Re: Full metal jacket in Mopar Action again?
[Re: fullmetaljacket]
#2564399
10/15/18 02:15 PM
10/15/18 02:15 PM
Posts: 31,021 Oregon
AndyF
Andy.
I've never used CAD programs to make parts. Most shops or computer heads out here are too busy to give the light of darkness. LOL For that, I approached everything with an old school mentality consisting of found or purchased materials at surplus outlets, rulers, pencils, hacksaws, drills and determination. I would love to CAD a few items that I can not make or just simply don't have the time to. It would be cool to mill out or 3D print titanium and or aluminum door handles, dash mounted knobs, mirrors and such.
Thank you TBoom. Shoot me a PM with some things you might want to work on and I'll see if I can help. I have CAD programs for a lot of parts. I mostly focus on 2D or 2.5D parts but I know guys who do 3D and have solid printers. The new gen solid printers can print metal parts but I haven't used that technology for any car parts yet. Here is a picture of the Holley EFI gauge that only weighs 2 oz.
#2565079
10/16/18 09:17 PM
10/16/18 09:17 PM
AndyF
Yes, It's a GM 140 amper and IIRC, it weighed like 11 Lbs or so where as the original 35 amp Chrysler unit was around 14 Lbs. I installed that one wire alternator after what it seemed was a low rating on the out put of the original. I have an electric fan with relays, electric Aeromotive in tank fuel pump, lights, and was spooked that the 55 Denso units would not pull their lightweight stuff. Perhaps I am paranoid. Since you have a running combination you could have your charging system tested to see how many amps you are actually using. Anyone with a decent voltmeter and amp clamp should be able to do the test for you. Turn on all of your lights, fans, pump, etc and see how many amps you are pulling. I doubt you use more than 55 amps. If you like the look of the factory alternators you could probably get an OE 37 amp unit gutted and rewired to put out 60+ amps. I'm sure it would be a lot less work than you invested in that steering wheel! That was a crazy amount of work. I can't even imagine how much work you have tied up in some of those parts.
[Re: RV2]
#2565199
10/17/18 01:59 AM
10/17/18 01:59 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
This is a very well deserved honor, with all of the hard work and determination you put forth over the years. You have my respect and appreciation for sure. Congrats!!
[Re: Chargerfan68]
#2565221
10/17/18 02:59 AM
10/17/18 02:59 AM
fullmetaljacket
Hey guys. Just getting a glimpse at this on the north side of midnight. First and foremost, thank you most for the inspiring remarks. Though this should be generated to the real world weight loss thread, it's cool to reflect on here as well.
Andy: "Shoot me a PM with some things you might want to work on and I'll see if I can help. I have CAD programs for a lot of parts. I mostly focus on 2D or 2.5D parts but I know guys who do 3D and have solid printers. The new gen solid printers can print metal parts but I haven't used that technology for any car parts yet. Here is a picture of the Holley EFI gauge that only weighs 2 oz."
I'd love to take you up on the offer to help with the CAD stuff in what ever way you possibly can. I'll soon send you over some quick flicks to give an idea of parts and you let me know if its realistic. I'd love to see door handles, side view and rear view mirrors be printed out of aluminum. Those things are heavy so imagine that. That EFI gauge is unimaginable in that weight class. Talk about Welter feather weight category.
Topside: "Love the idea of aluminum door handles; I presume you've already done the hinges".
Yes, I had already addressed the hinges quite a few years back when I found the cat that was reproducing the A864' and A990-65' aluminum hinges, but did not install them till recently when the new doors went on.
Rtsrunner: "What does this car weigh now?
Though I've yet to see the article, I'd hate to blow the meat and potatoes before it hits the stands. I will say this though after holding out for so long, I've done a few minor things since I've last talked to the "Action" team, so I can safely say that the car has now dived below the 3000 Lbs watermark. I'd like to go back and weigh it and get a real world number to you guys within this coming week or next when I pay a visit to the Lab.
More importantly, cars don't go down the road on their own, and standing weight or curb weight is just that, curb. If I could get this thing where it carries my 175 Lb structure while still flashing at or about 3000 Lbs, I'd be a happy camper.
Andy: "Since you have a running combination you could have your charging system tested to see how many amps you are actually using. Anyone with a decent voltmeter and amp clamp should be able to do the test for you. Turn on all of your lights, fans, pump, etc and see how many amps you are pulling. I doubt you use more than 55 amps. If you like the look of the factory alternators you could probably get an OE 37 amp unit gutted and rewired to put out 60+ amps. I'm sure it would be a lot less work than you invested in that steering wheel! That was a crazy amount of work. I can't even imagine how much work you have tied up in some of those parts.
I am going to look at my amp draw and see what kind of electrical appetite it has. I'd be more than happy to run one of those 55 amp mini power stations being that they probably weigh next to nothing. Are they a one wire combo?
I can't even imaging how to tell y'all how much work both hard and fun it has been to make things for this thing.
Over, but not out.
[Re: AndyF]
#2566677
10/19/18 09:55 PM
10/19/18 09:55 PM
AndyF
Yes, It's a GM 140 amper and IIRC, it weighed like 11 Lbs or so where as the original 35 amp Chrysler unit was around 14 Lbs. I installed that one wire alternator after what it seemed was a low rating on the out put of the original. I have an electric fan with relays, electric Aeromotive in tank fuel pump, lights, and was spooked that the 55 Denso units would not pull their lightweight stuff. Perhaps I am paranoid. Since you have a running combination you could have your charging system tested to see how many amps you are actually using. Anyone with a decent voltmeter and amp clamp should be able to do the test for you. Turn on all of your lights, fans, pump, etc and see how many amps you are pulling. I doubt you use more than 55 amps. If you like the look of the factory alternators you could probably get an OE 37 amp unit gutted and rewired to put out 60+ amps. I'm sure it would be a lot less work than you invested in that steering wheel! That was a crazy amount of work. I can't even imagine how much work you have tied up in some of those parts. I forgot I had this in my tool box until I spotted it today. This is a really simple tool for measuring current flow. I checked my starter and it draws 175 amps when the engine is cold. My ignition box uses 10 amps while the engine is running. The alternator in my car puts out about 35 amps with the engine running. Goes to 45 amps if I turn the lights on. The battery was fully charged in this picture so there was only an amp or two going to the battery.
[Re: AndyF]
#2568149
10/23/18 12:49 AM
10/23/18 12:49 AM
fullmetaljacket
My car may literally have thin skin and all, but thank God I have thick skin. Cliffy went to town with the snapping on my isms. LOL
That's what happens when you are neighbors in the same hood back in the day. LOL.
Good read and I'm glad they touched on the shadowy influential 2% cars.
[Re: topside]
#2568179
10/23/18 02:07 AM
10/23/18 02:07 AM
fullmetaljacket
I've actually snuck the rear past most eyes for many years, but the front stood right where Mother Mope put 'em. Besides, imagine the cost and work of moving a K-member and torsion bars a few inches forward. I figured by moving my engine back and the rear tires forward, it was equivalent to a 2% set up without the front tire give away.
