Re: 500" R/B Total Advance Timing
[Re: moparjohn]
#2564317
10/15/18 11:29 AM
10/15/18 11:29 AM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
What’s the timing light being used?
FWIW, I’ve never dynoed anything where the best power was made at 28* timing.
[Re: moparjohn]
#2564348
10/15/18 12:18 PM
10/15/18 12:18 PM
Posts: 4,206 New York
polyspheric
New York
High VE means higher cylinder pressure: less spark
Boffin Emeritus
[Re: moparjohn]
#2564377
10/15/18 01:19 PM
10/15/18 01:19 PM
Posts: 1,453 N.W. INDIANA
moparjohn
N.W. INDIANA
Here are some more pictures of the #1 and #2 spark plugs. The first 2 are #1 and the last 2 are #2. The one turned out real well and should help analyze. MJ
[Re: moparjohn]
#2564395
10/15/18 02:04 PM
10/15/18 02:04 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
What plug n heat range...........looks rich, wet and unhappy........
[Re: moparjohn]
#2564416
10/15/18 02:45 PM
10/15/18 02:45 PM
fast68plymouth
So. Burlington, Vt.
Dial-back timing lights...... I don’t trust them.
The first thing I’d do is get a light without the dial-back feature and redo the test at the track.
[Re: moparjohn]
#2564606
10/15/18 09:48 PM
10/15/18 09:48 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
Those plugs look quite unhappy....First how many passes are on them? What plug is it?
[Re: fast68plymouth]
#2564630
10/15/18 10:49 PM
10/15/18 10:49 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
The first thing I’d do is get a light without the dial-back feature and redo the test at the track. I thought I was the only one that felt this way. Only used two dial-backs, and they were both incorrect. I'm still using my 45 year old Sears non dialback timing light.
[Re: moparjohn]
#2564701
10/16/18 01:33 AM
10/16/18 01:33 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Those plugs in the pics have short straps, mine are NGK BCP7ES have straps that are over the electrode. Any benefit from a short strap ?
1963 Plymouth Max Wedge 1971 Barracuda
[Re: ozymaxwedge]
#2564726
10/16/18 04:47 AM
10/16/18 04:47 AM
Posts: 43,126 Bend,OR USA
Cab_Burge
Those plugs in the pics have short straps, mine are NGK BCP7ES have straps that are over the electrode. Any benefit from a short strap ? The exposed gap into the combustion chamber is usually a small benefit for race motors, especially if your close to the piston tops with the plugs Try them and see if you like them
[Re: moparjohn]
#2564841
10/16/18 02:35 PM
10/16/18 02:35 PM
Thumperdart
State of confusion
The plugs have no more than 20 passes on them. I have attached a picture of a new box of plugs. They are Champion product number 297 plug number C61CX. The heat range is the 61 in the part number. I hope this helps? MJ Lawn mower plugs...........
[Re: moparjohn]
#2564854
10/16/18 02:50 PM
10/16/18 02:50 PM
Posts: 4,457 Washington
madscientist
Washington
Nothing wrong with that plug. I use champions and that's all I use unless the customer has some weird aversion to them.
That 61 is a fairly cold plug, yet those look hot. Unless you are at sea level and 15:1 that plug should be the correct range. You can try the 59 but I'm not sure what's going on.
You got a ton of fuel moving through the engine, no timing and plug that looks hot. Something is weird.
[Re: moparjohn]
#2564862
10/16/18 02:58 PM
10/16/18 02:58 PM
madscientist
Washington
I just skimmed back through the thread and you are at 12:1 so that plug SHOULD be too cold. I would have started with a 284/C65YC or if you don't want the extended tip you can use the 285/C65C and tune from there.
So I've switched horses mid stream. I'm going to say get a hotter plug, verify TDC and your timing light and tune from there.
As AndyF said your plugs look bad. Sometimes looking at pictures isn't the same as looking in real life.
If there is no reason you can't run an extended tip plug, I'd use the extended tip.
