Caravan cruise control issue .... #2560447
10/07/18 06:58 PM
10/07/18 06:58 PM
Florida STAYcation
dOc ! Offline OP
The village idiot's idiot
dOc !  Offline OP
Florida STAYcation
Just recently happened in my 05 ... You set the cruise then 1 mile or 10 miles or even more later .. The cruise cuts off. Kills the cruise lite in the dash so to get it to restart you have to shut the car off and restart the vehicle OR "key" the car while rolling and restart it then. When I hit the on button the cruise could last 1 or maybe 50 miles or the cruise lite could go on and then immediately off. When the cruise is working - it works great. I've been putting some serious miles on this van - I sure miss that cruise.
Re: Caravan cruise control issue .... [Re: dOc !] #2560519
10/07/18 09:13 PM
10/07/18 09:13 PM
Guitar Jones Offline
Is the switch in the steering wheel? If so my best WAG would be the clock spring.
Nice to see you back, now behave yourself. laugh2
Re: Caravan cruise control issue .... [Re: dOc !] #2560535
10/07/18 09:52 PM
10/07/18 09:52 PM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
Hay GEEtar ... Yes on the steering wheel switch - The clock spring ? That's the wiring pack between the steering wheel and column ? Fractured wires ? What causes this ? Back and forth action of the s wheel over time ? Ez fix ??
Behave ? lol .. I know whose sandbox this is ! Btw - I saw your email some time ago ... It went poof on me !! I would have responded back. BTW - it's good to see your CONVERTER HUB is finally fixed !
Re: Caravan cruise control issue .... [Re: dOc !] #2560735
10/08/18 10:13 AM
10/08/18 10:13 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
From what Ive read some of the clock springs had problems.Our 12 Journey was perfect one day.The nextair bag light on .Typically if clock spring air bag light is on and lots of the wheel accs stop working completley like the cruise.Typically the switch in the wheel is the culprit.The journey at times wont come on.Smack the side of the wheel and it works.Will replace it one day.Oh yeah welcome back.Rocky
Chrysler Firepower
Re: Caravan cruise control issue .... [Re: therocks] #2560932
10/08/18 03:41 PM
10/08/18 03:41 PM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
Thx Rocky .... I called a two diff dealers to see if there was or ever was a recall. I was told no. But who knows if that is true? I was LIED TO when I had an MAJOR ISSUE with a headlight switch/wiring on a 98 diesel dually some years ago. Kind of serious when you suddenly lose headlights on I-55 in Illinois at midnite !
How big of a deal is it to r and r that clock spring ?
Re: Caravan cruise control issue .... [Re: dOc !] #2560939
10/08/18 03:59 PM
10/08/18 03:59 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
No recalls on it from what I know.Its not bad to do.Just have to discharge the electric r&R the air bag and then wheel.Then the retainer and the clock spring.I did some at work but that was years ago.When mine went cruise was totally nothing.Rocky
Chrysler Firepower
Re: Caravan cruise control issue .... [Re: therocks] #2560968
10/08/18 04:40 PM
10/08/18 04:40 PM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
R ... What should that job cost in the fair market ? I still don't have a building ... Jsta small man cave / storage unit that's full of bikes presently
Re: Caravan cruise control issue .... [Re: dOc !] #2561286
10/09/18 08:14 AM
10/09/18 08:14 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Had the dealer do the clock spring in the Journey.I could have done it but wasnt sure that was the problem.Was like 95% sure but not totally since I dont have the scanners and shop now.Cost parts labor and diag was around 500.Wife said she would rather pay than not and still not fixed.I do know my wheel switch for cruise will need replaced one day.Ill do that as its pretty easy and the switch isnt a lot.Rocky
Chrysler Firepower
Re: Caravan cruise control issue .... [Re: dOc !] #2561448
10/09/18 03:11 PM
10/09/18 03:11 PM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
500 beans ? Holy Chit !! ... What's the grocery list of those charges ? How about jsta going to a junkyard and pulling the whole steering column out of a car there and hoping it works ??!! .. I've never done any steering wheel work that has a air bag in it
Re: Caravan cruise control issue .... [Re: dOc !] #2561863
10/10/18 12:11 PM
10/10/18 12:11 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What about a brake pedal switch or a parking brake pedal switch? I have had a vehicle where the switch was too sensitive and a bump in the road would kill the cruise. Had to adjust the switch out a bit, problem solved.
