Page 1 of 3 1 2 3
500" R/B Total Advance Timing #2563889
10/14/18 03:14 PM
10/14/18 03:14 PM
N.W. INDIANA
moparjohn Offline OP
N.W. INDIANA
I recently went to an end of season test and tune. I had been running a total advance of 36 degrees and reduced it to 32 degrees and the car ran about 7 hundredths quicker? I then reduced it to 28 degrees and it picked up a couple more hundredths? It is a lot easier on the starter when it's warm and at 28 vs 36 also.
I would like to know what others are running for total advance on their 500" R/B engines?
Thanks! MJ
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2563894
10/14/18 03:25 PM
10/14/18 03:25 PM
New York
polyspheric Offline
polyspheric  Offline
New York
How much is initial?
Boffin Emeritus
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2563895
10/14/18 03:26 PM
10/14/18 03:26 PM
Did you verify TDC on the dampener and timing tab?
The reason I ask that is when we tested timing at the track or on a engine or chassis dyno all the RB we tested like from 34 to 36 max, the race cars would slow down in the 1/4 with 38 or 32 degrees total shruggy
That was a long time ago with stock stroke iron headed bracket motors running in Super Street.
We ran street hemi cars in NHRA stock and had the same results on both of those cars shruggy
My last pump gas 518 C.I. BB with iron and aluminum heads seemed to like from 34 to 36 degree also up
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2563898
10/14/18 03:30 PM
10/14/18 03:30 PM
AndyF Offline
AndyF  Offline
Depends on the heads and the piston shape and the fuel as well as other things but typically a BB Mopar with aftermarket heads and a flat top piston will like 34 degrees of timing. Maybe more, maybe less but any new build I work on we start with 34 and work from there. 28 seems a little low for max performance so you might have something else going on with that combination.
Re: 500" R/B Total Advance Timing [Re: Cab_Burge] #2563902
10/14/18 03:36 PM
10/14/18 03:36 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
What it likes will depend on a lot of variables like CR, quench, combustion chamber and cam timing/events. (Edit: I see Andy beat me to this..)
Mine likes 36° total on 91 no ethanol. Starts INSTANTLY and shuts off easily. That goes away when I pull 6° out for the nitrous. It is harder to start and doesn't like to shut off without running on. Eventually I will put a timing adjust knob in it for the MSD but for now I am doing it manually.
Re: 500" R/B Total Advance Timing [Re: GY3] #2563918
10/14/18 04:04 PM
10/14/18 04:04 PM
N.W. INDIANA
N.W. INDIANA
Thanks for the replies!
Here is some added info:
Yes, The TDC of the piston and timing mark was verified.
The pistons are flat tops with Indy SR heads Max Wedge type intake ports.
Running 110 race fuel and compression is 12 to 1.
MJ
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2563936
10/14/18 04:36 PM
10/14/18 04:36 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
My Little 383/432 Stroker
Edelbrock E Street 75cc
10.5-1 True Compression
200 # Cranking Compression On All Eight
Comp Cams XE275HL
Loves 15 Initial - 18 Mechanical - 33 Degrees Total
91 Octane No Ethanol
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2563946
10/14/18 04:49 PM
10/14/18 04:49 PM
AndyF Offline
AndyF  Offline
Indy SR heads with flat top pistons and 12:1 CR should like 34 degrees. What do your plugs look like? You might have something else going on. Maybe the wrong air fuel ratio or weak spark.
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2563950
10/14/18 04:55 PM
10/14/18 04:55 PM
Minn
SportF Offline
SportF  Offline
Minn
This has come up before, and I kinda took a poll on racers running timing on B and RB engines.
I don't remember anybody running less than 34 degrees total, with most running 36-38. This is with verified time marks. I also informally did this at the track, talking to Mopar racers with the same results.
If yours is running great at 28 degrees, that just doesn't sound right, in a couple of different ways.
I've been running 38 degrees for years, on a street 440, and a race 500 ci.
Good luck.
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564013
10/14/18 07:29 PM
10/14/18 07:29 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
John, I know the engine Bill's running with SR's didn't really make a difference between 32 and 36 either. Other than starting easier at 32. It did go slower at 38. We made back to back passes though no dyno like most of these guys.
Re: 500" R/B Total Advance Timing [Re: DblOJoe] #2564033
10/14/18 08:18 PM
10/14/18 08:18 PM
N.W. INDIANA
N.W. INDIANA
Joe,
Thanks for the feedback on Bill's engine. I'm a bit disappointed it didn't pick up with the 32 degrees of advance. Like Bill I've been adjusting out there on the track and watching the results. I'm going to pull a couple of plugs and share the pictures here.
John
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564035
10/14/18 08:25 PM
10/14/18 08:25 PM
PA
moparacer Offline
moparacer  Offline
PA
A lot of factors go into total timing. So much that you really can't go off of anyone else's setup. AF ratio, spark plug heat range, altitude you are running at, RPM range, piston type, cylinder head and combustion chamber efficiency, and on and on and on.
I have a 500 B on alky with 13.3 compression and domes that doesn't like any less than 38 degrees total. And the domes make it want more timing from my experiences and I have ran similar setups with flat tops that want lower total, maybe not like you are seeing but in the lower 30s anyway.. If she wants to run at 28, I would run her at 28!
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564040
10/14/18 08:34 PM
10/14/18 08:34 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Mine seems to like about 36 total. I dropped it to 32 and it slowed down. Ron
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564046
10/14/18 08:39 PM
10/14/18 08:39 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
FWIW my 470" low deck picked up power on the dyno when we backed it down to 32* from 34*.
I haven't put it in the car .
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564052
10/14/18 08:48 PM
10/14/18 08:48 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
My 500" wedge always liked 34*. I ran several different cams in the 245* to 255* range.
Master, again and still
Re: 500" R/B Total Advance Timing [Re: DaveRS23] #2564081
10/14/18 09:49 PM
10/14/18 09:49 PM
N.W. INDIANA
N.W. INDIANA
Here are the # 1 ( right ) and # 2 ( left ) plugs right after the last run at 28 degrees total advance. I had gone back up to 32 degrees and slowed a bit and then back to 28 degrees and picked back up.
MJ
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564086
10/14/18 09:54 PM
10/14/18 09:54 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Can’t see the timing marks on the ground electrodes with those fuzzy pictures
But it’s running rich
Siberian Huskies
Re: 500" R/B Total Advance Timing [Re: bee1971] #2564128
10/14/18 10:44 PM
10/14/18 10:44 PM
Washington
madscientist Offline
Washington
It's rich and the plug looks hot. That's why it likes less timing. He is pulling timing to keep the plug from overheating, rather than let the plug function like it was designed.
I've seen that my entire life.
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564153
10/14/18 11:19 PM
10/14/18 11:19 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine runs 15-1, flat top, 4.5 bore, -1 head. 114 renegade fuel. 32 degrees. Any more timing does nothing for ET or MPH. It's run as little as 28 degrees. Barely killed .10 in ET.
Doug
Re: 500" R/B Total Advance Timing [Re: moparjohn] #2564219
10/15/18 01:36 AM
10/15/18 01:36 AM
A most efficient highly developed all race N/A motor on good quality high octane race gas will like less timing than a conventional bracket or Stock super Stock like motor will, I'm talking about Pro Stock and Comp Eliminator motors that like a BSFC in or lower than .32 Lbs. per hour work
On your deal with those spark plugs it looks like pitting and blistering on the porclyn and way to hot on the heat range as well as rich on the AFR work twocents
Page 1 of 3 1 2 3
