Re: fix heater hose threads in a aluminum intake
[Re: mopars4ever]
#2561021
10/08/18 06:57 PM
10/08/18 06:57 PM
Posts: 1,238 Chicago, IL
PLUM_72
Chicago, IL
You can partially weld it up then drill and re-tap with an NPT tap. Or just try and use the next largest NPT thread tap and do something unique with the hose fitting.
1972 Dodge Challenger
[Re: GoodysGotaCuda]
#2561218
10/09/18 01:20 AM
10/09/18 01:20 AM
Posts: 954 garnett kansas
rhad
garnett kansas
some years ago i used a epoxy type repair where you put it on the threads screwed it in then unscrewed the fitting and waited for it to setup,i used it on a stripped ford brake caliper,i cant remember the exact name ,but it was something like thread renew,etc,etc it worked great seems like you had to put something on the good threads first so they would release after it was screwed it before it cured,its been a few yrs back ,my memory is pretty spotty in my old age
my ladder of success is missing some rungs
[Re: mopars4ever]
#2561226
10/09/18 01:41 AM
10/09/18 01:41 AM
RapidRobert
what about JB welding it in there permanently? I've JB welded fittings into the cooling system for cooling routing mods & No issues.
[Re: DrCharles]
#2562102
10/10/18 08:03 PM
10/10/18 08:03 PM
RapidRobert
JB weld. NPT common plumbing iron fittings into alum tcover. solid as a rock.
[Re: Challenger 1]
#2562160
10/10/18 10:01 PM
10/10/18 10:01 PM
RapidRobert
This will be out on the dirt track so it'll all be good. The hood will not be popped unless I win & get teched.
[Re: Challenger 1]
#2562245
10/11/18 01:17 AM
10/11/18 01:17 AM
RapidRobert
Actually that is a VERY valid point.
