/18 10:49 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I thought I was the only one that felt this way. Only used two dial-backs, and they were both incorrect. I'm still using my 45 year old Sears non dialback timing light.
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564657
10/15/18 11:41 PM
10/15/18 11:41 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Have you ever dialed zero on that light and checked the timing? I'm like the other guys, have doubts about the accuracy of the timing light. Only reasonable explanation or best power at 28 degrees.
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564701
10/16/18 01:33 AM
10/16/18 01:33 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Those plugs in the pics have short straps, mine are NGK BCP7ES have straps that are over the electrode. Any benefit from a short strap ?
1963 Plymouth Max Wedge
1971 Barracuda
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564722
10/16/18 03:53 AM
10/16/18 03:53 AM
AndyF Offline
AndyF  Offline
The short strap plugs are a little more fool proof. I like to use them on high compression engines. I don't think there is a power difference, they are just a little more robust since it is harder to bend the strap if someone on your pit crew drops the plug on the ground when you aren't looking.
Re: 500" R/B Total Advance Timing [Re: ozymaxwedge] #2564726
10/16/18 04:47 AM
10/16/18 04:47 AM
The exposed gap into the combustion chamber is usually a small benefit for race motors, especially if your close to the piston tops with the plugs work
Try them and see if you like them thumbs
Re: 500" R/B Total Advance Timing [Re: Al_Alguire] #2564824
10/16/18 01:57 PM
10/16/18 01:57 PM
N.W. INDIANA
N.W. INDIANA
The plugs have no more than 20 passes on them.
I have attached a picture of a new box of plugs.
They are Champion product number 297 plug number C61CX.
The heat range is the 61 in the part number.
I hope this helps?
MJ
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564841
10/16/18 02:35 PM
10/16/18 02:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I hope this helps?
MJ
Lawn mower plugs........... whistling
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564854
10/16/18 02:50 PM
10/16/18 02:50 PM
Washington
madscientist Offline
Washington
Nothing wrong with that plug. I use champions and that's all I use unless the customer has some weird aversion to them.
That 61 is a fairly cold plug, yet those look hot. Unless you are at sea level and 15:1 that plug should be the correct range. You can try the 59 but I'm not sure what's going on.
You got a ton of fuel moving through the engine, no timing and plug that looks hot. Something is weird.
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564862
10/16/18 02:58 PM
10/16/18 02:58 PM
Washington
Washington
I just skimmed back through the thread and you are at 12:1 so that plug SHOULD be too cold. I would have started with a 284/C65YC or if you don't want the extended tip you can use the 285/C65C and tune from there.
So I've switched horses mid stream. I'm going to say get a hotter plug, verify TDC and your timing light and tune from there.
As AndyF said your plugs look bad. Sometimes looking at pictures isn't the same as looking in real life.
If there is no reason you can't run an extended tip plug, I'd use the extended tip.
Page 2 of 3 1 2 3