Re: Caravan cruise control issue .... [Re: DaytonaTurbo] #2561874
10/10/18 12:18 PM
10/10/18 12:18 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Mine does that but sometimes doesn't come on in mu 06 T&C. I found that the main connector behind the drivers fender comes loose and turns random things on and off. I once lost my power window on the drivers side, jiggled the connector and it worked again. Terrible design is all I can say... eyes
JB Rhinehart, Realist
A-Body's RULE!
Re: Caravan cruise control issue .... [Re: Rhinodart] #2561910
10/10/18 01:30 PM
10/10/18 01:30 PM
moparx Offline
moparx  Offline
my wife's concorde cruise would work sporadically, and sometimes just cut out while working. had to tear out the complete dash for an evaporator replacement, found a loose connection at the brake light switch, so that was fixed. it's been two years since that job, and there hasn't been a cruise issue since. so it appears my problem was the brake light switch. you're mileage may vary .......
beer
Re: Caravan cruise control issue .... [Re: dOc !] #2562139
10/10/18 09:28 PM
10/10/18 09:28 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Wonder if you could pull codes by turning the ign switch on & off a few times and get the flashing light.For instance 3 blinks is a 3 with a pause then 4 blinks would be 4 making the fault code 34 work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Caravan cruise control issue .... [Re: DaytonaTurbo] #2562250
10/11/18 01:24 AM
10/11/18 01:24 AM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
DT .. I did consider that but this situation kills the system temporally ... A brake lite deal would allow you to hit the resume button and be on your way.
Re: Caravan cruise control issue .... [Re: Rhinodart] #2562254
10/11/18 01:27 AM
10/11/18 01:27 AM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
Main connector ? ... I'll have to check that tomorrow THX
Re: Caravan cruise control issue .... [Re: moparx] #2562258
10/11/18 01:32 AM
10/11/18 01:32 AM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
beer
X ... The brake lite switch ON/near the brake pedal ? Did your issue make you have to restart the car to make the dash lite AND THE SYSTEM ITSELF to operate again ?
Re: Caravan cruise control issue .... [Re: hemi-itis] #2562261
10/11/18 01:36 AM
10/11/18 01:36 AM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
Good idea itis !! ... I talked to a Bud today about taking this in and have someone with a big scanner to pull up some deep codes. Do you think the keying codes would reveal these issues ?
Re: Caravan cruise control issue .... [Re: dOc !] #2562417
10/11/18 01:05 PM
10/11/18 01:05 PM
moparx Offline
moparx  Offline
beer
sometimes yes, and sometimes no. that was the mystery. i tried different steering wheel switches, and other things, but i forget exactly what. ["oldtimers" disease] i couldn't get any codes from the 'puter. after it started working, i got a set of factory diagnostic manuals, but it has worked flawlessly since i fixed that wire. so shruggy
beer
Re: Caravan cruise control issue .... [Re: dOc !] #2563723
10/14/18 02:30 AM
10/14/18 02:30 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The dealer can record the electronics while driving it as I used to do it all the time. The scanner will also tell you why the cruise cut out the last time it was on. I could drive and record the electronics or I could install what we called the Co-Pilot and let the owner drive it and hit a button on it when the cruise cut out. Then he brings it back and I would download the info in the shop computer and I could see just what caused it to cut out. But have the codes checked first as it may have a code in it for the problem. Sometimes it would but not all the time. I replaced clocksprings and brakelite switches , cruise servo's and cruise switches along with even PCM's to fix cruise problems over the years. This sounds to an electrical problem and not vacuum related. Ron
Re: Caravan cruise control issue .... [Re: dOc !] #2563762
10/14/18 10:18 AM
10/14/18 10:18 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ron. Doc dosent probally want to spend $$$ on diag.Most peopledont.They will spend a bundle guessing etc but when it comes to paying say 100 bucks for diag no way.Saw it all the time at work.Rocky
Chrysler Firepower
